Old 09-15-2012, 03:26 PM   #6351
wrxsubiemod
Member#: 165104
E85 SoCalPorting
Owner
Nice setup
wrxsubiemod is offline   Reply With Quote
Old 09-15-2012, 03:36 PM   #6352
elbertmurphy
Member#: 268256
2005 STI
Originally Posted by Nuke209 View Post
new or used?
new everything
elbertmurphy is offline   Reply With Quote
Old 09-15-2012, 04:13 PM   #6353
breaksOFTEN
Member#: 260549
'69 Camaro '76XS750
'77CB750
Originally Posted by yo6bd
I'm using a GM sensor out of a totaled Tahoe. Along with the wiring harness and digital readout from zeitronics. I wired it in with my gauges so it comes on at the same time.
And I designed the bracket in solidworks.
Super clean set-up! Hope I can get one of those brackets from you when I get my ECA. Should help with tuning the different E blends
breaksOFTEN is offline   Reply With Quote
Old 09-15-2012, 04:20 PM   #6354
yo6bd
Member#: 196887
2010 Corn <3'er
361WHP/444WTQ stock turbo
I have a second one sitting right in front of me!
yo6bd is offline   Reply With Quote
Old 09-15-2012, 04:25 PM   #6355
07wrx84
Member#: 252195
07 WFC #900
@ 451awhp-404awtq
That's awesome!
07wrx84 is offline   Reply With Quote
Old 09-15-2012, 05:35 PM   #6356
07wrx84
Member#: 252195
07 WFC #900
@ 451awhp-404awtq
Have any of you disabled closed-loop fueling (run open-loop always)?
Old 09-15-2012, 06:08 PM   #6357
wrxsubiemod
Member#: 165104
E85 SoCalPorting
Owner
Yeah its the speed density guys. I think with Cobb you can have a transition between CL and OL
Old 09-15-2012, 06:16 PM   #6358
amalgrover
Member#: 183480
2011 Audi A3 Quattro
2009 Forester XT
well, there are guys not on speed density that do it sometimes as well. i will do it sometimes for tuning, but always turn CL back on. there are, however, some people that run their MAF based cars in OL all the time. you are going to lose some MPG doing this, which is why i don't choose to do it on my vehicles.
amalgrover is offline   Reply With Quote
Old 09-15-2012, 06:20 PM   #6359
07wrx84
Member#: 252195
07 WFC #900
@ 451awhp-404awtq
I thinkin bout disabling just for fun. Im tuned speed density, but my car is not a dd so mpg not a big deal to me. Speed density hates life at idle lol.
Old 09-15-2012, 06:24 PM   #6360
amalgrover
Member#: 183480
2009 Forester XT
interesting you should say that because most higher whp speed density setups run significantly smoother across the board than higher whp maf based setups
Old 09-15-2012, 06:28 PM   #6361
punchjamesarnol
Member#: 284835
2014 Hyundai Equus
White Pearl Mica
Why would you disable the CL to OL? thats what you get when your front wideband 02 sensor goes bad... you'll be dumping a lot of gas.
nevermind... just read your SD...
punchjamesarnol is offline   Reply With Quote
Old 09-15-2012, 06:38 PM   #6362
amalgrover
Member#: 183480
2009 Forester XT
when your front o2 sensor goes bad you go into a half-assed speed density/limp mode map. this is not the same thing that happens when you disable the CL fueling.
Old 09-15-2012, 06:45 PM   #6363
07wrx84
Member#: 252195
07 WFC #900
@ 451awhp-404awtq
Had to turn up my idle to about 950-1000 rpm so it wouldnt die. But I think best thing would be run maf/SD...
Old 09-15-2012, 06:48 PM   #6364
Phatron
Member#: 36033
CEO PhatBottiTuning
2006 STi GTX3582 + Meth
thats a misconception most people have about SD. CL is still there and all the fueling corrections, just like MAF....so you still experience the same issues with 02 sensors going bad and causing hesitations and random fueling. you can turn off the front 02 just like with maf but as was already pointed out, you'll prob see a drop in mpg.
Old 09-15-2012, 06:51 PM   #6365
amalgrover
Member#: 183480
2009 Forester XT
950-1000rpm isn't bad at all...hell, mine wouldn't idle lower than 1050-1150 smoothly. anything 1000rpm or less and it would have a little bit of a surging rpm, misfire pretty badly, and during cold weather if i coasted to a stop with the clutch pressed, the car would stall occasionally. just 50-100 rpm higher, and all these problems went away and it ran and idle VERY well.
i am on maf not sd...usually sd helps get rid of alot of these issues because you don't have the drastically reduced resolution from running larger maf housings.
Old 09-15-2012, 06:55 PM   #6366
Phatron
Member#: 36033
CEO PhatBottiTuning
^ most of the idle issues and misfires are caused by the larger injectors imo and not the maf. running a big ass injector at low ipw is like asking a fire hose to behave like a garden hose.
my 89mm maf idled fine. there was only one spot when cruising ~75mph that SD cleared up over that. everything else i dont feel a difference at all.
Old 09-15-2012, 06:56 PM   #6367
07wrx84
Member#: 252195
07 WFC #900
@ 451awhp-404awtq
Even if CL disabled?
Mmm... Interesting ya cuz most DSM guys there idles are crazy high from what I have witnessed! I had a few misfires in the beggining but I had my avcs maxed at idle ( whooops ) lol..
Old 09-15-2012, 07:02 PM   #6368
Phatron
Member#: 36033
CEO PhatBottiTuning
i dont understand the question.....
if you disable CL, you're disabling the front02's ability to make corrections. so if you disable it, then you wouldnt experience any problems from it going bad.
Old 09-15-2012, 07:05 PM   #6369
amalgrover
Member#: 183480
2009 Forester XT
^ what he said...when CL is disabled, it essentially is just there to plug a hole in the exhaust and give you a narrowband o2 sensor to log.
Old 09-15-2012, 07:06 PM   #6370
07wrx84
Member#: 252195
07 WFC #900
@ 451awhp-404awtq
Oh ok ok!
Old 09-15-2012, 07:42 PM   #6371
Phatron
Member#: 36033
CEO PhatBottiTuning
the other downside of removing CL (the front 02) is that you dont allow the ecu to correct for any leaks. so if you pop a leak the car may be undrivable without the corrections.
Old 09-15-2012, 09:09 PM   #6372
07wrx84
Member#: 252195
07 WFC #900
@ 451awhp-404awtq
I see where your coming from now! Thanks
Old 09-16-2012, 07:43 PM   #6373
mecpgh
Member#: 193014
02 WRX WRB, 05 STI
FPGreen E85 400+whp
Originally Posted by MainFrame
Yea, mine kept sticking (either open or closed). I know one other person locally that lost a built motor to them and at least five other cars that had issues with them. Honestly, I thought DW had pulled them off the market because from what I've seen 100% of them had varying degrees of problems.
Are you guys seeing the sticking and wot or any idc? I would like to get the car out to put some miles on it if i can
mecpgh is offline   Reply With Quote
Old 09-16-2012, 08:26 PM   #6374
MainFrame
Member#: 218739
2002 WRX hybrid
One set just stuck open 100% of the time, the car would start but it would barely idle because one cylinder was just dumping fuel and it was undriveable. Another set seemed okay at first, but once the car warmed up it wouldn't idle, constantly died. AFR while cruising was all over the place. It seemed like WOT ran better than anything else, but AFR was still inconsistent. Another set idled fine and was okay under really low load, but if you tried WOT it would go really lean and the more fuel you would add to the map the leaner it would get.
My understanding was that a few other cars ran fine with them for a month or two before they went down hill. Another set I know was running fine until one injector stuck shut in the middle of a WOT dyno pull and blew the motor.
MainFrame is offline   Reply With Quote
Old 09-16-2012, 08:49 PM   #6375
mecpgh
Member#: 193014
02 WRX WRB, 05 STI
FPGreen E85 400+whp
Ok thanks for the info. i guess I'm going to send my five o 1600s in and see of i can get a new set or maybe the 1200s since the seem to be better quality.
Motion Lab Tuned: Juanmedina's 2007 WRX E85 ARMY Motion Lab Tuning Proven Power Bragging 125 04-12-2010 02:57 AM
jid2 Track Car - e85 ARMY jid2 Member's Car Gallery 38 01-22-2010 10:44 PM
The Honduran army is the bravest in the world... wrxcelent Off-Topic 36 07-07-2009 08:21 AM
Spacific E85 Tuning thread Here ? discopotato03 Engine Management & Tuning 1 09-09-2008 11:01 AM
Did anyone hear the one about the Italian army and the IRAQI satiation? Asinine Off-Topic 3 09-20-2005 07:06 PM
