Welcome to the North American Subaru Impreza Owners Club Sunday March 1, 2015
Old 08-12-2009, 12:48 AM   #251
JSarv
Member#: 163445
l33t *******
12.07@115.9mph-EJ205
sr55? 55lb? If so not very far...
800cc injectors on E and lean are good for around 325-350whp... LEAN...
1000cc injectors on E are good for 350-450whp depending on afr's...I do believe 450 would be @ or near 100 IDC @ 12-1 AFR's...
So...
Stock Light Blues - E - 225ish whp (Stock TD04 - < Stage 2 power)
550's - E - 225-250whp - (Stock TD04 Stage 2 power)
Dark blues ?? - E - 250whp ish (vf39ish area)
600cc - E - 250-275 (VF39-Small 16g)
700cc - E - 275-300 (Small 16g/vf34/vf22/big16g)
800cc - E - 300-325 (Big 16g to 18g)
1000cc - E - (Well I'm at 360ish and 89% IDC @ 11.5-1 afr) 400-450whp (18g*lots of boost - 3076 (anything between 40lb and 55lb turbo)
1200cc - E - 450-525whp (55lb turbo to 65lb turbo)
1600cc - E - 500-650whp (35r (65lb turbo) and bigger)
^^ All assuming a 11.5-1 AFR @ redline..
That help?
And the you should ALWAYS change your fuel filter 500-1000 miles after running straight E.. And one last time after another 2-5k miles. Leftover CRAP from **** gas will get flushed and caught in the fuel filter.. Why risk a lack of fuel for $10 and 20 min?
Conversion kits are junk and useless. Get a retune and bigger injectors/pump.
-jerod
And if I'm wrong on the blues/pink/dark blues - please show me your IDC vs MAF V at redline on E + those injectors...
Would be nice to have a little list setup (nicer than mine) to let people know what they need for what size of turbo...
IE Stock injectors = TD04 on less than 16lbs of boost...
JSarv is offline   Reply With Quote
Old 08-12-2009, 01:11 PM   #252
HamFist
Member#: 2112
2000 Impreza 2.5RS
BRP
dammit...
HamFist is offline   Reply With Quote
Old 08-12-2009, 03:32 PM   #253
Prevent
Member#: 149114
I'm in search for some 900cc injectors for to run E85 on a TD06H 20g, i know Deatchwerks made a pair, and you can probably get them to make you a set if you ask...
Does anyone have some logs on fuel pressure, with a single walbro and a 44lb/min turbo or larger? I'm curious if 1 Walbro is enough...
Prevent is offline   Reply With Quote
Old 08-12-2009, 04:14 PM   #254
C J
Member#: 132587
2006 JrTuned STi
Stock block 10.34@134mph
Originally Posted by Cejpat View Post
CJ ... you do come across as dick online. Work on your attitude to be more zen ...
better than coming across as an idiot I suppose.
C J is offline   Reply With Quote
Old 08-12-2009, 04:28 PM   #255
juanmedina
Member#: 133146
07 FPgreen 7.37@95
WRX VF39+E85 12.0, 121mph
Originally Posted by HamFist View Post
dammit...
what?? did it rain? you were going for 12s didn't you?
Old 08-12-2009, 04:51 PM   #256
HamFist
Member#: 2112
2000 Impreza 2.5RS
BRP
It just won't happen until later. We're strapped for cash and need to refill the bottle. Everything is sorted and happy. We know it's our driving and not the car, and practice is what's missing.
Nothing is broken!
Old 08-12-2009, 05:11 PM   #257
thefoos
Member#: 144751
02 WRX BW EFR E85
7064 TS WRB
Originally Posted by AWDWRXLOVER View Post
can someone tell me how far my 800cc injectors will get me on my sr55 2.5 hybrid?
Not far enough...I'd go for some 1100cc/min and a AFPR to boot...
thefoos is offline   Reply With Quote
Old 08-12-2009, 05:25 PM   #258
Prevent
Member#: 149114
anyone have any literature, on dual fuel pump setups ?
Old 08-12-2009, 06:22 PM   #259
elevenpoint7five
Member#: 187798
04 2 liters of
AWESOME!
how much boost are you planning to run? most say 70ish on a walbro but some claim 75psi. your FPR will rise 1:1 with boost, so static pressure(pull vac line off and read pressure) i think its like 43? someone else chime in! static + psi from turbo = pressure needed.
elevenpoint7five is offline   Reply With Quote
Old 08-12-2009, 07:00 PM   #260
Prevent
Member#: 149114
stock is 43.5psi iirc..
It's looking like 1000cc injectors with stock base pressure is needed, or some 850cc's but i'd have to raise stock, quiet a bit.. there was a guy with an 08 sti td06h 20g, with 20psi he was at 97% idc..
boost wise... 18psi on 93, 23-24 on E85..
I think rob has a great idea on how to setup a dual walbro intake setup.
Old 08-12-2009, 07:03 PM   #261
elevenpoint7five
Member#: 187798
04 2 liters of
AWESOME!
so youd be right near the limits of a walbro but that should be fine. i run 22psi with no issues
Old 08-12-2009, 07:17 PM   #262
Prevent
Member#: 149114
but you're on a vf39 , i wont be.
Old 08-12-2009, 08:07 PM   #263
elevenpoint7five
Member#: 187798
04 2 liters of
AWESOME!
im talking about pumps not injectors though. so youll be fine.
Old 08-12-2009, 08:12 PM   #264
Prevent
Member#: 149114
Im just gonna take a stab at this but..
you're feeding much smaller injectors... the injectors i would have would be flowing around 1000cc's a minute... it's goin to take more pump to keep the FP constant and up there, then it is on 740cc injectors....etc...
i think to be on the safeside im most likely going to go with a dual walbro intank setup.
Old 08-17-2009, 05:58 PM   #265
bluescoobywagon
Member#: 14911
Not A Wagon!
2011 WRX - 285s on 18x9.5
Instead of dualing Walbros, I went with the Bosche 044.
bluescoobywagon is offline   Reply With Quote
Old 08-17-2009, 06:12 PM   #266
oly kenji
Member#: 211299
2005 STi
going into 2001 gc
stock sti fuel lines able to run e85?
oly kenji is offline   Reply With Quote
Old 08-17-2009, 06:13 PM   #267
juanmedina
Member#: 133146
07 FPgreen 7.37@95
YES...
Old 08-17-2009, 06:31 PM   #268
SinfulSTI
Member#: 156068
04 Another wrb STI
What kind of MPG are you guys getting with e85? And tell what your driving style is when answering this and how heavily modified the car is. Looking to get tuned on e85, except i will be daily driving the car.
SinfulSTI is offline   Reply With Quote
Old 08-17-2009, 06:31 PM   #269
UFOpilot
Member#: 189525
2007 WRX Wagon
Invisible Plain
Here's my setup, and the results:
Evo III 16G
Turbo XS TMIC
Grimmspeed up-pipe
Tial 44 mm EWG (atmosphere dump)
Cobb TBE
DW 1000 cc injectors
Walbro 255 fuel pump
Grimmspeed 3 port solenoid
JDM TGV deletes
AVO turbo inlet
1 step colder plugs
Thermal wrap on up-pipe, downpipe.
Tune by Tim Bailey @ www.surgelinetuning.com
e-85 @ 20 psi netted 341 whp and 366 torque.
Smoot delivery, steady pull to redline (and rev limiter ).
I have other maps, and I run the 19 psi e-85 as my daily, since I have a station that gets 85% year round 5 minutes from my house. I got 12 MPG on my first session, which is just over my expectation. I got 18 MPG mixed driving to the coast which is all highway, but some parts are curvy so I did go over wastegate many, many times.
I am really liking the extra 20-30 hp and torque the fuel is netting me. The tune is about as much as I want to put on my stock drivetrain though. I am expecting to need to do the swap before too long.
I have a couple of the Dynamometer charts up on my profile.
Travis
UFOpilot is offline   Reply With Quote
Old 08-17-2009, 06:53 PM   #270
charlesdixon
Member#: 161345
2005 AW STi
Stage Poo
Can I join?
06 WRX Wagon
stock injectors
80% IDC
Stock turbo
Perrin Inlet
TXs FMIC
Short Ram
233/ 290t
Oh and 4eat tranny.
21Mpg normal driving, down to about 16-18mpg spirited driving and 12mpg stupid driving.
Coming soon: 18g-8cm, 850cc, modded valve body and torque converter. Thinking i should be getting close to 11s?? Maybe? I dunno.
charlesdixon is offline   Reply With Quote
Old 08-18-2009, 06:20 AM   #271
gaby
Member#: 94097
2004 WRX Hybrid GT35
11.2@130.7
What type of timing are you guys running. I'm already 6 degres over 91oct tune but 3psi less.
Mod blue stock inj. Flow tested to 845cc @ 45psi
18g/7cm
205 with wrx heads
Headers full exhaust
11.1-11.8afrs
16.9psi @ 98idc
12dgr peak boost
18-23dgr from 4k-7300rpms
Havent dyno yet.
gaby is offline   Reply With Quote
Old 08-18-2009, 11:04 PM   #272
elevenpoint7five
Member#: 187798
04 2 liters of
AWESOME!
not with a stock FPR. its a 1:1 FPR, you wont get more pressure unless youre running an after market FPR or you crush the stocker to increase your static pressure.
i hear those are nice. you have one?
about 20MPG driving nice, about 18 when im on it quite a bit. needless to say, i rarely see 20
Old 08-19-2009, 05:18 AM   #273
SinfulSTI
Member#: 156068
04 Another wrb STI
Thank you for answering everyone and Nice. i am looking forward to getting tuned on E85 with either a HTA green or 68HTA. Not sure if i want to go big or small lol. I just make it over 22mpg with mainly highway on 93. I have a 04 sti thats a little past stage 2 but not a up'd turbo. Now i have another question, my friend told me E85 builds up a lot of carbon in the engine. That true? and if so are there any other negative side effects?
Old 08-19-2009, 07:25 AM   #274
elevenpoint7five
Member#: 187798
04 2 liters of
AWESOME!
No e85 is a very clean burning fuel. You should go read the e85 fuel FAQ in the engine management and tuning section. The only negative side effects I can think of are the gas mileage and the fact that taking long trips requires more planning or the ability to switch back to 93 or something.
Old 08-19-2009, 12:39 PM   #275
UFOpilot
Member#: 189525
2007 WRX Wagon
Invisible Plain
$2.00 per gallon negates the mileage issue for me, it works out to be nearly the same cost as better mileage at $3.05 per gallon for premium.
Motion Lab Tuned: Juanmedina's 2007 WRX E85 ARMY Motion Lab Tuning Proven Power Bragging 125 04-12-2010 03:57 AM
jid2 Track Car - e85 ARMY jid2 Member's Car Gallery 38 01-22-2010 11:44 PM
The Honduran army is the bravest in the world... wrxcelent Off-Topic 36 07-07-2009 09:21 AM
Spacific E85 Tuning thread Here ? discopotato03 Engine Management & Tuning 1 09-09-2008 12:01 PM
Did anyone hear the one about the Italian army and the IRAQI satiation? Asinine Off-Topic 3 09-20-2005 08:06 PM
