Welcome to the North American Subaru Impreza Owners Club Thursday June 20, 2013
Old 09-17-2012, 03:13 PM   #6401
jnorth85
Member#: 76785
2000 RSTi Coupe
SRP
Originally Posted by fastblueufo
They don't put junk in the housings, its the tips and pintle that are often modified by a company and then sold under another company's name . Strong knowledge there son.
Correct. But many of these injectors are not "modified" injectors they are simply manufacturing at a higher flow rate.
jnorth85 is offline   Reply With Quote
Old 09-17-2012, 03:18 PM   #6402
WRXt4cy
Member#: 172698
11 STi Stg2 E85
02 v8 Spec C E85
Go on... I don't want to hear simply that "Injectors X suck because people have had isuses with them". I want to understand what exactly the differences are that make one injector perform better than another. I haven't been able to get a good handle on this or I haven't been looking in the right places to find the information myself.
For example, when I was injector shopping, I compared ID1000 topfeeds to FiveO topfeeds. I did my research and found that there were equal parts of people saying ID's "sucked" as parts of people saying FiveOs "sucked" so that didn't help. From what I found, it seemed that both companies were buying Bosch EV14 based injectors, flow testing them and matching up sets to sell. ID's seemed to flow closer to 900ccs, FiveO's seemed to flow closer to 1000cc and the FiveOs were quite a bit cheaper. The opinions from people who had tuned both sets seemed to indicate they were equal on that level so I went with FiveOs.
WRXt4cy is offline   Reply With Quote
Old 09-17-2012, 03:41 PM   #6403
MainFrame
Member#: 218739
2002 WRX hybrid
I'm not sure what type injectors they buy and sell. Whatever they are doesn't matter much when bottom line is, THEY SUCK! Five-0 just keeps selling the same crap injectors for years and doesn't try selling a better injector. They would rather just replace the tons of bad ones or better yet, have the customer just eat the money spent on there injectors only to spend more money on a better set. I've seen that done more than once.
Sounds like my experiences with Deatschwerks.. although most people seemed to like the DWs, until shortly after I get my first set of 1300s installed, then all of a sudden everyone was having problems with them. I gave them three tries.. the second time I called DW personally and asked if they could be sure to test and verify my injectors were working before they sent them out. They said they test all injectors prior to shipping and they insured I would not have any problems with this set. Of course as soon as I had them in the car and tried to scale them I knew they were junk.
MainFrame is offline   Reply With Quote
Old 09-17-2012, 04:27 PM   #6404
baseballdbk1
Member#: 242700
2011 Impreza Wrx Sti
Originally Posted by mecpgh
Already made over 400 whp with the five o1600s i previously had installed, og fp green 23psi, ewg, el headers, fmic,stock block stock fuel lines, Perrin V1 rails, dw300 pump. More than likely i am going to build myself a rotated setup soon and a NEW fuel system.
Like i said before, just get the fic 2150 injectors and be happy! :-)
baseballdbk1 is offline   Reply With Quote
Old 09-17-2012, 04:51 PM   #6405
Concillian
Member#: 4414
2002 WRX Sedan
Midnight Black
Originally Posted by rymaggi View Post
Anyone running a wrx factory 5spd with e85? hows it holding up, and how many miles have you put on it? And how long do you think you have tell you will need to upgrade your tranny?
I am... an 02 that has ~180k miles, but not insane power. It didn't feel like it was going to be happy with the TD04 at 22 psi though. I could put serious shock load abuse into it. On the 18g it's been holding on E85 for a year or two, but I don't beat up on my tranny. Onramp here and there, no racing.
I'm going to re-build soon, and I plan on tuning the boost curve to limit torque to keep things from being too out of control. probably around 300 airboy. That's about my peak torque now, but after rebuild and a different turbo, I'm hoping to have a pretty flat ~300 torque from ~3500 to 6500-7000 rather than the torque mountain by keeping boost low @ spool, and gradually tapering it up towards redline.
Concillian is offline   Reply With Quote
Old 09-17-2012, 05:50 PM   #6406
amalgrover
Member#: 183480
2011 Audi A3 Quattro
2009 Forester XT
...and like i said, why wouldn't he just get smaller/cheaper ones if there is no need for 2150cc of fuel. even if he was running something as big as a 40R, the 1680's should be fine. there really isn't much of a need to go all the way to the 2150's unless you were planning a pretty SERIOUS setup. IMO, going to something that large when it isn't needed is just increasing the chances of having issues without any real reason for it, especially if there are other options from the same company that are better suited for the setup.
amalgrover is offline   Reply With Quote
Old 09-17-2012, 06:10 PM   #6407
breaksOFTEN
Member#: 260549
69' Camaro Project,
76' Yamaha Cafe Project
What are some good injectors for a gtx3076r ? (64lb/min)I'm running dw 1100's currently but have heard they have a tendency to fail without notice, and I'm at about 90-95% idc.
Just looking to see what I could swap in there that would give me the fuel I need and not fail on me in the future.
breaksOFTEN is offline   Reply With Quote
Old 09-17-2012, 06:52 PM   #6408
baseballdbk1
Member#: 242700
What is your problem with a reliable injector that idles perfectly on pump gas, he will have plenty of injector using E85 when he upgrades to a rotated kit, and does not have the problems like the 1600 cores that are prone to failure?
I spoken with DW and FIC about why they do not use a mid-range injector size such as the 1600 and both have told me that there is a problem with the cores that causes inconsistency...
so why not just go bigger with a higher reliability factor and consistency while being able to idle perfectly on pump @ 14.7:1?
Old 09-17-2012, 08:21 PM   #6409
maxpowr
Member#: 159243
sg3 Turbo Tek Tuned
Hakt Ecu e85 30r 6spd
so i bought a used set of dw1300s. less than an hour on them. installed them and had surging at low rpm low speed cruise.
since i was the second owner they would not refund them. they would however sell me a set of ev-14 bodied dw1000s for 400$ plus my 1300cc cores. or send my cores in and they would exchange them for 112$.
not looking forward to downtime from having a car with no injectors, which could be over a week, RAY and i decided to try them on e85.
GREAT SUCCESS!
big up ray of turbotek tuning.
maxpowr is offline   Reply With Quote
Old 09-17-2012, 08:34 PM   #6410
mecpgh
Member#: 193014
02 WRX WRB, 05 STI
FPGreen E85 400+whp
GREAT SUCCESS!
Ya the set i have idle and cruise great even with 3 month old E in the tank i just don't want to get stuck now that I'm hearing these other horror stories
mecpgh is offline   Reply With Quote
Old 09-17-2012, 08:36 PM   #6411
Phatron
Member#: 36033
CEO PhatBottiTuning
2006 STi GTX3582 + Meth
Having an injector that still doesn't work on pump isn't really a great solution though. Most of them work on e85 because of the additional fuel needs.
Old 09-17-2012, 08:50 PM   #6412
maxpowr
Member#: 159243
sg3 Turbo Tek Tuned
supposed to be a temporary solution, but they work pretty well so far.
plus my goals arent tremendous. 450whp/400tq.
Old 09-17-2012, 09:05 PM   #6413
maxpowr
Member#: 159243
sg3 Turbo Tek Tuned
Old 09-17-2012, 09:18 PM   #6414
xluben
Member#: 261612
2011 WRX 5 Door
NF Performance Stage 1
^Agreed.
Originally Posted by xluben View Post
Anyone with an 08+ WRX or STI (ie. plastic fuel pump housing) know which color wire needs to be spliced into to hard wire the fuel pump? Like this, but for the newer models:
http://forums.nasioc.com/forums/show....php?t=2382384
^Anyone?
xluben is offline   Reply With Quote
Old 09-17-2012, 09:59 PM   #6415
yo6bd
Member#: 196887
2010 Corn <3'er
361WHP/444WTQ stock turbo
^Anyone?
I was going to do this but decided not to on stock turbo. I think I may have found a thread somewhere, can't remember. You could just take a volt meter and check which wire is hot when you turn the key on.
yo6bd is offline   Reply With Quote
Old 09-17-2012, 10:39 PM   #6416
amalgrover
Member#: 183480
2009 Forester XT
interesting that FIC would say something like that since they DEFINITELY sell injectors that are 1450cc and 1650cc.
obviously, i am not against FIC injectors considering i am running a set of bluemax 1250's. i am against going almost double the injector size needed if it isn't necessary, because no matter how good your's idles on pump gas, not everyone's will be like that. if every car was like that, FIC wouldn't sell something like the FIC Injector Easy Tune Box.
Old 09-17-2012, 10:52 PM   #6417
mecpgh
Member#: 193014
02 WRX WRB, 05 STI
FPGreen E85 400+whp
Ya^^ considering my five o 16s idled crappy in high heat, better in winter temps and nearly perfect with the a/c on, slight extra load. I figure if I didn't have a light flywheel and clutch that it would be smoother.
So there its going to be alot of variances in the success of a particular injector based on climate , tuner/amount of time spent on dialing them in, and the individual setup before even considering the difference between pump gas end E85
That is why i spent so much time with this one set of injectors. I wanted to be sure that it wasn't something external too the injectors
Old 09-17-2012, 11:00 PM   #6418
Phatron
Member#: 36033
CEO PhatBottiTuning
It was id that pulled there 1600's due to fuel temp fluctuation problems.
Old 09-18-2012, 12:45 AM   #6419
baseballdbk1
Member#: 242700
look at the subaru injector options... nothing between 1100 and 2150
he said he was running 1600cc injectors and will soon be going rotated...
whats the problem with giving yourself room to work with and never having to run an IDC close to 85-90% where it becomes static?
Old 09-18-2012, 12:46 AM   #6420
baseballdbk1
Member#: 242700
as well as FIC and DW will not use the bosch 1600 cores due to the inconsistencies...
I had talk to many people over the winter bcz i was "possibly" gonna step down to a smaller injector but every person/company that I had talk to strongly recommended sticking with the 2150 injectors based on all the problems seen with the 1600 injectors
Old 09-18-2012, 12:58 AM   #6421
baseballdbk1
Member#: 242700
http://www.evoxforums.com/forums/showthread.php?t=51468
There have been a few post on why people are having fueling issues, Injector Dynamics has just finished some real world testing in there rolling test car and are issuing a RECALL on all the 1600cc injectors they have sold.
Hi all,
Anyone with ID1600's please contact me to exchange them.
July 15, 2011
The Injector Dynamics ID1600 has been discontinued due to excessive fuel temperature
sensitivity which was recently revealed by ongoing product testing.
Additional testing was prompted by customer feedback suggesting that the ID1600 exhibited
reduced flow rates when operated with high fuel temperatures.
Extensive on-vehicle testing was performed while varying fuel temperature, and the results
confirmed two things:
1. The ID1600 did in fact exhibit temperature sensitivity with flow decreasing as fuel temperature
increased.
2. The temperature sensitivity was not linear and became extreme at high temperatures.
These test results explained why the reported problems were limited to those performing
extended chassis dyno tuning, or driving in hot climates with fuel systems prone to fuel heating.
The results also explained why the overwhelming majority reported no problems, and why our
initial on-vehicle and flow bench testing showed that the ID1600 met our standards.
---->Now these injectors they are recalling use the same body the FIC 1680's do so they will have the same issue (and have shown the same symptoms)<---
Old 09-18-2012, 01:05 AM   #6422
Phatron
Member#: 36033
CEO PhatBottiTuning
That was over a year ago...not just now. I believe I posted that link and quote in this thread already. And last I read on fic is that they weren't pulling them....did they change their minds recently? Last i read on Fic was posting on Evom that they only had like 1% of 1600's owners complain so they weren't recalling. May have changed though.
Old 09-18-2012, 01:12 AM   #6423
baseballdbk1
Member#: 242700
I do not know if it is a recent thing either which is why is was confused when i talked to all these people over the winter looking into buying 1600s when i was somewhat concerned about how the 2150s would be if i needed to run pump but no worries now...
i know a few people that run fic 1600 injectors in their subies for a long time with no known issues but then you cant buy them anymore?
Old 09-18-2012, 07:38 AM   #6424
amalgrover
Member#: 183480
2009 Forester XT
yes, look at the subaru injector options. there is a tab that says low-z or high-z. click on the low-z tab, and you will see the in-between sizes . just because they aren't plug&play doesn't mean they aren't an option. also, evo injectors fit as well with a 5/8" spacer on the fuel rail. so there are even more options there.
Old 09-18-2012, 10:52 AM   #6425
explicithero
Member#: 15893
2004 STi
white
The FIC 1600 was having an issue of internal parts Melting because fuel temps got to high while running pump gas. They work great for E85. I happen to know of two sets for sale one brand new and one set with about 2000 miles on them.
Also ID will e bringing out a 1400-1800cc injector soon. No word that I have heard o what the exact specs are.
explicithero is offline   Reply With Quote
Motion Lab Tuned: Juanmedina's 2007 WRX E85 ARMY Motion Lab Tuning Proven Power Bragging 125 04-12-2010 02:57 AM
jid2 Track Car - e85 ARMY jid2 Member's Car Gallery 38 01-22-2010 10:44 PM
The Honduran army is the bravest in the world... wrxcelent Off-Topic 36 07-07-2009 08:21 AM
Spacific E85 Tuning thread Here ? discopotato03 Engine Management & Tuning 1 09-09-2008 11:01 AM
Did anyone hear the one about the Italian army and the IRAQI satiation? Asinine Off-Topic 3 09-20-2005 07:06 PM
Message Board Statistics All times are GMT -4. The time now is 04:10 AM.
