Welcome to the North American Subaru Impreza Owners Club Tuesday August 4, 2015
Old 10-13-2011, 05:59 PM   #4676
karlknaupp
Member#: 60871
2004 WRB WRX
Hot damn Jr.
karlknaupp is offline   Reply With Quote
Old 10-13-2011, 06:02 PM   #4677
Phatron
Member#: 36033
CEO PhatBottiTuning
2006 STi GTX3582 + Meth
Originally Posted by 5lipstream View Post
@MaxwellPower: where is your shop located?
The 2nd best thing about the internet besides porn
Old 10-13-2011, 06:06 PM   #4678
karlknaupp
Member#: 60871
2004 WRB WRX
U like helping people with Google.. Lol
Old 10-13-2011, 06:09 PM   #4679
Phatron
Member#: 36033
CEO PhatBottiTuning
Terminator is going to come true...except its going to be Google instead of Skynet
Old 10-13-2011, 06:09 PM   #4680
Junior2JZ
Member#: 64908
10.8 XT+10.0@143 GR+
2x9.0@170mph GTRs
Ron how many shares of Google ya own?
Junior2JZ is offline   Reply With Quote
Old 10-13-2011, 06:13 PM   #4681
karlknaupp
Member#: 60871
2004 WRB WRX
Im a share holder... Keep spreading the word lol.
Old 10-13-2011, 06:57 PM   #4682
Junior2JZ
Member#: 64908
2x9.0@170mph GTRs
Different car 650whp with id2ks/Walbro 400 @ 32psi. It is hitting 95% IDC stock lines, stock reg. I bet with some more base pressure we can get 700whp
Old 10-13-2011, 07:45 PM   #4683
maxpowr
Member#: 159243
sg3 Turbo Tek Tuned
Hakt Ecu e85 30r 6spd
im confused...why do i need 1600's for e85?
maxpowr is offline   Reply With Quote
Old 10-13-2011, 08:22 PM   #4684
MainFrame
Member#: 218739
2002 WRX hybrid
what turbo?
MainFrame is offline   Reply With Quote
Old 10-13-2011, 09:54 PM   #4685
Junior2JZ
Member#: 64908
2x9.0@170mph GTRs
You dont.. Unless you are going for a few 8sec passes like the P&L cars
Old 10-13-2011, 10:52 PM   #4686
maxpowr
Member#: 159243
sg3 Turbo Tek Tuned
gt3076r (.63), 75mm cai/maf, id1000s, walbro 255, perrin rails, aero FPR, V5 heads, 272s, +1 valve train, tgv delete, 10mm phenolic spacer, 2.5l, borla uneq header, 44ewg, 3 inch catless.
putting in a walbro 400 for e85 gets me there?
Old 10-13-2011, 11:12 PM   #4687
MainFrame
Member#: 218739
2002 WRX hybrid
1200's should be enough.. you just have to remember that the id1000s don't actually flow very close to 1000cc. I don't remember off the top of my head, but I think at stock fuel pressure they flow in the high 800s. I'm sure several people here know exactly how much they flow.
Old 10-13-2011, 11:45 PM   #4688
juanmedina
Member#: 133146
07 FPgreen 7.37@95
WRX VF39+E85 12.0, 121mph
Old 10-13-2011, 11:52 PM   #4689
maxpowr
Member#: 159243
sg3 Turbo Tek Tuned
what are you saying juan? crank the fuel pressure up to 60#s with a walbro 400?
so with 30#s of boost i'm at 90#'s...
Old 10-14-2011, 01:01 AM   #4690
Junior2JZ
Member#: 64908
2x9.0@170mph GTRs
50 base should get you to max out the 30r. I did it last week with DW1000s and a aero 340. Made 475ish @ 25psi with 90% duty cycle
Old 10-14-2011, 02:07 AM   #4691
Marshall6285
Member#: 256100
I've been thinking of switching to e85 and this is my current setup
ej205, wiseco pistons, stock rods, walbro 255, vf23, full 3" exhaust, fmic, currently sti pinks, intake, apexi ebc.
From what I have researched, I should go with dw1000 and a tune? Please correct me if I'm wrong.
And also later, I would like to get a bigger turbo. I was thinking either hta 68 or td06-18xt.
This is going to mainly be used for daily driving and maybe a few track days.
Am I dumb for these turbo choices?
Marshall6285 is offline   Reply With Quote
Old 10-14-2011, 08:15 AM   #4692
maxpowr
Member#: 159243
sg3 Turbo Tek Tuned
I'll sell my id1000s if you want em bro...i feel im gonna need bigger.
At 24#s my ids were at 110% on 93. I dont see how putting a walbro 400 & cranking pressure up to 50#s gives me 30-40% more fuel...but i'd love to be wrong.
Old 10-14-2011, 09:05 AM   #4693
Junior2JZ
Member#: 64908
2x9.0@170mph GTRs
Walbro 400 will hold pressure to red line. Your 255 more then likely drops pressure.. The ID injectors need steady pressure to achieve there flow capabilities.
If a set of DW1000s can supply enough fuel to max out a 30r on e85, I don't think you will have an issue running id1000s with your setup as long as you have the proper pressure.
Old 10-14-2011, 11:31 AM   #4694
5lipstream
Member#: 124663
2003 AW WRX
2008 GG Evo X MR
Junior: will twin walbro 255's be sufficient for 600ish whp on e? ID2000's at stock pressure.
5lipstream is offline   Reply With Quote
Old 10-14-2011, 12:16 PM   #4695
MattPersman
Member#: 139385
why not P&L and have Jr tune it if you want to drive it. no disrespect to etunes or AMS but if you want it tuned on a dyno, I think I would see Jr
I'd prob just drive up there. There's a shortage of awd dynos in this area and I don't want a road tune.
MattPersman is offline   Reply With Quote
Old 10-14-2011, 12:58 PM   #4696
maxpowr
Member#: 159243
sg3 Turbo Tek Tuned
Somebody pm me a fair price on a walbro 400...intank pump that will require wiring and relays and fuses?
Old 10-14-2011, 01:33 PM   #4697
karlknaupp
Member#: 60871
2004 WRB WRX
i got you!
Old 10-15-2011, 12:34 AM   #4698
Junior2JZ
Member#: 64908
2x9.0@170mph GTRs
More then enough fuel.
Old 10-15-2011, 06:41 PM   #4699
2fst4chp
Member#: 274047
07 EQ built and tuned sti..made 347whp @ 5700 rpm and 399wtq @ 3700 rpm on e85 @ 22.5 psi
-EQ stage 1 block
-EQ stage 1 head
-FP 68HTA turbo
-Ebay tmic heat treated
-Cobb ap
-Perrin inlet
-APS 70mm cai
-Hallman mbc
-TurboXS stealth back w/spt 3" axle back
-Cosworth air bump Delete
-NGK one step colder spark plugs
-Walboro 255
-DW 1300cc injectors
-Grimspeed TGV deletes
-RPS clutch
2fst4chp is offline   Reply With Quote
Old 10-15-2011, 07:29 PM   #4700
RP31
Member#: 123574
2005 2.6L 9:1 425WHP
CGM STi
After some AVCS and timing changes, I have improved to 400 WHP @ 6000 RPM and 415 WTQ at 4600 RPM on E60 at 23 psi... My spoolup region is still a little rich, so I tweaked that in the UTEC and made some more AVCS changes, but I just reflashed the ECU and won't be going out again tonight to get new Airboy numbers. I'm pretty happy with it now though - 300+ WTQ from 3000 RPM to 6750 RPM, and 300+ WHP from 4000 RPM to redline.
RP31 is offline   Reply With Quote
Motion Lab Tuned: Juanmedina's 2007 WRX E85 ARMY Motion Lab Tuning Proven Power Bragging 125 04-12-2010 02:57 AM
jid2 Track Car - e85 ARMY jid2 Member's Car Gallery 38 01-22-2010 10:44 PM
The Honduran army is the bravest in the world... wrxcelent Off-Topic 36 07-07-2009 08:21 AM
Spacific E85 Tuning thread Here ? discopotato03 Engine Management & Tuning 1 09-09-2008 11:01 AM
Did anyone hear the one about the Italian army and the IRAQI satiation? Asinine Off-Topic 3 09-20-2005 07:06 PM
