Old 09-17-2011, 12:21 AM   #4451
maxpowr
Member#: 159243
sg3 Turbo Tek Tuned
Hakt Ecu e85 30r 6spd
sounds good to me. i'll donate...i know ron gives away good engines.
maxpowr is offline   Reply With Quote
Old 09-17-2011, 01:35 AM   #4452
jnorth85
Member#: 76785
2000 580Whp The RSTI
SRP
If anyone is looking im selling an id2000 side feed to top feed conversion kit. Perfect for E85
jnorth85 is offline   Reply With Quote
Old 09-20-2011, 10:22 AM   #4453
5lipstream
Member#: 124663
2003 AW WRX
2008 GG Evo X MR
Would I need this if I'm already top feed?
5lipstream is offline   Reply With Quote
Old 09-20-2011, 10:53 AM   #4454
02RexWI
Member#: 165141
^No, you just need the injectors. I'm thinking about selling mine if you're interested in them.
02RexWI is offline   Reply With Quote
Old 09-20-2011, 11:43 AM   #4455
jnorth85
Member#: 76785
SRP
Correct, however the conversion injectors have machined adapters so they work with the top feed rails
Old 09-20-2011, 12:31 PM   #4456
5lipstream
Member#: 124663
2003 AW WRX
2008 GG Evo X MR
Pm me the price
Old 09-22-2011, 10:09 AM   #4457
wgr73
Member#: 232458
2005 & 2008 STi
Cobb 20g & EFR 7670
Originally Posted by 5lipstream View Post
Pm me the price
PM me too if 5lipstream doesnt bite
wgr73 is offline   Reply With Quote
Old 09-22-2011, 11:03 AM   #4458
skatin707
Member#: 251552
Chapter/Region: HIIC
2014 FXT
Satin White Pearl
I miss this thread
I bought a coilpack on here and it still hasn't come in the mail. He shipped late and with a slow method (if he shipped at all, I have no tracking number to check).
So now I'm looking for another coilpack...i miss my car!
skatin707 is offline   Reply With Quote
Old 09-22-2011, 12:26 PM   #4459
maxpowr
Member#: 159243
sg3 Turbo Tek Tuned
if you have id2000 top feed injectors for sale, pm me a price as well.
i heard if you arent running AN lines with e85, the fuel corrodes the rubber which in turn gets into stuff you dont want it to. not to mention eventually it will spout a leak.
confirm? deny?
e85 safe fuel line is?
i also heard walbro 255s are not qualified to run e85 and will fail eventually.
rumor or truth?
Old 09-22-2011, 12:37 PM   #4460
amalgrover
Member#: 183480
2011 Audi A3 Quattro
2009 Forester XT
this is not really true with newer vehicles...vehicles manufactured after ethanol started being put into pump gas had to have ethanol compatible fuel systems
confirm? deny?
walbro 255's are NOT supposed to be used with e85 if you ask walbro themselves or a walbro dealer, however, most of the ones being used with e85 are running without issue. they do have an ethanol compatible pump, but the aero340 and the dw300 are cheaper, flow more, and E100 compatible. the normal walbro 255's are so cheap and issues are so far and few between that i wouldn't worry about it too much
rumor or truth?
...ethanol isn't really corrosive like methanol is...as long as you keep moisture out of it...
amalgrover is offline   Reply With Quote
Old 09-22-2011, 02:52 PM   #4461
maxpowr
Member#: 159243
sg3 Turbo Tek Tuned
big up amal...
im not gonna run e85 till i get 2000cc's anyway. before i go e85 i will have a fuel system designed for it.
pump power is good enough for me anyway. i like the knock tolerance and extra power of e85 but it does complicate things...less MPG, unreliable blend...testing every fill up, or investing in a subaru based laboratory to make sure its working correctly. its just not as ez as 93...
Old 09-22-2011, 03:06 PM   #4462
Phatron
Member#: 36033
CEO PhatBottiTuning
2006 STi GTX3582 + Meth
"this is not really true with newer vehicles...vehicles manufactured after ethanol started being put into pump gas had to have ethanol compatible fuel systems"
thats almost exactly what i said. some pump gas is e20....so OEM vehicles should already be somewhat ethanol compatible.
it may not be 10 year compatible, but its also not gonna eat through your hose in 10 minutes.
Old 09-22-2011, 03:13 PM   #4463
02RexWI
Member#: 165141
Hotrod has been running it in his WRX for many years now with no signs of corroded lines.
Check out the E85 FAQ thread if you're curious.
The Carberry ROM will soon have full flex fuel compatibility if you're worried about the blending issues.
Old 09-22-2011, 03:13 PM   #4464
maxpowr
Member#: 159243
sg3 Turbo Tek Tuned
if there is 100% e85 compatible equiptment that is what i will opt to buy.
somebody post up links to the most optimal yet cost effective e85 fuel system.
unless of course everything i hear is not always true...
Old 09-22-2011, 03:14 PM   #4465
Maxwell Power
Member#: 190729
you CANNOT run the top feed conversion injectors with regular rails on regular tgv housings. The injector is modified to work with the side feed TGV housing.
If you modify the injector, you might be able to.
recap:
The conversion injectors are made ONLY for the conversion rails and side feed TGVs.
Maxwell Power is offline   Reply With Quote
Old 09-22-2011, 03:15 PM   #4466
Maxwell Power
Member#: 190729
In regards to Walbro pumps:
Walbro says " There are parts in the fuel pump that may corrode over time..."
I have dual walbros in my RS running e85 with no issue yet. Many people run them for quite some time before they go out.
Old 09-22-2011, 03:23 PM   #4467
maxpowr
Member#: 159243
sg3 Turbo Tek Tuned
how many miles with 43#s of fuel pressure on 93 pump can we estimate a single walbro should last?
i am asking for an opinionated estimate. i have like 60k on mine.
Old 09-22-2011, 06:26 PM   #4468
skatin707
Member#: 251552
2014 FXT
Satin White Pearl
I'm curious is switching from 91 to E85 and back to 91 may have hindered my fuel pump. I'm having REALLY bad misfires in 1,2, and 3. So far I've done plugs, fuel filter, cleaned battery terminals, and cleaned cam sensor. Any other ideas? I'm thinking my #4 coilpack is toast.
Old 09-22-2011, 06:28 PM   #4469
02RexWI
Member#: 165141
^I have a coilpack laying around... and I WILL ship it
Old 09-22-2011, 06:30 PM   #4470
skatin707
Member#: 251552
2014 FXT
Satin White Pearl
I can't afford another one right now. Wife's car is totalled, I'm racking up hotel fees, and then getting ripped off...money is tight
Thanks though
Old 09-22-2011, 08:15 PM   #4471
maxpowr
Member#: 159243
sg3 Turbo Tek Tuned
move the coilpacks around and see what happens. i find it hard to believe more than 2 coil packs at a time are bad.
what was the last thing you did to the car before the problem?
Old 09-22-2011, 09:47 PM   #4472
skatin707
Member#: 251552
2014 FXT
Satin White Pearl
I was going to move 4 to the other side and see if the problem rotated.
I put gas in it...that's it.
Old 09-26-2011, 12:33 AM   #4473
TickTack
Member#: 100353
Probably heading to the track on Saturday with this. I haven't been on a drag strip since I ran a 15.8s in my stock Jetta years ago. Any tips/tricks besides the obvious? Tire choices are 255/40/17 Hankooks R-S3s or 225/45/17 Kuhmo V710 slicks (autox). Think it's worth the trouble to bring slicks? I'm not super serious about it, but I'l take anything I can get! Any predictions on ETs or trap speeds?
Originally Posted by TickTack View Post
2006 STI - stock motor/turbo - 75k
ACT clutch
3in catless TBE
APS 65mm CAI
Big TMIC
GrimmSpeed xpipe, EWG uppipe
GrimmSpeed ported exhaust manifolds, intake manifold and TGV deletes
GrimmSpeed 3mm phenolic spacers
GrimmSpeed crank pulley
GrimmSpeed 3-port BCS
Turbosmart Hyper-Gate45 Wastegate
DW1100cc sidefeeds
DW300lph pump
Fresh stock plugs, gapped to .024
Tuned well and ended up at 326whp/403ftlb @ 24psi on the Dyno Dynamics at DB Performance. Tuner says stock STIs typically put down around 200whp on his dyno.
TickTack is offline   Reply With Quote
Old 09-26-2011, 02:15 AM   #4474
99STM
Member#: 219160
2002 Impreza WRX
AW (6MT, E85, EWG, VF39)
With a good driver that is probably an 11.xx car on the corn.
99STM is offline   Reply With Quote
Old 09-26-2011, 05:51 AM   #4475
02RexWI
Member#: 165141
I've seen people use auto-x slicks at the drag strip, but you have to try pretty hard to get them sticky. Bring a blow torch
Motion Lab Tuned: Juanmedina's 2007 WRX E85 ARMY Motion Lab Tuning Proven Power Bragging 125 04-12-2010 02:57 AM
jid2 Track Car - e85 ARMY jid2 Member's Car Gallery 38 01-22-2010 10:44 PM
The Honduran army is the bravest in the world... wrxcelent Off-Topic 36 07-07-2009 08:21 AM
Spacific E85 Tuning thread Here ? discopotato03 Engine Management & Tuning 1 09-09-2008 11:01 AM
Did anyone hear the one about the Italian army and the IRAQI satiation? Asinine Off-Topic 3 09-20-2005 07:06 PM
