Old 09-16-2012, 09:29 PM   #6376
MainFrame
Member#: 218739
2002 WRX hybrid
Originally Posted by mecpgh View Post
Ok thanks for the info. i guess I'm going to send my five o 1600s in and see of i can get a new set or maybe the 1200s since the seem to be better quality.
I've been told that the 1200s are good, but 1600s are hit or miss.
MainFrame is offline   Reply With Quote
Old 09-16-2012, 09:54 PM   #6377
baseballdbk1
Member#: 242700
2015 Impreza Wrx
Why not just get a set of fic 2150 injectors and call it a day?
baseballdbk1 is offline   Reply With Quote
Old 09-16-2012, 09:58 PM   #6378
maxpowr
Member#: 159243
sg3 Turbo Tek Tuned
Hakt Ecu e85 30r 6spd
gonna give my dw1300s a shot of E tomorrow.
maxpowr is offline   Reply With Quote
Old 09-16-2012, 10:17 PM   #6379
mecpgh
Member#: 193014
02 WRX WRB, 05 STI
FPGreen E85 400+whp
Because there $780 but the thought did cross my mind
mecpgh is offline   Reply With Quote
Old 09-16-2012, 10:36 PM   #6380
baseballdbk1
Member#: 242700
2015 Impreza Wrx
Yes they are higher in price but i would not want to go cheap on something such as injectors...
They idle perfectly on pump gas and of course E85 an they are consistent across the board!
Old 09-16-2012, 11:07 PM   #6381
mecpgh
Member#: 193014
02 WRX WRB, 05 STI
FPGreen E85 400+whp
On stock ecu?
Old 09-16-2012, 11:12 PM   #6382
baseballdbk1
Member#: 242700
2015 Impreza Wrx
On stock ecu?
Yep! Runs like a champ on stock ecu!
Old 09-16-2012, 11:58 PM   #6383
amalgrover
Member#: 183480
2011 Audi A3 Quattro
2009 Forester XT
maybe in your case, but that doesn't mean they will do the same in his case.
plus, i'm sure 2150cc is overkill by a HUGE amount for mecpgh's setup. i love the FIC injectors (i run the bluemax 1250's in my bugeye currently), but there are other sizes offered that would be much better matched to his setup...not to mention other sizes that would be MUCH cheaper for him.
amalgrover is offline   Reply With Quote
Old 09-17-2012, 12:40 AM   #6384
baseballdbk1
Member#: 242700
2015 Impreza Wrx
On stock ecu?
what type of setup are you planning on running power wise so i can get an idea of what injector size would be the best... turbo, boost level, built/stock bottom end, fuel setup, etc
Old 09-17-2012, 01:56 AM   #6385
rymaggi
Member#: 253442
Anyone running a wrx factory 5spd with e85? hows it holding up, and how many miles have you put on it? And how long do you think you have tell you will need to upgrade your tranny?
rymaggi is offline   Reply With Quote
Old 09-17-2012, 05:01 AM   #6386
mecpgh
Member#: 193014
02 WRX WRB, 05 STI
FPGreen E85 400+whp
Already made over 400 whp with the five o1600s i previously had installed, og fp green 23psi, ewg, el headers, fmic,stock block stock fuel lines, Perrin V1 rails, dw300 pump. More than likely i am going to build myself a rotated setup soon and a NEW fuel system.
Old 09-17-2012, 07:04 AM   #6387
fastblueufo
Member#: 212154
02 billet crank
pauter rods, pt5857, E85
If your looking for quality in five-0 injectors your crazy. Even the top feeds are junk. Doesn't matter if there 850 or 1400cc. You may get a set of 850cc to tune out decent. But, put some miles on them and they eventually start having problems. Why risk a lower than 50% chance that the first injector set you get tunes out good when you can buy a better brand for 100 bucks more and get a good set right out of the box. Five-0 injectors are just to hit and miss to even risk using there ****. That whole company can kiss my ass. They have been selling the same crap for injectors for years. They had the same problems when they first started selling them as they do now. The product hasn't gotten better over the past few years. That tells me the company doesn't care about quality at all. Sure they may swap a set with no troubles. But, the second set is usually one to give problems also. And its usually the same problems as the first set.
fastblueufo is offline   Reply With Quote
Old 09-17-2012, 07:44 AM   #6388
mecpgh
Member#: 193014
02 WRX WRB, 05 STI
FPGreen E85 400+whp
Ya i agree i was only thinking about seeing if i could trade then out but i really don't want another set of them either. Someone sell your 700+hp E fuel system to me used so i don't have to go through all the hassle from scratch
Old 09-17-2012, 10:08 AM   #6389
amalgrover
Member#: 183480
2009 Forester XT
well, if my car doesn't sell in the next month, i am planning on parting it out, and you can buy my fuel system. it isn't quite 700whp on E type good, but it is good to probably 550whp airboy on stock fuel pressure. with some additional fuel pressure, it would probably get you to 600+whp airboy.
Old 09-17-2012, 10:15 AM   #6390
mecpgh
Member#: 193014
02 WRX WRB, 05 STI
FPGreen E85 400+whp
Ya cool what is your fuel setup?
Old 09-17-2012, 10:41 AM   #6391
WRXt4cy
Member#: 172698
11 STi BW 8374 E85
02 v8 Spec C E85
I'm a little confused and maybe I haven't done enough research, but my understanding was that FiveO, like any other company that sells injectors, doesn't "build" injectors; they mod or flow match sets of injectors built by other companies. For example, as I understand it, the 026IMP1000 injectors they sell are just Bosch EV14's. FiveO buys them in bulk and tests and flow matches them and sells them in sets. Is that not the case?
If not, what it is about FiveO injectors that makes them so inferior to say the FIC injectors? Where does FIC get their injectors and what makes them better?
I'm not wanting to argue or debate. I simply want to understand what makes them so much better.
WRXt4cy is offline   Reply With Quote
Old 09-17-2012, 12:35 PM   #6392
amalgrover
Member#: 183480
2009 Forester XT
mine is actually a pretty simple setup compared to alot of people's...
--FIC Bluemax 1250cc low impedance injectors
--P&L Motorsports injector resistor pack
--DW300 fuel pump
--Kenne Bell Boost-A-Pump
...the fuel pump with the boost-a-pump on it can flow almost [email protected] fuel pressure with 30psi of boost. the injector flow sheets from FIC have the injectors flowing [email protected], give or take about 5cc.
like i said, i don't know just yet if it is getting parted out, but as of right now, there really hasn't been a whole lot of serious interest in buying my car so...odds are pretty good that it will be getting parted out in about 3-4 weeks. i will keep you posted on things though.
Old 09-17-2012, 01:11 PM   #6393
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
Anyone with an 08+ WRX or STI (ie. plastic fuel pump housing) know which color wire needs to be spliced into to hard wire the fuel pump? Like this, but for the newer models:
http://forums.nasioc.com/forums/show....php?t=2382384
xluben is offline   Reply With Quote
Old 09-17-2012, 01:35 PM   #6394
fastblueufo
Member#: 212154
02 billet crank
I'm not sure what type injectors they buy and sell. Whatever they are doesn't matter much when bottom line is, THEY SUCK! Five-0 just keeps selling the same crap injectors for years and doesn't try selling a better injector. They would rather just replace the tons of bad ones or better yet, have the customer just eat the money spent on there injectors only to spend more money on a better set. I've seen that done more than once.
Old 09-17-2012, 01:50 PM   #6395
jnorth85
Member#: 76785
2000 580Whp The RSTI
SRP
You do realize they sell the same type of injectors other company's sell right? Denso, Bosch, etc. The EV14 injector body is the same injector ID sells.
jnorth85 is offline   Reply With Quote
Old 09-17-2012, 02:41 PM   #6396
WRXt4cy
Member#: 172698
11 STi BW 8374 E85
02 v8 Spec C E85
Yeah... it seems like every injector distributor has their people that love them and their people that hate them.
My personal experience with FiveO's has been a good one. They seem to offer the same injectors as the other distributors but at a lower price. I've seen lots of people that have good luck with them and I've seen others that haven't. I noticed a lot of people having trouble with their side feeds for whatever reason. I think it was actually you that I asked on RomRaider what you recommend for sidefeeds and you steered me towards Deatschwerks which I've been recommending them ever since but I continue to recommend FiveO's topfeed Bosch EV14 injectors and haven't seen a singe issue in at least 10 sets of them now.
I just want to understand more about the mysterious world of fuel injectors. They seem like a pretty basic piece of hardware really with only a few notable differences in design type. I am by no means saying a person should just go get injectors from anywhere and they will be great, but it just seems odd that experiences vary so much between one set to the next.
Old 09-17-2012, 02:49 PM   #6397
fastblueufo
Member#: 212154
02 billet crank
It may be the same body but the final product that they sell sucks. Why do there injectors have so much trouble? Because just an injector body does not make a whole injector. I'm pretty sure they prol buy the final injector from a company (prol in china). There are very few shops that actually sell products that they actually make themselves, especially in the import scene. Most of these name brand products that you see advertised in mags and online are actually made in china and other countrys, very few actually come from japan or the US, and most are cheaply made.
Old 09-17-2012, 02:57 PM   #6398
jnorth85
Member#: 76785
SRP
What!? No. I believe you are a little off base here. I have a pretty strong knowledge of international business and how the aftermarket parts world works. If they sold Chinese junk inside a Bosch housing they would be shut down quickly
Old 09-17-2012, 03:02 PM   #6399
fastblueufo
Member#: 212154
02 billet crank
They don't put junk in the housings, its the tips and pintle that are often modified by a company and then sold under another company's name . Strong knowledge there son.
Old 09-17-2012, 03:04 PM   #6400
sackytar
Member#: 149262
03WR Rallycar/FXT/OB
PrimerGrey
Regardless of where they are manufactured. I am on my second set, still having issues with them and am very reluctant to put a third in.
sackytar is offline   Reply With Quote
Motion Lab Tuned: Juanmedina's 2007 WRX E85 ARMY Motion Lab Tuning Proven Power Bragging 125 04-12-2010 02:57 AM
jid2 Track Car - e85 ARMY jid2 Member's Car Gallery 38 01-22-2010 10:44 PM
The Honduran army is the bravest in the world... wrxcelent Off-Topic 36 07-07-2009 08:21 AM
Spacific E85 Tuning thread Here ? discopotato03 Engine Management & Tuning 1 09-09-2008 11:01 AM
Did anyone hear the one about the Italian army and the IRAQI satiation? Asinine Off-Topic 3 09-20-2005 07:06 PM
