Old 09-10-2012, 09:35 PM   #6251
amalgrover
Member#: 183480
2011 Audi A3 Quattro
2009 Forester XT
some people do not have issues, but alot of people do...
my first e85 motor had zero issues with the stock heat range iridiums, but my second motor misfired like crazy until i switched to stock heat range coppers.
amalgrover is offline   Reply With Quote
Old 09-10-2012, 09:37 PM   #6252
Squidz
Member#: 142608
2003 Sonic Yellow
Marginally well behaved.
I think i just need to go back to stock heat range anything...
And Amal, sorry i missed your question earlier....i'm gonna leave the fuel system the way it is for now. Just enjoy having the car back after almost three years.
Squidz is offline   Reply With Quote
Old 09-10-2012, 09:43 PM   #6253
amalgrover
Member#: 183480
2009 Forester XT
its all good...i definitely feel ya on that one. 3yrs is a long time to go without your toy, and i was the same way when that happened with mine.
Old 09-10-2012, 10:03 PM   #6254
smeerone
Member#: 249068
2010 WRX
DGM Phatbotti Tuned
Whats up army, i got a cel today while accelerating in 5th gear ( 2010 wrx) p0108 map high input. Has anyone dealt with this?
Headers, dp, walbro255, dw 1000's, tmic.
smeerone is offline   Reply With Quote
Old 09-10-2012, 10:07 PM   #6255
amalgrover
Member#: 183480
2009 Forester XT
the only time i have come across this issue was when there was an intake leak near the map sensor...thats just the extent of my personal experience with that CEL.
Old 09-10-2012, 10:24 PM   #6256
Phatron
Member#: 36033
CEO PhatBottiTuning
2006 STi GTX3582 + Meth
you have to increase the MAP sensor CEL voltage. subaru lowered it from from 4.92volts in 2007 to 4.6 volts on teh 08+ wrx's.
or if you did air pump deletes there is a connector that needs to stay connected for the atm pressure sensor, i believe if its unplugged it can cause that same cel.
Old 09-10-2012, 11:23 PM   #6257
smeerone
Member#: 249068
2010 WRX
DGM Phatbotti Tuned
Thanks Ron, no air pump deletes. Can Mikey fix the voltage issue or its a mechanical fix? Would a 3 bar Map also work? ( omori)
Old 09-11-2012, 12:02 AM   #6258
07wrx84
Member#: 252195
07 WFC #900
@ 451awhp-404awtq
Is it worth the hassle to do " air pump deletes "? I have the plates just haven't actually installed em lol!
07wrx84 is offline   Reply With Quote
Old 09-11-2012, 12:16 AM   #6259
STi Mikey
Member#: 114631
2009 GTR, 735whp
13' Benz, 15' WRX
Ill up the threshold but we shouldnt be anywhere near it. Only running 21psi. Rob, let me know if you need the new map or if you turned the boost down.
-Mikey
STi Mikey is offline   Reply With Quote
Old 09-11-2012, 12:33 AM   #6260
smeerone
Member#: 249068
2010 WRX
DGM Phatbotti Tuned
-Mikey
Thanks Mikey
Old 09-11-2012, 12:41 AM   #6261
Phatron
Member#: 36033
CEO PhatBottiTuning
It's not an overboost cel, it's a high MAP volt cel. It seems to be tempermental too. Most cars don't even pop it with the stock voltage setting. But a few do and I really haven't figured out why. But based on the old voltage trip point and the new lower trip point it seems like Subaru lowered it and started using it as a secondary or backup overboost cel. So since the voltage is lower it seems to trip on some cars ~18-19 psi.
Old 09-11-2012, 09:06 AM   #6262
Innovative Tuning
Member#: 67958
MY96 Time Attack
and 06 STI daily
Stock shortblock, 21 psi, e85
Innovative Tuning is offline   Reply With Quote
Old 09-11-2012, 10:05 AM   #6263
jnorth85
Member#: 76785
2000 580Whp The RSTI
SRP
I've been at this power level for a full season now still holding strong!
The stock block can really hold up well on E85!
jnorth85 is offline   Reply With Quote
Old 09-11-2012, 10:21 AM   #6264
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
My stock block lasted a few months with a 20G XTR, E85 and about 22psi. It was around 400WHP on a Mustang dyno. I think I got nearly 6k miles out of it between installing the new turbo and cracking a piston.
xluben is online now   Reply With Quote
Old 09-11-2012, 10:23 AM   #6265
draco159
Member#: 204121
2005 WRX Wagon
CGM
That was on a 2.5 right? I wonder how a 2.0 would compare.
draco159 is offline   Reply With Quote
Old 09-11-2012, 12:34 PM   #6266
jnorth85
Member#: 76785
SRP
I'm on a DOM3 xtr @ 26 psi.
I've gone one season at 450whp (23-24psi)
And am now on one season at 520whp.
Stock EJ257 holding so far!
Old 09-11-2012, 02:38 PM   #6267
07wrx84
Member#: 252195
07 WFC #900
@ 451awhp-404awtq
What were your driving habits most time?
Old 09-11-2012, 02:52 PM   #6268
smeerone
Member#: 249068
2010 WRX
DGM Phatbotti Tuned
So, I'm not sure if you answered this Ron, is the voltage a mechanical fix like increasing the voltage on the FP or is it a data table fix? Also the second part is would a 3bar MAP sensor help?
Old 09-11-2012, 02:56 PM   #6269
Phatron
Member#: 36033
CEO PhatBottiTuning
yes i answered it. its a table fix. increasing the MAP high voltage CEL trip point
Old 09-11-2012, 03:00 PM   #6270
smeerone
Member#: 249068
2010 WRX
DGM Phatbotti Tuned
Sorry missed that. Ok so It's not too bad. Would that CEL cause any other drivability issues that you are aware of?
Old 09-11-2012, 03:21 PM   #6271
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
2.5's crack pistons very easily.
What does "one season" mean? Track car? Minimal miles? Or is it a daily driver?
Daily driven. WOT pulls through the gears once a day or so (varied). Didn't overly beat on it, but I used the power on a regular basis. No track days at all.
Old 09-11-2012, 03:56 PM   #6272
jnorth85
Member#: 76785
SRP
Track days, drag events, and a few shows.
in other words when I drive it. I drive it very hard.
It just lasted 7 20:00 sessions in 90+ heat at 26 psi
Old 09-12-2012, 06:12 PM   #6273
breaksOFTEN
Member#: 260549
'69 Camaro '76XS750
'77CB750
So stock heat range is the way to go for E85 huh. Guess I should switch them out, since I have been running one step colder and the starts are really rough, but I have no other driving issues or knock.
No tuning changes are necessary correct?
breaksOFTEN is offline   Reply With Quote
Old 09-12-2012, 06:16 PM   #6274
amalgrover
Member#: 183480
2009 Forester XT
i'm a big believer in stock heat range for 90% of the setups on here no matter what fuel it is...
and no, no tune changes are needed for the swap back to stock heat range spark plugs.
Old 09-12-2012, 06:58 PM   #6275
Nuke209
Member#: 108089
2003 WRX
NF Performance
ffs + lc, stock pistons dont like as much lol
Nuke209 is offline   Reply With Quote
Motion Lab Tuned: Juanmedina's 2007 WRX E85 ARMY Motion Lab Tuning Proven Power Bragging 125 04-12-2010 02:57 AM
jid2 Track Car - e85 ARMY jid2 Member's Car Gallery 38 01-22-2010 10:44 PM
The Honduran army is the bravest in the world... wrxcelent Off-Topic 36 07-07-2009 08:21 AM
Spacific E85 Tuning thread Here ? discopotato03 Engine Management & Tuning 1 09-09-2008 11:01 AM
Did anyone hear the one about the Italian army and the IRAQI satiation? Asinine Off-Topic 3 09-20-2005 07:06 PM
