Old 08-30-2012, 03:46 PM   #6226
smeerone
Member#: 249068
2010 WRX
DGM Phatbotti Tuned
Originally Posted by Squidz
Joined the E85 Army finally last weekend. Finally got my project up and running.
She made 426WHP/417WTQ and we ran out of injector. I'll get the dyno plot up this weekend when i get some time to scan it into the puter.
Congrats!
smeerone is offline   Reply With Quote
Old 08-30-2012, 05:10 PM   #6227
wrxsubiemod
Member#: 165104
E85 SoCalPorting
Owner
Awesome
wrxsubiemod is offline   Reply With Quote
Old 08-30-2012, 07:22 PM   #6228
amalgrover
Member#: 183480
2011 Audi A3 Quattro
2009 Forester XT
welcome to the club Squidz...what are the details on your setup?
amalgrover is offline   Reply With Quote
Old 08-30-2012, 09:08 PM   #6229
Squidz
Member#: 142608
2003 Sonic Yellow
Marginally well behaved.
Trying to get the build thread together...here's the cliff notes:
EJ25 forged pistons/rods (9.2:1 compression)
USDM EJ20 heads/ CNC combustion chambers/Supertech springs/STi cams
Brand new 8cm FP HTA71 turbocharger (first one ever built...car was a test mule)
Internal WG
84mm FP Inlet
ETS Top-mount intercooler
IDE 1000 cc
DW 300 LPH fuel pump
GT Spec UEL Header
Cobb Tuned
Squidz is offline   Reply With Quote
Old 08-30-2012, 09:20 PM   #6230
amalgrover
Member#: 183480
2009 Forester XT
very nice!
are you planning to upgrade the fuel system or are you going to let it ride as is for now?
Old 08-30-2012, 09:27 PM   #6231
07wrx84
Member#: 252195
07 WFC #900
@ 451awhp-404awtq
Way nice bro!
07wrx84 is offline   Reply With Quote
Old 08-30-2012, 10:32 PM   #6232
sackytar
Member#: 149262
03WR Rallycar/FXT/OB
PrimerGrey
Internal WG
84mm FP Inlet
IDE 1000 cc
GT Spec UEL Header
Cobb Tuned
Get this thing tuned I wanna see numbers and spool time.
Plan on Doing similar build
sackytar is offline   Reply With Quote
Old 09-03-2012, 08:57 PM   #6233
mpen747
Member#: 292343
do i have to completely drain my gas tank if im going to get tuned for e85? or would 1/8 tank (near empty) be alright?
mpen747 is offline   Reply With Quote
Old 09-03-2012, 09:00 PM   #6234
06rexwagon
Member#: 114730
2006 WRX Limited Wag
[email protected]
Ideally you would run a tank of e85 through on a base tune for e85 before doing any power tuning. The afr changes too much when you have a mixture. I tune a lot of cars and if I ever have to do e85 right after pump gas I drain it completely and even pull the drain plugs on the tank.
06rexwagon is offline   Reply With Quote
Old 09-03-2012, 09:01 PM   #6235
Blacksheep6
Member#: 239945
To be on the safe side you can drain the tank. But you can just run it down past the empty line and you will be fine. Make sure to test the ethenal content of the E85 when you fill up.
Blacksheep6 is offline   Reply With Quote
Old 09-03-2012, 09:02 PM   #6236
speedyHAM
Member#: 48377
1996 Gutted, built
XP class Impreza L
Depends if you are always going to run straight E85 or if there will be some gas mixed in at some point.
If you want a safe tune, 1/8 tank of gas +7/8 tank of E85 would make it pretty safe for a tune as long as your tuner knows what they are doing. In the winter some areas get E70 blend to help cars start in the cold, so 1/8th tank of gas may represent your "worst case" winter blend.
speedyHAM is offline   Reply With Quote
Old 09-05-2012, 06:31 PM   #6237
Squidz
Member#: 142608
2003 Sonic Yellow
No problem...here ya go:
http://www.cobbtuning.com/Dyno-Database-s/70119.htm
It's under Cobb Plano, 2003 WRX, owner is Shawn Rizzo
Old 09-05-2012, 06:44 PM   #6238
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
xluben is offline   Reply With Quote
Old 09-05-2012, 09:13 PM   #6239
Squidz
Member#: 142608
2003 Sonic Yellow
^^ Thanks! How did you do that? I kept trying to use the image link and it wouldn't work.
Old 09-05-2012, 09:30 PM   #6240
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
If you go to the link that I posted, at the bottom it says "Link to This Graph". Click that, and then paste that URL between the [IMG] tags and it magically pops up!
Old 09-09-2012, 03:00 PM   #6241
nate_fisher
Member#: 270482
2011 turbotek fxt
[email protected] 4eat xt record?
So i thought i would post in here befor i start a thread asking were i can get e85 near englishtown nj. I am planning to go to englishtown for the sti vs evo day but i live in albany ny and it is about 180 miles each way. I see there are no e85 station in nj and i cant find any stops along the way there so i was wondering if they sell e85 at englishtown raceway? If not what would be my option filling up multiple 5 gal jugs full for the drive lol?
nate_fisher is offline   Reply With Quote
Old 09-09-2012, 03:10 PM   #6242
07wrx84
Member#: 252195
07 WFC #900
@ 451awhp-404awtq
Sounds too much outta the way!
Old 09-10-2012, 01:40 PM   #6243
gerryriccio
Member#: 273440
2011 WRX
Can anyone tell me if I should be running colder plugs....I have a 2011 wrx, stock turbo running 17 psi, 1000 cc dw injectors, and a dw65c fuel pump. I've been running E85 for a couple weeks and made good power for having a stock turbo and inter cooler (306/359). I get a little hard starting when the car is already warm but runs good otherwise....any advise will help!
gerryriccio is offline   Reply With Quote
Old 09-10-2012, 01:48 PM   #6244
WRXt4cy
Member#: 172698
11 STi BW 8374 E85
02 v8 Spec C E85
You should stick with stock heat range plugs with E85. I've seen some cases of high rpm spark blowout with colder plugs.
The rough hot starts have to do with hot start enrichment. For whatever reason, the stock tuning targets rich AFRs during hot starts, probably to help with evaporation or something. Gasoline doesn't mind running really rich like that but E85 will run rough and misfire. It should normally clear up after 15 seconds or so. If you are Cobb tuned, your tuner should be able to disable this enrichment, if you are Open Source tuned then it should be possible very soon as the definitions for these tables are being defined. I've been testing them on my own car.
WRXt4cy is offline   Reply With Quote
Old 09-10-2012, 01:57 PM   #6245
1VIPWRX
Member#: 107554
yellow
e85 pump on the thruway by the suffern exit
1VIPWRX is offline   Reply With Quote
Old 09-10-2012, 01:57 PM   #6246
guroove
Member#: 129833
2005 Forester XT
Obsidian Black Pearl
No, do not run colder plugs.
guroove is offline   Reply With Quote
Old 09-10-2012, 03:01 PM   #6247
07wrx84
Member#: 252195
07 WFC #900
@ 451awhp-404awtq
Copper!
Old 09-10-2012, 05:07 PM   #6248
gerryriccio
Member#: 273440
2011 WRX
Thanks everyone, I appreciate the info
Old 09-10-2012, 06:45 PM   #6249
Squidz
Member#: 142608
2003 Sonic Yellow
Hrmm...i'm running colder plugs in mine. Anyone had any issues with idle using colder plugs? Wonder if that could be the issue.
Makes sense though that E85 burns so much cooler you don't really need the colder plugs...
Old 09-10-2012, 09:13 PM   #6250
punchjamesarnol
Member#: 284835
2014 Hyundai Equus
White Pearl Mica
I've been on stock iridiums for over a year, and no prob...
punchjamesarnol is offline   Reply With Quote
Motion Lab Tuned: Juanmedina's 2007 WRX E85 ARMY Motion Lab Tuning Proven Power Bragging 125 04-12-2010 02:57 AM
jid2 Track Car - e85 ARMY jid2 Member's Car Gallery 38 01-22-2010 10:44 PM
The Honduran army is the bravest in the world... wrxcelent Off-Topic 36 07-07-2009 08:21 AM
Spacific E85 Tuning thread Here ? discopotato03 Engine Management & Tuning 1 09-09-2008 11:01 AM
Did anyone hear the one about the Italian army and the IRAQI satiation? Asinine Off-Topic 3 09-20-2005 07:06 PM
