Old 07-20-2011, 12:29 PM   #4001
juanmedina
Member#: 133146
07 FPgreen [email protected]
WRX VF39+E85 12.0, 121mph
Originally Posted by Phatron View Post
** still waiting on $4k evo **
I talk to the guy yesterday...
I text you the number in a few, I charge 1K or a gtx3076 for the reference in case of a deal.... kidding .
Old 07-20-2011, 12:43 PM   #4002
Phatron
Member#: 36033
CEO PhatBottiTuning
2006 STi GTX3582 + Meth
i'll let you drive it out here
Old 07-20-2011, 12:49 PM   #4003
juanmedina
Member#: 133146
Old 07-20-2011, 12:59 PM   #4004
Phatron
Member#: 36033
CEO PhatBottiTuning
i'll pay for gas. i bet jake will do it.
Old 07-20-2011, 01:07 PM   #4005
juanmedina
Member#: 133146
Jake is crazy.... I work and even if I can the take the time off. What would I do if I get pull over with a car with no registration/tags ?
Old 07-20-2011, 01:33 PM   #4006
Phatron
Member#: 36033
CEO PhatBottiTuning
u dont pull over....u just gun it and head for mexico
Old 07-20-2011, 02:31 PM   #4007
TickTack
Member#: 100353
You guys typically just let your tank drain at home, fill it with e85 and get a AAA tow or something to the tuner? I don't have a laptop or tactrix cable handy for a base tune.
TickTack is offline   Reply With Quote
Old 07-20-2011, 02:58 PM   #4008
skatin707
Member#: 251552
Chapter/Region: HIIC
2014 FXT
Satin White Pearl
Plan your trip carefully. Try to get to your tuner as close to empty as possible.
Bring a few 5 gallon containers. 1 with 91/93oct in it and 2 with E85. The pump gas is just in case you run out. The E85 is so have no reason to leave the shop once you get there.
Also, your car can run with a little bit of E85 in it, around 20% or more.
skatin707 is offline   Reply With Quote
Old 07-20-2011, 03:10 PM   #4009
TickTack
Member#: 100353
But I don't think it'll run well enough on new pump/injectors to make it there on pump gas. It's a 30min drive. Seems like I should just burn a AAA tow on this one.
Old 07-20-2011, 03:18 PM   #4010
drewvdw
Member#: 255776
2010 LR WRX
MPS powered.
see if your tuner can do a limp tune for you?
drewvdw is offline   Reply With Quote
Old 07-20-2011, 03:22 PM   #4011
TickTack
Member#: 100353
I'll just give him a call tomorrow and see what he prefers me to do and do what he says.
Old 07-20-2011, 03:29 PM   #4012
skatin707
Member#: 251552
2014 FXT
Satin White Pearl
This is the obvious option, that wont help him though.
Old 07-20-2011, 03:30 PM   #4013
TickTack
Member#: 100353
I can come up with something, thanks guys. Looking forward to some extra power.
Old 07-20-2011, 03:41 PM   #4014
Phatron
Member#: 36033
CEO PhatBottiTuning
just purchase the tactrix cable and a wideband. its the best $350 any subaru owner can ever spend.
People are gonna say....well if i get tuned on the dyno i dont need a wideband....and once the tune is done i wont need the tactrix.....wrong and wrong.
The wideband is a constant leak monitor. And the tactrix can be used to monitor AF learnings, check CEL's, knock learning table, logging.
Old 07-20-2011, 03:47 PM   #4015
TickTack
Member#: 100353
Good, I just needed somebody to tell me that. Don't know why I'm cutting corners to save a few hundred bucks at this point, haha. Done and done.
Old 07-20-2011, 03:53 PM   #4016
Phatron
Member#: 36033
CEO PhatBottiTuning
u can only get the tactrix from tactrix.com.....and AEM Uego's are $165 on ebay......if you get the digital 30-4100 Uego you can log it with the busted finger motorsports cable.
Old 07-20-2011, 04:29 PM   #4017
TickTack
Member#: 100353
This looks like a pretty basic but well-functioning kit. Any thoughts?
http://www.innovatemotorsports.com/products/db.php
Old 07-20-2011, 04:33 PM   #4018
Phatron
Member#: 36033
CEO PhatBottiTuning
aem uegos are better. the lc-1's take 10x longer to install and they have lots of problems and a high failure rate. they need constant recalibrations....you have to remove the 02 sensor from the exhaust and ground a wire to make it perform a free air calibration.
the Uegos dont require any calibration, ever.
if you're stuck on innovate, try out this one....its basically innovate's copy of the uego
http://www.innovatemotorsports.com/products/MTXL.php
Old 07-20-2011, 04:53 PM   #4019
skatin707
Member#: 251552
2014 FXT
Satin White Pearl
If you get a working cable that is...
Old 07-20-2011, 05:00 PM   #4020
Phatron
Member#: 36033
CEO PhatBottiTuning
if you're having trouble logging with the BFM cable its probably a driver issue or something else....its highly unlikey that the BFM cable is bad....its a pretty simple device. pretty much the only things that would cause it to not work are cut wires, loose connections, missing pins on the serial interface, f'd up usb connector...you should be able to verify all those with a visual inspection
are you sure you have the digital uego? if you have the analog one the bfm cable wont work.
the digital one has a blue wire for logging....the analog doesnt have a blue wire....it has a white one in its place
Old 07-20-2011, 05:16 PM   #4021
maxpowr
Member#: 159243
sg3 Turbo Tek Tuned
Hakt Ecu e85 30r 6spd
Ill drive that evolution back to Jersey. Again, what's the hold up?
If ron don't want it, I do.
maxpowr is offline   Reply With Quote
Old 07-20-2011, 06:37 PM   #4022
skatin707
Member#: 251552
2014 FXT
Satin White Pearl
Yeah mine is digital. They replaced my first one. Getting the second one to work is pretty complicated too. I've followed their directions but it wouldn't work for me.
Old 07-20-2011, 06:58 PM   #4023
Phatron
Member#: 36033
CEO PhatBottiTuning
solder uego to serial
serial plugs to serial
usb plugs to laptop
select com port in romraider under secondary devices (make sure you're not selecting the same com port as the tactrix)
select AEM Uego
maybe you're soldering the wrong wires or selecting the wrong com port?
Old 07-20-2011, 07:19 PM   #4024
skatin707
Member#: 251552
2014 FXT
Satin White Pearl
usb plugs to laptop
select AEM Uego
Nope, I've got all that right.
Old 07-20-2011, 07:46 PM   #4025
02RexWI
Member#: 165141
Did u try communication through hyper terminal?
02RexWI is offline   Reply With Quote
Motion Lab Tuned: Juanmedina's 2007 WRX E85 ARMY Motion Lab Tuning Proven Power Bragging 125 04-12-2010 02:57 AM
jid2 Track Car - e85 ARMY jid2 Member's Car Gallery 38 01-22-2010 10:44 PM
The Honduran army is the bravest in the world... wrxcelent Off-Topic 36 07-07-2009 08:21 AM
Spacific E85 Tuning thread Here ? discopotato03 Engine Management & Tuning 1 09-09-2008 11:01 AM
Did anyone hear the one about the Italian army and the IRAQI satiation? Asinine Off-Topic 3 09-20-2005 07:06 PM
