Old 08-01-2012, 10:44 PM   #6051
|Rev|
Member#: 100651
2010 STI
I have officially joined the E85 army.
Printer at the shop was acting funky so the graph is hard to see. Car made 326/360. Expected more out of it but oh well. Tune is great and the low power is in no way shape or form the tuners fault.
Power mods are as follows.
07 Sti, HTA68(7cm) - ID1000's - Walboro 255lph - Perrin inlet - Cobb 3 port EBCS - GS Ceramic coated up-pipe - Tial 44mm EWG
Elevation at the shop is over 5k ft, correction factor is 1.5 I believe (15%)
|Rev| is offline   Reply With Quote
Old 08-02-2012, 10:48 AM   #6052
Squidz
Member#: 142608
2003 Sonic Yellow
Marginally well behaved.
That graph looks great, very responsive (yay 7cm!!). That is a pretty low number though for that turbo and E85. What's the peak boost on it?
Squidz is offline   Reply With Quote
Old 08-02-2012, 11:10 AM   #6053
WRXt4cy
Member#: 172698
11 STi BW 8374 E85
02 v8 Spec C E85
That's not too bad for that turbo at higher altitude but I'm surprised to see the torque drop off so sharply after peaking. I would also be curious to know how much boost it hits and then tapers to.
WRXt4cy is offline   Reply With Quote
Old 08-02-2012, 11:33 AM   #6054
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
Yeah, I'd be curious to see the boost curve too. I thought the point of the HTA68 was stock-like spool, but not dropping off up top. This looks like it dies just like a VF would. In fact, it looks just like a VF powerband with similar (possibly even lower) peak numbers (than a VF). I'm still not convinced the HTA68 is worth it over a VF. Most results I've seen make it look pretty similar.
xluben is offline   Reply With Quote
Old 08-02-2012, 12:05 PM   #6055
StiRhino
Member#: 245964
2011 STI
Another one to join the E85 army.
Car made 540/462 SAE correction factor or 550AWHP STD correction factor at 26PSI. It Can make 600+ on 32PSI but I wanted it to last a while so no need to push it.
04 Sti, GTX35r (.63 hotside) - ID2000's - dual Walboro 255lph - Tigwerks FMIC, Headers, Downpipe, Uppipe, turbo inlet. Cobb SD
StiRhino is offline   Reply With Quote
Old 08-02-2012, 12:55 PM   #6056
sackytar
Member#: 149262
03WR Rallycar/FXT/OB
PrimerGrey
Car made 540/462 SAE. 26PSI Can make 600+ on more 32PSI but I wanted it to last.
Scary!
sackytar is offline   Reply With Quote
Old 08-02-2012, 11:20 PM   #6057
MainFrame
Member#: 218739
2002 WRX hybrid
What GTX35r is that? I'm almost done with my GTX3576r build and I went with a Tial .82 hotside. That .63 hotside (I'm assuming Garrett T3 housing) looks to be holding power up top really well.
MainFrame is offline   Reply With Quote
Old 08-02-2012, 11:28 PM   #6058
StiRhino
Member#: 245964
2011 STI
Tial Stainless Steel .63 hot side. GTX3582r
Old 08-04-2012, 06:47 PM   #6059
yo6bd
Member#: 196887
2010 Corn <3'er
361WHP/444WTQ stock turbo
Finally made the switch!!!
Everything else is stock besides these mods:
Invidia Catless Q300 TBE
Perrin Inlet
AEM CAI
Cobb BPV
Pierburg 3 port EBCS
DW300 Fuel Pump
ID1000's
Zeitronics E85 fuel gauge
yo6bd is offline   Reply With Quote
Old 08-04-2012, 06:50 PM   #6060
punchjamesarnol
Member#: 284835
2014 Hyundai Equus
White Pearl Mica
Congrats!!! where'd you get the zeitronix gauge?
punchjamesarnol is offline   Reply With Quote
Old 08-04-2012, 07:34 PM   #6061
yo6bd
Member#: 196887
2010 Corn <3'er
Got the gauge direct from Zeitronix as well as the wiring harness. Sensor was off e-bay from a crashed Tahoe!
Holder was designed by me and made by my sheet metal guy from work
Old 08-04-2012, 08:21 PM   #6062
StiRhino
Member#: 245964
2011 STI
Cool mount for the ECA. I like my a lot it keeps all the guess work out of the fuel. Here is where I have mine mounted.
Old 08-04-2012, 08:29 PM   #6063
sackytar
Member#: 149262
PrimerGrey
E sensor Ftw! So many times I am sketched out about what fuel I am getting. The sensors are pricy though.
Old 08-04-2012, 08:51 PM   #6064
smeerone
Member#: 249068
2010 WRX
DGM Phatbotti Tuned
How much is the tahoe sensor typically?
smeerone is offline   Reply With Quote
Old 08-04-2012, 08:52 PM   #6065
yo6bd
Member#: 196887
2010 Corn <3'er
Yea. Sensors are pricey. I probably spend $400 total. Where did you mount yours? Mine is on a bracket utilizing the balance hose on my Sti.
Old 08-04-2012, 08:53 PM   #6066
yo6bd
Member#: 196887
2010 Corn <3'er
Look on e-bay. Paid $150 shipped from a guy in Texas. Most others were $200
Old 08-04-2012, 08:54 PM   #6067
smeerone
Member#: 249068
2010 WRX
DGM Phatbotti Tuned
Are u guys really seeing that much of a variance in the quality of E?
Old 08-04-2012, 08:56 PM   #6068
StiRhino
Member#: 245964
2011 STI
I paid 100 on ebay for mine. But most are 200 Like yo6bd said. My sensor is mounted on a bracket where my windshield washer bottle use to be.
Old 08-04-2012, 08:57 PM   #6069
yo6bd
Member#: 196887
2010 Corn <3'er
Got E76 my first time when I went for tune. My tuner had some E85 for his car. Used his to get it to E84
Old 08-04-2012, 08:58 PM   #6070
smeerone
Member#: 249068
2010 WRX
DGM Phatbotti Tuned
So what happens if im tuned for 85 and i get 75?
Old 08-04-2012, 08:58 PM   #6071
yo6bd
Member#: 196887
2010 Corn <3'er
+1. Mine is on the bracket that holds the fuel regulator.
Old 08-04-2012, 09:00 PM   #6072
StiRhino
Member#: 245964
2011 STI
Yeah sorry but laws only state it has to be E70 to be considered E85 and my EXPENSIVE motor and parts are not worth risk. My car was tuned on E84 so if I get some E70 in the tank I can do some damage to the motor.
Old 08-04-2012, 09:01 PM   #6073
StiRhino
Member#: 245964
2011 STI
If you get some low E content fuel either turn down the boost or don't beat on it.
Old 08-04-2012, 09:02 PM   #6074
StiRhino
Member#: 245964
2011 STI
It just depends on how aggressive your tuner has tuned your car and if he left some room in the tune for chance that you may get low E
Old 08-04-2012, 09:05 PM   #6075
smeerone
Member#: 249068
2010 WRX
DGM Phatbotti Tuned
Im going E next week and now im gonna get the sensor just to be safe. Thx for input fellas. I'll make sure to remind my tuner (sti mikey) to implement some safe guards.
Motion Lab Tuned: Juanmedina's 2007 WRX E85 ARMY Motion Lab Tuning Proven Power Bragging 125 04-12-2010 02:57 AM
jid2 Track Car - e85 ARMY jid2 Member's Car Gallery 38 01-22-2010 10:44 PM
The Honduran army is the bravest in the world... wrxcelent Off-Topic 36 07-07-2009 08:21 AM
Spacific E85 Tuning thread Here ? discopotato03 Engine Management & Tuning 1 09-09-2008 11:01 AM
Did anyone hear the one about the Italian army and the IRAQI satiation? Asinine Off-Topic 3 09-20-2005 07:06 PM
