Old 03-25-2011, 09:28 PM   #2601
99STM
Member#: 219160
2002 Impreza WRX
AW (6MT, E85, EWG, VF39)
How often do you have to replace that?
99STM is offline   Reply With Quote
Old 03-25-2011, 10:22 PM   #2602
MattPersman
Member#: 139385
1400s installed. Phatron has started the tuning. its too late for my wife to let me do anymore but the weekend is here so hopefully by the end of the weekend the 93 tune on these injectors will be good and e85 started
MattPersman is offline   Reply With Quote
Old 03-26-2011, 12:14 AM   #2603
maxpowr
Member#: 159243
sg3 Turbo Tek Tuned
Hakt Ecu e85 30r 6spd
rons been busy...
maxpowr is offline   Reply With Quote
Old 03-26-2011, 02:24 AM   #2604
99STM
Member#: 219160
2002 Impreza WRX
Just a small update, I threw a P0442 tonight. It had popped up when we first started tuning it but it just says "EVAP leak small". Not sure if this would have a direct relation with my problems but I'm sure one of you guys would be able to give a good answer.
Old 03-26-2011, 02:34 AM   #2605
maxpowr
Member#: 159243
sg3 Turbo Tek Tuned
replace fuel pump? that seal around the tank can be a pain if you dont replace the gasket new. those stud/bolts are only 9#s of tq btw. could be a loose/beat gas cap too.
Old 03-26-2011, 02:40 AM   #2606
99STM
Member#: 219160
2002 Impreza WRX
Yeah I was just thinking it could be that rubber gasket around the tank assembly seal or w/e. It didn't throw the code until after I did the fuel pump so it only makes sense that it has something to do with the fuel pump assembly. We had a hell of a time getting that gasket on. I will look at it when I do the Walbro and make sure that it is on there correct.
Also, NGK V Power plugs are ok with Ethanol, correct? I didn't buy Iridiums because that is a little more money than I had to spend.
Old 03-26-2011, 03:08 AM   #2607
maxpowr
Member#: 159243
sg3 Turbo Tek Tuned
i took that seal out 3 times before i decided to replace it new. i also overtightened the nut and broke a stud which to me doesn't look fixable.
Old 03-26-2011, 03:14 AM   #2608
99STM
Member#: 219160
2002 Impreza WRX
Well I want to see if it is actually in there properly before I buy a new one.
Old 03-26-2011, 03:37 AM   #2609
SVT_WRX
Member#: 164830
G61 III OVE 58e
Don't need to replace it. You can take them apart and clean them.
SVT_WRX is offline   Reply With Quote
Old 03-26-2011, 03:40 AM   #2610
Prevent
Member#: 149114
Where do you have your Golan filter at ? I was thinking inside the engine bay.
Prevent is offline   Reply With Quote
Old 03-26-2011, 03:45 AM   #2611
SVT_WRX
Member#: 164830
G61 III OVE 58e
Yes...it's in the same exact spot where the OEM filter was.
http://forums.nasioc.com/forums/show...729586&page=13
Ninth post down.
Old 03-26-2011, 04:05 AM   #2612
Prevent
Member#: 149114
Ninth post down.
Cool cool, mine has the filter in-tank, so i have to go back in there and take it out... no problem, swap out the walbro with a deatchwerks
Old 03-26-2011, 07:23 AM   #2613
karlknaupp
Member#: 60871
04 Wrx & 17 fxt
here is what my car has done so far, phatron tuned!
ej205
weisco pistons, manley rods, rem treated crank, heads ported and polished, 1mm over sized valves, gsc s2 cams. hta68, id1000s, spec c intake manifold, kstech 83 maf intake, perrin fmic core with reversed intake manifold piping, grimmspeed 38mvs tial ewg setup, invidia dp, p&l straight pipe cat back. stock 5spd, spec stg1 clutch
karlknaupp is offline   Reply With Quote
Old 03-26-2011, 09:49 AM   #2614
maxpowr
Member#: 159243
sg3 Turbo Tek Tuned
congrats karl. car feels ready to race! rons putting a clutch in the mail for me...
Old 03-26-2011, 12:19 PM   #2615
juanmedina
Member#: 133146
07 FPgreen [email protected]
WRX VF39+E85 12.0, 121mph
Wow dude that's a lot power from a HTA68 congrats , the highest whp HTA68 I have seen. How much boost and timing are your running? Probably a lot. Why aren't you reving higher? Nice dude
E85 is the ****
Ron I know you never liked the HTA68, what do you think about it now?
Old 03-26-2011, 12:50 PM   #2616
maxpowr
Member#: 159243
sg3 Turbo Tek Tuned
i think i like it, but i wanna see karl trap it.
Old 03-26-2011, 01:09 PM   #2617
TDagen
Member#: 163648
2002 Wrx,5.3L,S476r
FNF LSX Swap,E85 and more
That's a ton of power and espescially with the 2.0L!! Spools pretty fast too! E85 ftw...
TDagen is offline   Reply With Quote
Old 03-26-2011, 02:52 PM   #2618
Phatron
Member#: 36033
CEO PhatBottiTuning
2006 STi GTX3582 + Meth
E85 is the ****
boost was like 23 tapering to 21 - his ID1000's are hitting 98%
timing was 20-21 up to 25-26.....theres still more in it.....
as for the turbo....it really just depends on what powerband u want. i would rather have something in the FP Green - GT30 range make 30-50whp more on e85
Old 03-26-2011, 03:21 PM   #2619
maxpowr
Member#: 159243
sg3 Turbo Tek Tuned
gt30 power is nice...on a 2.5l. karls car feels like its set up right. nice work karl, jodie, ron, mikey.
Old 03-26-2011, 08:17 PM   #2620
MattPersman
Member#: 139385
yeah thats good power for the street!
Old 03-26-2011, 08:28 PM   #2621
99STM
Member#: 219160
2002 Impreza WRX
That is some damn good power on that turbo. I am leaning more and more towards the HTA68 for this summer.
Old 03-26-2011, 09:16 PM   #2622
RP31
Member#: 123574
2005 2.6L 9:1 425WHP
CGM STi
Looking forward to getting some numbers from my car into this thread once it's done. Previously I was running a stock engine STi with a 20G, TMIC, EWG, and 850cc injectors and making 370 WHP on E85 for 80K miles.
Then my oil pickup broke.
Now I'm slowly assembling a sleeved, pinned, 2.6L (102mm bore), 9:1 compression ratio engine with forged internals, coated pistons, +1mm valves, dual valve springs, an FMIC, larger EWG, 1200cc injectors, and some other upgrades. Same turbo for now though. Hopefully I can have it all done next month, break it in, and have E85 numbers some time in June!
RP31 is offline   Reply With Quote
Old 03-26-2011, 10:53 PM   #2623
karlknaupp
Member#: 60871
04 Wrx & 17 fxt
well guys im moving on from the id1000s as they just not enough fuel to push the turbo a lil bit more... o and i also need a clutch...
my plans are to end up with a rotated gtx30 in the distant future, so im thinking of going to 2000s now just to have them and be ready. how many different 2000s are there? i know id and five 0, does DW have 2000s?
i also think i wanna see how far i can push this stock 5spd.. i know that might sound stupid but i mean look at what ive put my trans through, i could only guess like 200-300+ passes at the track and who knows how much legal street races. i think i got a special trans from subaru lol. ive ran 12.0 @ 118 on the stock motor with it. and have cut numerous 1.6s, plenty of 1.7s and 1.8s... its got special sauce...
Old 03-26-2011, 11:05 PM   #2624
maxpowr
Member#: 159243
sg3 Turbo Tek Tuned
good driver. failures are typically user error right? oh and TQ.
Old 03-26-2011, 11:10 PM   #2625
john 1badSTI
Member#: 77470
04 sti [email protected]
on e85@ 30psi--spinning
personally speaking I like tuning the ID2000'S,have not worked with fic's or five0's but heard they were alright for the price.I just always try to buy the best for my own car and get my customers to do the same so there are no problems down the road.You know the old saying "you get what you pay for".gl with your decision and parts choice.
john 1badSTI is offline   Reply With Quote
Motion Lab Tuned: Juanmedina's 2007 WRX E85 ARMY Motion Lab Tuning Proven Power Bragging 125 04-12-2010 02:57 AM
jid2 Track Car - e85 ARMY jid2 Member's Car Gallery 38 01-22-2010 10:44 PM
The Honduran army is the bravest in the world... wrxcelent Off-Topic 36 07-07-2009 08:21 AM
Spacific E85 Tuning thread Here ? discopotato03 Engine Management & Tuning 1 09-09-2008 11:01 AM
Did anyone hear the one about the Italian army and the IRAQI satiation? Asinine Off-Topic 3 09-20-2005 07:06 PM
