#2551 |
Member#: 170973
Vehicle:2004 WRX 4EAT PSM |
Not sure on idc. There were enough other issues going that I didn't think to log that. Should have, but I will next time. It's not true E85 in the tank either. More like E70 from my estimates.
My suspicions were also the fuel pump, but then I was thinking if it truly flows 190 l/hr then I would think that would be enough for a stock turbo on a non-aggressive tune if a walbro 255 can support near 400whp on E85. Maybe not though?
#2552 |
Member#: 219160
Vehicle:2002 Impreza WRX AW (6MT, E85, EWG, VF39) |
I don't believe it is the fuel pump. It will lean out at half throttle but I think that is because the map needs some work. I only did probably one WOT log last night and that was when the CEL started flashing for the Cyl. 1 misfire. On the way home last night, I would slowly give it more throttle and watch the wideband and the boost gauge. At 13psi, it will start to physically stutter and misfire. The AFR's were rich were a little rich, but not a whole lot. I am going to regap the plugs today and see what happens. This is also the first tank of gas and there was still a gallon or 2 of 91 in the tank when I filled it. I don't think that would cause the problems we are suffering though. At this point, I am fairly convinced it is a mechanical issue. If regapping does not work, I am going to pressure test the inlet. If that doesn't work, coil packs would be a good place to start and I will probably start on Cylinder 1 since that's where we got the misfire.
#2553 | |
Member#: 148974
SCIC
Vehicle:2002 WRX R.I.P. 2005 STi - sold |
#2554 |
Member#: 219160
I will try that. But it wouldn't really make sense that at half throttle the car runs fine. A little lean but there is no hesitation. And RIGHT at the point of 13psi, it starts to stutter and misfire. I'm kinda thinking that 13psi is just the point where the plugs do not have the energy to jump the gap.
#2555 |
Member#: 36033
SCIC
Vehicle:CEO PhatBottiTuning 2006 STi GTX3582 + Meth |
Fuel pump flow rates DECREASE as boost rises....
#2556 |
Member#: 219160
I will go log the car and I will post up the log.
#2557 |
Member#: 219160
Any thing in particular you would like me to log? FBKC, Throttle Position, and AF Corrected/Learned is probably what I would start with. I will watch my Wideband.
#2558 |
Member#: 36033
SCIC
Parameters to Log – remember some of this may not be visible until hooked up to the vehicle
Engine Speed (RPM ) Engine load (g/rev) Ignition total timing Injector Duty Cycle (IDC) FeedBack Knock Correction (fbkc) Fine Learning Knock Correction (flkc) Mass Air Flow Voltage (MAFv) LC-1 Manifold Relative Pressure (MRP) (4 byte)(or direct if 4byte not there) Intake Air Temperature (IAT) Primary Wastegate Duty Cycle (WGDC) TARGET Boost |
#2559 |
Member#: 219160
Ok. Probably won't be able to post it until later.
#2560 |
Member#: 219160
Unfortunately, I couldn't get a log. However, when I did the pull, right around 3k rpms it starts to stutter and misfire. I got a cel that I haven't pulled yet but I am almost positive its a misfire code. After a out 4k it starts to lean out to 12:1 then leans out more. I quit the pull after it got to 13:1. I can admit when im wrong and I believe you were right. The symptoms sound a lot like the fuel pump isn't flowing enough. But would that cause the mid range stuttering?
#2561 |
Member#: 183480
South East
Vehicle:2011 Audi A3 Quattro 2009 Forester XT |
#2562 | |
Member#: 170973
#2563 |
Member#: 219160
That's also a possibility that we have thought about. Would the first tank be enough to clog it though?
#2564 | |
Member#: 230366
TXIC
Vehicle:2005 STi Cobb Pro-Tuned |
#2565 |
Member#: 219160
135k. It may have been changed before me but I can't say for sure.
#2566 |
Member#: 139385
should be changed even if that doesn't fix the issue. it would be nice to put a fuel pressure gauge on your car and go drive the thing so see what happens. Ron is an awesome tuner. These mechanical issues are hard to diagnose over the internet though
#2567 |
Member#: 274321
#2568 | |
Member#: 165141
#2569 |
Member#: 159243
Vehicle:sg3 Turbo Tek Tuned Hakt Ecu e85 30r 6spd |
i shouldn't say anything cause i havce not been able to work on my car recently, but looking forward to the results.
i love diagnosing mechanical problems with ron over the phone! "i don't know dood, i'm a tuner not a mechanic!" |
#2570 |
Member#: 164830
SCIC
Vehicle:2002 WRX G61 III OVE 58e |
Possibilities:
Injector scaler too high MAF scaling too low Fuel pump can't keep up Clogged fuel filter Failing injector(s) Massive vacuum leak Failing MAF sensor As others have said, the appropriate things need to be logged. Do not do anymore WOT without logging the right stuff. Log, log, log! It could be knocking like crazy because of the lean condition. I had a very similar issue a few years ago and it turned out to be a fairly large vacuum leak and a faulty MAF sensor. |
#2571 |
Member#: 219160
We are going to run wastegate pressure today. If we still encounter lean AFR's up top, the problem lies elsewhere. If it hits the target AFR's, it is most likely the fuel pump. I do not think the stuttering is being caused by the fuel pump, that could be blowout or possibly the fuel filter clogged up. But then again, I don't know.
#2572 |
Member#: 219160
Btw, the injector scalor is set pretty low. We checked for leaks the other night and couldn't see anything. All those others are definitely possibilities but I am going to put my money on the fuel pump.
#2573 |
Member#: 277007
Vehicle:02 6spd bugsti 30r v5 heads 272 hakt ecu |
do the easy stuff first, and start taking things out of the equation. in my experiences that last thing i touched is usually the last thing i ucked up.
def don't do anymore wot pulls till you get a hold on the issues. at the very least ease into it till a problem develops. i remember mikey calling it "babysteps". have one of these tuning gurus at least look at the rom... |
#2574 | |
Member#: 7962
Vehicle:05' V35 Skyline PSM 02WRX -SOLD |
#2575 | |
Member#: 164830
SCIC
D0000d....just be careful....and make sure you log the appropriate stuff. I've been able to diagnose every single one of my mechanical issues by reading on these forums.....and I do my own work. Tuning and everything else. Nobody touches my car but me. If it were me, I would do the following in this order: 1. Clean MAF sensor 2. Change fuel filter 3. Boost leak test 4. Then log it and see what happens 5. What do IDC's look like? AFR's? Knocking? If IDC's and AFR's are good then it's probably not your injector scaling, fuel filter or fuel pump. If they don't look good then... 6. Borrow somebody elses MAF sensor 7. Log 8. Still happening? Change fuel pump 9. Log 10. Still happening? Check all exhaust bolts to make sure everything is nice and tight. 11. Still happening? Something else in the tune??? Primary open loop fueling??? Clogged up-pipe??? Jacked up turbo? Other sensor failing? TGV's not opening up??? |
| Thread Tools | |
| Display Modes | |
| Motion Lab Tuned: Juanmedina's 2007 WRX E85 ARMY | Motion Lab Tuning | Proven Power Bragging | 125 | 04-12-2010 02:57 AM |
| jid2 Track Car - e85 ARMY | jid2 | Member's Car Gallery | 38 | 01-22-2010 10:44 PM |
| The Honduran army is the bravest in the world... | wrxcelent | Off-Topic | 36 | 07-07-2009 08:21 AM |
| Spacific E85 Tuning thread Here ? | discopotato03 | Engine Management & Tuning | 1 | 09-09-2008 11:01 AM |
| Did anyone hear the one about the Italian army and the IRAQI satiation? | Asinine | Off-Topic | 3 | 09-20-2005 07:06 PM |
