Old 12-05-2011, 10:27 PM   #5051
smeerone
Member#: 249068
2010 WRX
DGM Phatbotti Tuned
Originally Posted by WRXPCT04
Time for me to post up and join the Army
06' STi
Nitrited Crank
Eagle Rods
Weisco Pistons
Kelford B 264 Cams
1mm larger valves
Cosworth Intake
Garrett GTX3076 .82
Modified Dark Blue 1000cc injectors
Dual Walbro's - 75psi base pressure
UTEC Tuned by Jermaine @ TurboXS
E85 @ 28psi
Saw 565whp/500+tq on their dynapack, but ran out of injector.
Anyone have any good 1200cc+ injectors sizes they're having good luck with aside from the ID2000's??
Show off! I bet its pretty slow huh
smeerone is offline   Reply With Quote
Old 12-05-2011, 10:28 PM   #5052
jayblizzo
Member#: 58957
2010 WRX STI
SSM
Originally Posted by MainFrame
Ahh.. I thought you were talking flow. Yea, the pump is slightly larger, and flares out at the end, but it dropped right into my 255 harness no problem.
I don't know if I already said this, but it's damn quiet too. Much quieter than my old 255.
Yeah it is much quieter than my 255
jayblizzo is offline   Reply With Quote
Old 12-05-2011, 10:34 PM   #5053
WRXPCT04
Member#: 144563
2006 STi
SGM GTX3076
grocery getter ya know.... I don't show off often so i'll take advantage this once.
WRXPCT04 is offline   Reply With Quote
Old 12-05-2011, 10:35 PM   #5054
smeerone
Member#: 249068
2010 WRX
DGM Phatbotti Tuned
Enjoy man, I bet it's ALOT of fun.
Old 12-06-2011, 07:43 AM   #5055
buddsautoparts.com
Member#: 263591
2004 being rebuilt
good question!
06' STi
Nitrited Crank
Eagle Rods
Weisco Pistons
Kelford B 264 Cams
1mm larger valves
Cosworth Intake
Garrett GTX3076 .82
E85 @ 28psi
FIC has 2150's and 1680's I have both instock needing to move the 1680's so a steal is what they are.. Fiveomotorsports does as well
buddsautoparts.com is offline   Reply With Quote
Old 12-06-2011, 09:01 AM   #5056
WRXPCT04
Member#: 144563
2006 STi
SGM GTX3076
PM me some details on those 1680's
Old 12-13-2011, 07:09 PM   #5057
wrxsubiemod
Member#: 165104
E85 SoCalPorting
Owner
What vendor on here was selling those fuel testers? Need to have one around
wrxsubiemod is offline   Reply With Quote
Old 12-13-2011, 07:15 PM   #5058
8thWonder
Member#: 230366
2005 STi
it's motor buildin' time!
maperformance
8thWonder is offline   Reply With Quote
Old 12-13-2011, 07:24 PM   #5059
wrxsubiemod
Member#: 165104
E85 SoCalPorting
Owner
^thanks
Old 12-14-2011, 09:48 AM   #5060
WhyHelloOfficer
Member#: 193989
2004 Matte White GTO
Australian Racecar
The 'Quick Fuel 36-E85' from Summit Racing is what I use. It cost all of $15.
WhyHelloOfficer is offline   Reply With Quote
Old 12-14-2011, 11:56 AM   #5061
rydog
Member#: 70982
I found one for under $5 on ebay from a company that sells marine accessories. It is small and stores easily. I use an old baby bottle to collect the fuel and medicine dropper to transfer it to the test tube.
rydog is offline   Reply With Quote
Old 12-14-2011, 03:33 PM   #5062
8thWonder
Member#: 230366
2005 STi
Petition for E85 vehicles to be exempt from emissions testing:
https://wwws.whitehouse.gov/petition...-smog/XRhzHptF
Old 12-15-2011, 06:47 PM   #5063
4orcefed240
Member#: 99072
2006 STI
SGM
Seriously people need to get in and sign this, it would be awesome. Takes two seconds to create a profile too(faster than it takes to register a forum)
4orcefed240 is offline   Reply With Quote
Old 12-15-2011, 08:43 PM   #5064
SurfGuruJeff
Member#: 148974
2010 STi Hatch
^^^ signed yesterday
SurfGuruJeff is offline   Reply With Quote
Old 12-15-2011, 11:29 PM   #5065
02RexWI
Member#: 165141
Good luck getting that passed with the verbiage of larger fuel pump and injectors
02RexWI is offline   Reply With Quote
Old 12-17-2011, 02:51 PM   #5066
mecpgh
Member#: 193014
02 WRX WRB, 05 STI
FPGreen E85 400+whp
Can anyone explain why humidity kills my cold start on E? I've been working onthis for a month our so. Initial start is ok have the cranking tables up for ethanol but right after still in open loop just goes lean and wants to die. Can not decide if I need to tweak my maf scaling down low our not because it's fine on pump. Also I'm on five o 1600s
mecpgh is offline   Reply With Quote
Old 12-17-2011, 05:33 PM   #5067
amalgrover
Member#: 183480
2011 Audi A3 Quattro
2009 Forester XT
have you tried changing the warm-up tables at all...i had a similar problem and had to increase my warm-up duration a little bit, and it smoothed things out alot
amalgrover is offline   Reply With Quote
Old 12-17-2011, 06:09 PM   #5068
mecpgh
Member#: 193014
02 WRX WRB, 05 STI
FPGreen E85 400+whp
I just started tweaking them to see what would happen. Just sucks because there are something like 9 or so on the 05sti rom. Any idea how much change you made? I don't know enough about the decay values and 1,2,3 a, b enrichments .I'm trying to figure out the logic of it all.
Old 12-18-2011, 11:48 AM   #5069
punchjamesarnol
Member#: 284835
2014 Hyundai Equus
White Pearl Mica
gonna change the subject real quick. Phatron just finished tuning my car. 360hp/403 tq on stock vf48 @ 22 psi. Thanks Ron!
punchjamesarnol is offline   Reply With Quote
Old 12-18-2011, 11:59 AM   #5070
Visconti
Member#: 156247
14' Flex Fuel FXT
15' Flex Fuel WRX
what are you higher hp e85 guys running for plugs?
Visconti is offline   Reply With Quote
Old 12-18-2011, 03:01 PM   #5071
07wrx84
Member#: 252195
07 WFC #900
@ 451awhp-404awtq
Stock
07wrx84 is offline   Reply With Quote
Old 12-18-2011, 03:03 PM   #5072
mecpgh
Member#: 193014
02 WRX WRB, 05 STI
FPGreen E85 400+whp
I'm running coppers and lots of others do as well
Old 12-18-2011, 03:43 PM   #5073
amalgrover
Member#: 183480
2009 Forester XT
stock heat range coppers
Old 12-18-2011, 03:51 PM   #5074
mecpgh
Member#: 193014
02 WRX WRB, 05 STI
FPGreen E85 400+whp
Amailgrover any other details on you warm up enrich?
Old 12-18-2011, 04:03 PM   #5075
amalgrover
Member#: 183480
2009 Forester XT
unfortunately, every car is different in this area so there isn't a specific way or amount i can tell you to change things. its pretty much an area where you have to make small adjustments, test, and repeat until you get it right. just make sure you are only adjusting the tables that are applicable so it doesn't mess up the warm weather startup stuff. what you need to do is increase things across the tables so that it stays in warm up longer and enriches more for longer. a starting point might be the decay step value tables. you may want to try shifting everything to the right 1 block (in the applicable temp ranges) on these tables. what i mean by this is if you were to start at the far right block, copy the value immediately left of it, and past it into the far right block. just repeat this all the way down the table so that all the decay step values have been increased so they hold from decaying enrichment until temps come up 1 more block than originally set. sometimes this works, and sometimes it doesn't do anything at all to help...its just a matter of finding the right settings for your car and your geographical location.
...i wish i could help more, but its just so hit or miss from car to car...
Motion Lab Tuned: Juanmedina's 2007 WRX E85 ARMY Motion Lab Tuning Proven Power Bragging 125 04-12-2010 03:57 AM
jid2 Track Car - e85 ARMY jid2 Member's Car Gallery 38 01-22-2010 11:44 PM
The Honduran army is the bravest in the world... wrxcelent Off-Topic 36 07-07-2009 09:21 AM
Spacific E85 Tuning thread Here ? discopotato03 Engine Management & Tuning 1 09-09-2008 12:01 PM
Did anyone hear the one about the Italian army and the IRAQI satiation? Asinine Off-Topic 3 09-20-2005 08:06 PM
