Old 10-19-2012, 09:48 PM   #6551
maxpowr
Member#: 159243
sg3 Turbo Tek Tuned
Hakt Ecu e85 30r 6spd
OEM pistons?
maxpowr is offline   Reply With Quote
Old 10-20-2012, 12:31 AM   #6552
jnorth85
Member#: 76785
2000 RSTi Coupe
SRP
Originally Posted by maxpowr
OEM pistons?
I am personally making over 500 on oem pistons with E85
jnorth85 is offline   Reply With Quote
Old 10-20-2012, 11:18 AM   #6553
Maxwell Power
Member#: 190729
OEM pistons?
Yes. The brz is 12.5:1 from the factory.
The whole engine is stock minus the bolt ons. It ran an 11.3 in the quarter.
Maxwell Power is offline   Reply With Quote
Old 10-20-2012, 12:35 PM   #6554
juanmedina
Member#: 133146
07 FPgreen 7.37@95
WRX VF39+E85 12.0, 121mph
The brz/fr-s are making 540whp dynojet this days on the 100% stock motor
Old 10-20-2012, 02:00 PM   #6555
karlknaupp
Member#: 60871
2004 WRB WRX
'10 WRB STI SE stg2
Which is crazy sick!! need some of that power.
karlknaupp is offline   Reply With Quote
Old 10-20-2012, 02:29 PM   #6556
maxpowr
Member#: 159243
sg3 Turbo Tek Tuned
guess we will see how long it lasts at that power level.
Old 10-20-2012, 02:40 PM   #6557
Junior2JZ
Member#: 64908
10.8 XT+ Real stock
turbo record holder 11.4
STI can and have made the same power on stock motors as well.
Junior2JZ is offline   Reply With Quote
Old 10-20-2012, 09:44 PM   #6558
jnorth85
Member#: 76785
2000 RSTi Coupe
SRP
E85 is a very safe fuel with out the fear of detonation you can really push the stock motor.
Old 10-21-2012, 05:38 AM   #6559
sackytar
Member#: 149262
2003 03WRXw6sp/05FXT
Yeah that's a lot of boom for a stock engine.
sackytar is online now   Reply With Quote
Old 10-21-2012, 10:23 AM   #6560
Matt_H
Member#: 107000
2008 STI <3 TXS and
2011 F150 Andrewtech
Looking for some advice here...
I'm in the process of having a motor done and will be switching over to E85, but also still have the ability to run 93 after draining the tank/lines etc.
Right now I have a DW65C (265 lph) pump, modded top feeds for fuel modifications.
With the new build I plan on running 1600cc injectors, I have a Areomotive FPR and not sure what to do with feeding the injectors. I've seen surge tanks, inline pumps, dual pumps etc. I'm not sure if I should have the DW pump feeding a surge, feeding a single pump or what.
The new setup includes:
3MI 2.35 motor
Fully build heads
GTX3582R
Flipped Cosie manifold
GT Spec exhaust manifold
Fuel rails (not purchased yet, brand recommendations?)
1600cc injectors (not purchased yet, brand recommendations?)
Areomotive FPR
My car will be a weekend/fun car and might see a 1/4 a few times a year. Looking to make big power on the new setup. I was making 430whp before I lost compression on 93 and this will be the first time running E85.
Matt_H is offline   Reply With Quote
Old 10-21-2012, 11:31 AM   #6561
TickTack
Member#: 100353
I only got a few hundred miles on my new build, but I had good luck with the fiveo 1600cc top feed injectors (http://www.fiveomotorsport.com/1600c...import-fit-wrx) and aeromotive fuel rails. I made my own lines using Aeroquip hose and fittings. I'd recommend using new top o-rings rather than the ones included with the injectors (there's a mcmaster p/n floating around). As far as pump, I'm running out of fuel from my hardwired DW300 at around 510whp. I'll be trying a walbro460 this fall before going to a surge tank/external pump setup next summer.
TickTack is offline   Reply With Quote
Old 10-21-2012, 11:48 AM   #6562
sackytar
Member#: 149262
3MI 2.35 motor
Fully build heads
GTX3582R
Areomotive FPR
I will say that I ran 2 sets of 50 1000cc Injectors and they ran horrible both sets. I had a 3rd mailed to me but refused to put them in. I got some ID1000s and put them in Tuesday and car idles great and i am had no issues.
With the 50 injectors I had misfires all over the place. And the part that tucks I the fuel rail was deteriorating.
I learned my lesson with them.
Mayhem tuning (Cory) is in the process of tweaking them out now. And they are night and day. Do the Injector Dynamics.
Old 10-21-2012, 12:15 PM   #6563
Matt_H
Member#: 107000
2008 STI <3 TXS and
I saw the FiveO were hit or miss, seemed like there were more common with people having problems with them. I was thinking about taking out the DW65C and swapping it out for a Walbro 400.
Looks like the Injector Dynamics 1600s are discontinued. Is it worth it to go 2000 and have the headroom or to look for another brand of 1600s?
Old 10-21-2012, 12:25 PM   #6564
sackytar
Member#: 149262
ID2000 seems to be working for people.
Old 10-21-2012, 12:45 PM   #6565
Maxwell Power
Member#: 190729
Next year there should be another injector available that will suit all our needs. I can't give specifics, but it should be Feb or March.
Old 10-21-2012, 01:04 PM   #6566
karlknaupp
Member#: 60871
2004 WRB WRX
'10 WRB STI SE stg2
Way to tease us lol
Old 10-21-2012, 01:06 PM   #6567
Zee Biker
Member#: 166005
2005 Saab 92x
Beaten Silver
Which manufacturer?
Zee Biker is offline   Reply With Quote
Old 10-21-2012, 01:26 PM   #6568
Matt_H
Member#: 107000
2008 STI <3 TXS and
Ugh. I think Micah needs at least one set early.
For me
Old 10-21-2012, 01:28 PM   #6569
Junior2JZ
Member#: 64908
10.8 XT+ Real stock
Just trapped 164mph with 1600s and e85. Injectors are now at 90% duty cycle with 60psi base pressure.
Just goes to show that a proper fuel system will go a VERY LONG WAY...
Old 10-21-2012, 02:29 PM   #6570
jnorth85
Member#: 76785
2000 RSTi Coupe
SRP
ID2000's dont agree with the stock ecu very well.
Five 0 sells many different injectors brands/types/sizes its hard to say "five O sucks" when they sell the same EV14 injector ID raves about.
That said 450whp is the limit for a DW300 rewired you cab get to around 500whp. Beyond that it's your choice..
I personally went the single pump route meaning I ran a swirl pot to feed the pump.
I went with the new and innovative fuelabs on demanded based fuel system.
Old 10-21-2012, 03:52 PM   #6571
punchjamesarnol
Member#: 284835
2010 450+whp DGM STI
DOM2.5/e85/Phatron tuned
Thats what we all say before our motor goes... Have a plan and some loot for when she goes.
Whats your setup jn85? 500 ponies is what I want next!!! I gotta re-do my fuel system, head work, mid range cams and a bigger turbo. But I have to get my wifes permission first. LOL!
punchjamesarnol is offline   Reply With Quote
Old 10-21-2012, 04:14 PM   #6572
jnorth85
Member#: 76785
2000 RSTi Coupe
SRP
I'm running a dom 3 XTR at 26psi.
Stock long block.
No issues with the motor at all but I plan on building this winter so I can push it a little more!
Old 10-23-2012, 08:47 PM   #6573
Jdub.csu
Member#: 283784
2012 SWP WRX HATCH
Stock long block.
How long have you been running that setup?
Jdub.csu is offline   Reply With Quote
Old 10-23-2012, 09:16 PM   #6574
jnorth85
Member#: 76785
2000 RSTi Coupe
SRP
I got it tuned in the spring.
I've done 4-5 30+ min sessions on a road course. Made around 15 passes on the drag strip and done a countless amount of hard driving. The car isn't my DD so when I do drive it, I drive it hard.
Old 10-23-2012, 09:37 PM   #6575
Jdub.csu
Member#: 283784
2012 SWP WRX HATCH
Ah so lower miles then but hard miles Conservative E85 tune I assume?
Motion Lab Tuned: Juanmedina's 2007 WRX E85 ARMY Motion Lab Tuning Proven Power Bragging 125 04-12-2010 02:57 AM
jid2 Track Car - e85 ARMY jid2 Member's Car Gallery 38 01-22-2010 10:44 PM
The Honduran army is the bravest in the world... wrxcelent Off-Topic 36 07-07-2009 08:21 AM
Spacific E85 Tuning thread Here ? discopotato03 Engine Management & Tuning 1 09-09-2008 11:01 AM
Did anyone hear the one about the Italian army and the IRAQI satiation? Asinine Off-Topic 3 09-20-2005 07:06 PM
Message Board Statistics All times are GMT -4. The time now is 09:26 AM.
