Old 08-12-2011, 03:10 AM   #4201
skatin707
Member#: 251552
Chapter/Region: HIIC
2014 FXT
Satin White Pearl
I'll use whatever you guys recommend.
On my parts list is a banjo bolt for the turbo and the bolts for the fuel rails. I'm really hoping that's all I need.
skatin707 is offline   Reply With Quote
Old 08-12-2011, 11:57 AM   #4202
amalgrover
Member#: 183480
2011 Audi A3 Quattro
2009 Forester XT
honestly, any water remover will do just fine. there is a possibility that the ethanol actually acts as a water remover since the water will bond to the ethanol and then the ethanol will bond to the gasoline...BUT...i would stick a water remover in there just to be safe. most any water remover from the autoparts store or walmart will do just fine.
amalgrover is offline   Reply With Quote
Old 08-12-2011, 01:45 PM   #4203
john 1badSTI
Member#: 77470
04 sti [email protected]
on e85@ 30psi--spinning
lucas oil makes a good product specifically for e85 called safeguard.
john 1badSTI is offline   Reply With Quote
Old 08-12-2011, 01:48 PM   #4204
Phatron
Member#: 36033
CEO PhatBottiTuning
2006 STi GTX3582 + Meth
What happens if u pour water remover in a glass of water?
Old 08-12-2011, 01:52 PM   #4205
skatin707
Member#: 251552
2014 FXT
Satin White Pearl
You just figured out how to be a magician.
Old 08-12-2011, 02:26 PM   #4206
smeerone
Member#: 249068
2010 WRX
DGM Phatbotti Tuned
This^^^
smeerone is offline   Reply With Quote
Old 08-13-2011, 11:08 PM   #4207
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
OK, so I finally got around to logging the 50-100mph pulls that I had talked about a while back. I decided this was the best range to use. Seems the most fair to all of the transmissions. I did it from a 30mph roll so my turbo was spooled up when I hit 50mph. Some might not agree with this, but I think it's the most consistent way. Basically just get from 50-100mph as fast as possible: use whatever gears you'd like, brake boost, start slower and go WOT through 50mph, etc. Just keep it to a flat surface and you're good.
I'll start with my numbers, and some that I pulled with my brother's 2011 MS3 that is Stage 2. If I can get a few more people from this thread to post up their results, then I'll create a separate thread in PPB to try to get a full NASIOC list going. I tried to make a format for the entries. Let me know if I missed anything relevant. It would also be good to post a log or a plot.
Here's mine:
Vehicle: 2011 WRX
Motor: Stock
Turbo: Stock
Transmission: Stock 5 Speed
Redline: Stock
Upgrades: Stage 2 + E85 Tune
Weight: Full Stock Weight + Driver and Passenger
50-100MPH: 7.52sec
Vehicle: 2011 MS3
Motor: Stock
Turbo: Stock
Transmission: Stock 6 Speed
Redline: Stock
Upgrades: Stage 2
50-100MPH: 9.22sec
xluben is offline   Reply With Quote
Old 08-14-2011, 12:06 AM   #4208
maxpowr
Member#: 159243
sg3 Turbo Tek Tuned
Hakt Ecu e85 30r 6spd
maxpowr is offline   Reply With Quote
Old 08-15-2011, 11:00 AM   #4209
Maxwell Power
Member#: 190729
Originally Posted by maxpowr View Post
i like where this is going.^^^
just for fun...
David Wolfe Drag Radial Twin Turbo Mustang 6.57sec!!! - YouTube
that thing is moving. It's very drama free with an auto trans though.
Maxwell Power is offline   Reply With Quote
Old 08-15-2011, 11:11 AM   #4210
juanmedina
Member#: 133146
07 FPgreen [email protected]
WRX VF39+E85 12.0, 121mph
Originally Posted by xluben View Post
Vehicle: 2011 WRX
Motor: Stock
Turbo: Stock
Redline: Stock
50-100MPH: 7.52sec
Vehicle: 2011 MS3
Motor: Stock
Turbo: Stock
Redline: Stock
Upgrades: Stage 2
50-100MPH: 9.22sec
Airboy calculates these times automatically from a log. I think it would be easier to use them. There is no shifting involve.
50-80mph, sec 2.34
60-80mph, sec 1.46
3-6k rpm, sec 3.63
Old 08-15-2011, 11:15 AM   #4211
Maxwell Power
Member#: 190729
if I leave it in 3rd, I don't have to shift... and it still takes about 4 seconds.
Old 08-15-2011, 11:18 AM   #4212
juanmedina
Member#: 133146
you and your 2.3L .....
I can get about 97mph in 3rd with my 7.5K redline
Old 08-15-2011, 11:21 AM   #4213
Maxwell Power
Member#: 190729
lol. Mine is technically a 2.5 (102.3mm x 75mm)
Old 08-15-2011, 11:37 AM   #4214
karlknaupp
Member#: 60871
2004 WRB WRX
i think im gonna go with a long rod motor too!
karlknaupp is offline   Reply With Quote
Old 08-15-2011, 11:42 AM   #4215
maxpowr
Member#: 159243
sg3 Turbo Tek Tuned
im liking the idea as well.
stroke a 2.0 block with sti crank rods and proper pistons...
destroke a bored out 2.5 with sti crank and sti rods with proper pistons...
i hear there is a level of difficulty with assembling a stroker motor...dom has mastered it?
something about access to the piston to install the rod/piston pin, c clips.
Old 08-15-2011, 11:53 AM   #4216
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
Interesting. I didn't know the spreadsheets did that. I initially wanted to pick a range that would all be included in a log, but that's just such a small range, and the fact that a single gear and small portion of the powerband will greatly favor some setups over other setups.
For example, if you have a 5 speed and your turbo doesn't spool until 5k, then a 50-80mph in 3rd gear will probably be out of the powerband the whole time. I thought that a wider range, like 50-100mph, and the use of any gears you'd like, would be more of an even playing field.
I'd really be interested in seeing what other cars can do the 50-100mph in (and to compare that to power). Idk, just a thought. If we could get some more people to post logs, then I'd move this out to the main PPB section to try to get a bigger list going, but right now it doesn't seem like enough interest in making the logs.
Old 08-15-2011, 12:56 PM   #4217
skatin707
Member#: 251552
2014 FXT
Satin White Pearl
This is what I'm planning.
Old 08-15-2011, 01:30 PM   #4218
02RexWI
Member#: 165141
You can't line up the rods with the hole in the block to put the wrist pins in, so you have to leave the case halves split while you install the pistons, wrist pins and clips. Then after you have the pistons locked in you can bolt the case halves together.
I think the hardest part would be applying sealant to the case, and making sure the crank bearings dont fall out.
I'll be building one if my 2.5 I just built decides to go tits up early.
02RexWI is offline   Reply With Quote
Old 08-15-2011, 03:24 PM   #4219
Maxwell Power
Member#: 190729
by STi crank and pistons I assume you mean EJ207 for the destroker.
pretty close to that. We do a few other things to speed up the process and do some assembly out of the normal order of things.
Old 08-15-2011, 05:07 PM   #4220
smeerone
Member#: 249068
2010 WRX
DGM Phatbotti Tuned
What's up fellas? I have a question. I swapped out the fuel pump on my 2010 Rex and tore one of the o rings in the fp housing. Besides dealer any suggestions on where to get one? Gracias. Obviously fuel grade.
Old 08-15-2011, 05:10 PM   #4221
RicersWetDream
Member#: 245581
2009 WRX
2014 Forester XT
I believe all the o-rings that are inside the housing, aka the few lines that plug in around the housing as well as the o-ring around the actual pump output itself, are all the same size.
Part #2-12093 at napa
RicersWetDream is offline   Reply With Quote
Old 08-15-2011, 05:17 PM   #4222
smeerone
Member#: 249068
2010 WRX
DGM Phatbotti Tuned
I thought so too, however visibly slightly larger. Also 2 different part numbers via SOA. I appreciate your help anyway.
Old 08-15-2011, 06:29 PM   #4223
5lipstream
Member#: 124663
2003 AW WRX
2008 GG Evo X MR
Originally Posted by amalgrover
you should shoot for higher than 9:1 compression. i had mine at 9.3:1 on my first build. i liked it alot better than stock, and on my current motor i am running 9.77:1. i LOVE the higher compression for daily driving.
Qft. I've ridden in 2 different 10:1 e85 evos plus my roommates 9:1 evo and the difference is amazing. I'm building a new high comp, sleeved e85 motor this winter and going with 100mm ~10:1 pistons. I haven't made up my mind on the stroke though. I'm going back and forth between destroked 2.3 or stock stroke 2.5 with a Precision 6265. The gt4094r is just too laggy for my taste.
5lipstream is offline   Reply With Quote
Old 08-16-2011, 04:10 PM   #4224
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
No one else wants to log a 50-100mph run?
Old 08-16-2011, 04:14 PM   #4225
RicersWetDream
Member#: 245581
2009 WRX
2014 Forester XT
I'll probably do one on thursday when I finish the E85 tune. I need to get a tactrix cable of my own. Question on that, am I allowed to start lower than 50 so I can be full boost by 50mph, or is it a rule that I need to be at 50 then floor it?
Motion Lab Tuned: Juanmedina's 2007 WRX E85 ARMY Motion Lab Tuning Proven Power Bragging 125 04-12-2010 02:57 AM
jid2 Track Car - e85 ARMY jid2 Member's Car Gallery 38 01-22-2010 10:44 PM
The Honduran army is the bravest in the world... wrxcelent Off-Topic 36 07-07-2009 08:21 AM
Spacific E85 Tuning thread Here ? discopotato03 Engine Management & Tuning 1 09-09-2008 11:01 AM
Did anyone hear the one about the Italian army and the IRAQI satiation? Asinine Off-Topic 3 09-20-2005 07:06 PM
