Old 08-02-2011, 01:04 PM   #4151
07pearlwht
Member#: 212576
2007 impreza wrx sti
pearl white
373whp 410wtq /07pearlwht /07 STI/ EJ257 + 20gxt-r 8cm/1000cc 82%idc /4660ft.
07pearlwht is offline   Reply With Quote
Old 08-03-2011, 06:46 AM   #4152
MattPersman
Member#: 139385
Originally Posted by maxpowr View Post
rons the man.
+1 thanks for continued support
MattPersman is offline   Reply With Quote
Old 08-03-2011, 02:05 PM   #4153
Gfunk720
Member#: 42549
E92 M3 M\\\
VW Sportvagon Oilburner
This has probably been covered, but I can't read back through every page. That gauge that Visconti has is sick, but may be a little overkill for me.
Can anyone recommend a decent Ethanol testing kit? Looking for something accurate that wont break the bank.
Gfunk720 is offline   Reply With Quote
Old 08-03-2011, 02:10 PM   #4154
WhyHelloOfficer
Member#: 193989
2004 Matte White GTO
Australian Racecar
A graduated cylinder that you can seal is all you need.
http://continuouswave.com/whaler/ref...hanolTest.html
WhyHelloOfficer is offline   Reply With Quote
Old 08-03-2011, 03:26 PM   #4155
STiProsDoc
Member#: 158495
2007 STi OBP
Phatbotti tuned on E85
This is what I use
http://www.summitracing.com/parts/QFT-36-E85/
STiProsDoc is offline   Reply With Quote
Old 08-03-2011, 08:32 PM   #4156
RicersWetDream
Member#: 245581
2009 WRX
2014 Forester XT
^Same here. Last batch was E88.
RicersWetDream is offline   Reply With Quote
Old 08-03-2011, 10:33 PM   #4157
Gfunk720
Member#: 42549
E92 M3 M\\\
Thanks for the links. Very helpful.
Put my Aeromotive 340 in tonight, and it looks like they fixed the polarity issues on the pump. I confirmed it against my Walbro after I took it out, same as the stock harness. Install was pretty simple.
Should be pumping E85 in no time
Old 08-04-2011, 05:35 PM   #4158
TickTack
Member#: 100353
Any harm in clicking my key to 'on' after my injector/pump/tgv/intake manifold install to make sure everything is hooked back up correctly before I get the car towed to tuning tomorrow? I figure this would be a safe way to check for leaks and that the pump is operating correctly.
TickTack is offline   Reply With Quote
Old 08-04-2011, 06:51 PM   #4159
amalgrover
Member#: 183480
2011 Audi A3 Quattro
2009 Forester XT
i highly recommend checking for leaks...i usually check for fuel leaks by unplugging the coilpacks and then turning the motor over for a few seconds. that little bit of fuel in there isn't going to hurt anything. there have been reports of AERO340 pumps not working properly (like mine where it was turning on properly but the gear inside wasn't actually pumping any fuel into the lines). doing this would save you the FAIL moment of getting all the way to the tuner and finding your fuel pump bad, injectors not seated, etc.. Ops checks are always a good idea when possible with any install.
fyi...if you are ever wanting to check for oil leaks or prime an engine, turbo, etc. you would disconnect your fuel pump relay (the green connector on the passenger side) and then turn the motor over for about 10 seconds. i usually do this 2x when priming a new engine or turbo. just allows the oil to fully circulate through the system and build up a small amount of pressure.
amalgrover is offline   Reply With Quote
Old 08-04-2011, 08:38 PM   #4160
smeerone
Member#: 249068
2010 WRX
DGM Phatbotti Tuned
Guys is there a tell tale sign a fuel filter is clogged/dirty?
smeerone is offline   Reply With Quote
Old 08-04-2011, 08:39 PM   #4161
smeerone
Member#: 249068
2010 WRX
DGM Phatbotti Tuned
Car wont turn over unless it's cranked a lot. Recently swapped the walbro in.
Old 08-04-2011, 09:46 PM   #4162
RicersWetDream
Member#: 245581
2009 WRX
2014 Forester XT
Did you double o-ring the new pump? Does it take a while to crank after sitting for a while, but fires right up if you turn it off and crank it right away?
If you have a bad seal at the fuel pump ---> fuel pump housing it'll bleed pressure off and have to re-prime after sitting for a while, hence the long cranking process.
Old 08-04-2011, 09:59 PM   #4163
smeerone
Member#: 249068
2010 WRX
DGM Phatbotti Tuned
Thanks, don't think mine is double o ringed. I'm going to inspect.
Old 08-04-2011, 10:03 PM   #4164
maxpowr
Member#: 159243
sg3 Turbo Tek Tuned
Hakt Ecu e85 30r 6spd
if you get a po420(?code?)it may be the seal that the gas tank cover has. i used mine over and it leaked pressure. same code as loose fuel cap.
i also broke one of the studs on the gas tank...i think its only 9#s of tq.
maxpowr is offline   Reply With Quote
Old 08-04-2011, 10:15 PM   #4165
wrxsubiemod
Member#: 165104
E85 SoCalPorting
Owner
I think its less^ one snapped on me as well. Damn bolts
wrxsubiemod is offline   Reply With Quote
Old 08-04-2011, 10:23 PM   #4166
maxpowr
Member#: 159243
sg3 Turbo Tek Tuned
i used a new seal and it held for 5 years now...minus two studs. i dont see how the studs can be replaced without dropping the tank and possibly replacing the whole tank...
those studs are stupid undersized.
Old 08-04-2011, 11:25 PM   #4167
02RexWI
Member#: 165141
Word.
02RexWI is offline   Reply With Quote
Old 08-04-2011, 11:38 PM   #4168
maxpowr
Member#: 159243
sg3 Turbo Tek Tuned
fortunately they are welded so the other side didn't fall into the tank...but i dont see how it can be repaired...
i'll probally have to consider replacing the tank when i have to pull the 70k'd walbro.
Old 08-05-2011, 12:14 AM   #4169
amalgrover
Member#: 183480
2009 Forester XT
could just lay some catch cloth inside the tank, drill it out, and then use a nut and bolt with an o-ring or just jbweld it closed. the nut and bolt with jbweld would hold and seal just as good as it did before, and that way you don't have to drop the whole tank and weld with gas fumes.
Old 08-05-2011, 07:53 AM   #4170
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
Here's a thread I made on the issue:
http://forums.nasioc.com/forums/show....php?t=2130397
Taking longer to turn over after a Walbro install is NOT normal (even though plenty of people will swear that it is). The car should start up exactly like OEM. You need to make sure everything that needed to be trimmed, has been trimmed. You also need to make sure to use the double o-ring trick or something else similar to get it to seal. Also verify that all the other connections on that housing are on tight.
I had the slow startup issue pop back up a few months after that thread and it ended up being one of the hoses on the housing that had come very slightly loose. By this time I had my wideband gauge hooked up and saw that it would run crazy lean up top (ran fine while cruising). Definitely not a safe condition for the motor.
xluben is offline   Reply With Quote
Old 08-05-2011, 07:59 AM   #4171
smeerone
Member#: 249068
2010 WRX
DGM Phatbotti Tuned
^^ thank you, this is really helpful.
Old 08-05-2011, 12:28 PM   #4172
MattPersman
Member#: 139385
P0420 is a catalytic efficiency code not and evap leak code
Old 08-05-2011, 12:46 PM   #4173
benit0
Member#: 202204
02 WRX
2002 WRX Wagon
317whp / 293wtq - virtual dyno
Stock long block ej20 @ 200k
800cc PE Top Feeds
VF22
85% IDC
800ft
I tuned it my self, theirs a lot more room in it i'm positive. hopefully getting a protune soon here.
benit0 is offline   Reply With Quote
Old 08-05-2011, 12:54 PM   #4174
amalgrover
Member#: 183480
2009 Forester XT
wow...200,000 miles ...i'm impressed...even more impressed if it lasts with the e85 in there cleaning all that carbon and junk away from the seal and stuff
Old 08-05-2011, 01:16 PM   #4175
benit0
Member#: 202204
02 WRX
I bought it at 164k. 100% bone stock, no rust clean as a whistle.
Around 170k was when i went "stage 2" and about 180k is when i went vf22/injectors/tgv delete/e85 and some other random stuff.
Been driving it the last 20k with no issues.
Oh, its at exactly 196k right now. I've only had it for 1 year 3 months.
Motion Lab Tuned: Juanmedina's 2007 WRX E85 ARMY Motion Lab Tuning Proven Power Bragging 125 04-12-2010 02:57 AM
jid2 Track Car - e85 ARMY jid2 Member's Car Gallery 38 01-22-2010 10:44 PM
The Honduran army is the bravest in the world... wrxcelent Off-Topic 36 07-07-2009 08:21 AM
Spacific E85 Tuning thread Here ? discopotato03 Engine Management & Tuning 1 09-09-2008 11:01 AM
Did anyone hear the one about the Italian army and the IRAQI satiation? Asinine Off-Topic 3 09-20-2005 07:06 PM
