Old 05-13-2012, 11:09 AM   #5926
Maxwell Power
Member#: 190729
Originally Posted by jnorth85
Here is a video of a run friday night, i only got 3 passes in!
It has the JDM 5th and 6th also!
Video Link: http://www.youtube.com/watch?v=Uxnr1R8MdQc&sns=em
Nice shifting! FFS? or just that good.
Maxwell Power is offline   Reply With Quote
Old 05-13-2012, 11:35 AM   #5927
jnorth85
Member#: 76785
2000 580Whp The RSTI
SRP
Just normal shifting with the clutch haha.
jnorth85 is offline   Reply With Quote
Old 05-13-2012, 11:59 AM   #5928
jays05
Member#: 78165
05 STI 35r + e85
I started tweaking the tune again after installing an omni 4bar map sensor (replacing a gm 3bar). I'm at 27psi and 11.6ish AFR, and EGT's are still super low - the highest my gauge has seen is 820c. Still using a UTEC too
I have some funky grinding noises going on in the front end though and it's been getting worse lately. It's speed dependent and unrelated to steering angle or using the brakes. I'm gonna replace the front pads even though there is still meat on em and see if I can find anything wrong with the front axles and cv's while it's apart.
jays05 is offline   Reply With Quote
Old 05-13-2012, 02:17 PM   #5929
maxpowr
Member#: 159243
sg3 Turbo Tek Tuned
Hakt Ecu e85 30r 6spd
throw out bearing?
maxpowr is offline   Reply With Quote
Old 05-13-2012, 02:49 PM   #5930
jays05
Member#: 78165
05 STI 35r + e85
Originally Posted by maxpowr View Post
throw out bearing?
It's speed dependent not rpm. Clutch in/out does not make a difference either.
When I had the wheels off I didn't see the dust covers rubbing, and I couldn't feel any play in the wheel bearings. I might just put the car on jackstands and let it idle in 4th gear or something.
Old 05-13-2012, 03:08 PM   #5931
Maxwell Power
Member#: 190729
You sure you didn't break an axle up front and the diff is making noise?
Old 05-13-2012, 03:31 PM   #5932
jays05
Member#: 78165
05 STI 35r + e85
I was thinking the same thing, but it sounds the same with the dccd open or locked, and it makes the sound going downhill in neutral. It's the old style 6-speed where dccd open is completely open.
I noticed it right after the motor went back in, 4k miles ago. It started as a shush-shush-shush noise that I could only hear with the windows down. Now it is more like chuck-chuck-chuck, not super loud but there is no sound deadener in the car so it's pretty noticeable. Maybe I'll dig into it tonight.
Old 05-13-2012, 06:23 PM   #5933
Maxwell Power
Member#: 190729
I was thinking front diff, not center.
Old 05-14-2012, 08:37 AM   #5934
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
Originally Posted by jnorth85 View Post
We ended up with an estimated 505/480 on virtual dyno
The car loves the E!
Justin's RSTi @ Cedar Falls Raceway - May 11th 2012 - YouTube
Looks great. Any chance you'd be able to do a 50-100mph video for comparison to all the heavy cars?
http://forums.nasioc.com/forums/show....php?t=2349792
xluben is offline   Reply With Quote
Old 05-14-2012, 09:05 AM   #5935
jnorth85
Member#: 76785
SRP
It is in my plans !
Old 05-14-2012, 09:15 PM   #5936
07wrx84
Member#: 252195
07 WFC #900
@ 451awhp-404awtq
Originally Posted by punchjamesarnol
If I may ask, what are your mods? I'm wanting to bump up boost a notch to get more power.
ALL bolt ons!
20gxt 8cm
Hybrid boost control
Tgv deletes
Hks hi-power exhaust! catless
Big TMIC
38mm EWG
P/P exhaust mani and cross pipe
Aggressive tune with gasoline AFR and LOTS of timing lol... On 22 pounds of boost!
07wrx84 is offline   Reply With Quote
Old 05-15-2012, 08:29 PM   #5937
jays05
Member#: 78165
05 STI 35r + e85
After putting the car up on jackstands and letting it idle in 3rd/4th gear, I'm pretty sure that the noise is coming from the tailshaft of the trans
Old 05-15-2012, 08:41 PM   #5938
340Duster
Member#: 52314
2002 PSM WRX 16G-XT
'13 500 Abarth
Transfer gear bearings possibly then.
340Duster is offline   Reply With Quote
Old 05-16-2012, 02:48 AM   #5939
silverongold
Member#: 132599
02 impreza wrx
Hey dudes!
I am building a turbo set up probably using a BW s200 airwerks (30r sizeish). I will be running e85 and would like to know what recommendations you have for a fuel pump set up. Currently i have dw 1000's and a walbro pump. will this be enough for a 30r size turbo or will i need a bigger pump and injectors? I am shootin for high 400hps.
thanks!
silverongold is offline   Reply With Quote
Old 05-16-2012, 08:28 AM   #5940
SubieLuvin
Member#: 248202
2013 WRX Sedan
I pick my car up tonight. I'm gettin antsyyyy
SubieLuvin is offline   Reply With Quote
Old 05-16-2012, 09:25 AM   #5941
jnorth85
Member#: 76785
SRP
Originally Posted by silverongold
Hey dudes!
thanks!
You will need more pump, and injectors.
Youll need at least 1200cc injectors if you can maintain pressure at redline.
There are a few pump options.
1) dual in tank pumps
2) additional in line pump
3) swirl pot with external pump(s)
4) boost a pump (may work, probably not the best option)
You may be able to get by with a simple re-wire but you will be at the upper limits of doing that.
With a 30r you should be able to break 500whp
Old 05-16-2012, 10:58 AM   #5942
Maxwell Power
Member#: 190729
Everything in that area is super easy to work on. Not very cheap, but easy.
Old 05-16-2012, 04:22 PM   #5943
silverongold
Member#: 132599
02 impreza wrx
Thank you for your input! If I ran my walbro into a surge tank and then an inline what pump would that work, and what would you recommend for an inline pump? And where can I find good info on setting up pumps, regulator, wiring ect?
Old 05-16-2012, 04:43 PM   #5944
slowgenius
Member#: 48350
WRX 03/04/07 hybrid
I went with a Fuelab inline pump with a whalbro feeding a surge tank.
It has some flexibility as far as speed control. It can be used with their electronic fuel pressure regulator, take a 0-5v pwm signal or use the supplied resistor to run constant high, or constant low.
Aeromotive also makes an inline pump, and many others. Its all up to you. Find out what your fuel type and flow requirements are, and give yourself some extra headroom and go from there.
There are some good ideas in the fuel systems thread in the built motor discussion.
slowgenius is offline   Reply With Quote
Old 05-16-2012, 07:38 PM   #5945
Squidz
Member#: 142608
2003 Sonic Yellow
Marginally well behaved.
Sooo...all the parts of my car are finally in the same room. That's progress after two years...LOL.
Was wondering how many of you guys run a dual map setup (e85 and Gasoline)? Anyone had any luck switching between them on a regular basis? Was wondering if it was even worth having a gasoline map built for it.
Squidz is offline   Reply With Quote
Old 05-16-2012, 09:16 PM   #5946
07wrx84
Member#: 252195
07 WFC #900
@ 451awhp-404awtq
I only have E85 map! But she not my DD! So prob wise to have both just incase...
Old 05-16-2012, 09:54 PM   #5947
Squidz
Member#: 142608
2003 Sonic Yellow
Well, my wrx doesn't have to be my DD either. However i would like to drive it quite a bit. If it's not incredibly wise to switch back and forth (i.e people have experienced issues with it), then i don't need to do it.
Just wondering what my options are and what others have experienced.
Thanks for the response.
Old 05-16-2012, 10:15 PM   #5948
SubieLuvin
Member#: 248202
2013 WRX Sedan
Switching back and forth very often wouldn't be an issue if you ran the car very low on fuel before switching maps and refueling so they didn't mix. But, with that comes burning up your fuel pump when your letting it run so low all the time. Too much headache though imo
Id personally say its a good idea go pick one and stick with it most of the time. If 93 is that much more abundant for you in the area than the corn fuel then just spray meth. It seems like a lot of guys in here have run e85 pretty much year round even in colder weather...so what is your purpose to switch maps?
Old 05-16-2012, 10:18 PM   #5949
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
Switching back and forth is a bad idea in my book. Unless you manually pump/siphon the tank dry to switch.
Old 05-16-2012, 10:20 PM   #5950
SubieLuvin
Member#: 248202
2013 WRX Sedan
That'd be the much safer way to do it I'm an idiot lol. Seems like a pain in the dick though
Motion Lab Tuned: Juanmedina's 2007 WRX E85 ARMY Motion Lab Tuning Proven Power Bragging 125 04-12-2010 02:57 AM
jid2 Track Car - e85 ARMY jid2 Member's Car Gallery 38 01-22-2010 10:44 PM
The Honduran army is the bravest in the world... wrxcelent Off-Topic 36 07-07-2009 08:21 AM
Spacific E85 Tuning thread Here ? discopotato03 Engine Management & Tuning 1 09-09-2008 11:01 AM
Did anyone hear the one about the Italian army and the IRAQI satiation? Asinine Off-Topic 3 09-20-2005 07:06 PM
