Old 02-20-2013, 09:45 PM   #7001
got_matt
Member#: 347730
2004 WRX
Lightbulb
04 WRX WAGON
fp 68 hta
agency power fuel rails
Walbro 400
ID 1000cc injectors
E85
102% duty cycle at stock fuel pressure
last dynoed at 24psi boost
391wph
380tq
got_matt is offline   Reply With Quote
Old 02-20-2013, 11:46 PM   #7002
sackytar
Member#: 149262
03WR Rallycar/FXT/OB
PrimerGrey
Originally Posted by got_matt View Post
04 WRX WAGON
fp 68 hta
Walbro 400
ID 1000cc injectors
E85
391wph
380tq
Stock engine?
sackytar is offline   Reply With Quote
Old 02-21-2013, 12:57 AM   #7003
Paul
Member#: 56203
00 RSTI Coupe
Twin Scroll 2.5XTR EJ207
I bet its on stock wiring
Old 02-21-2013, 01:01 AM   #7004
scoobasaurusrex
Member#: 255114
2007 wrb wrx wagon
93oct vf43 ewg
Originally Posted by Phatron View Post
325whp, yes
3k spool, yes
e85 > meth, you dont have to worry about uneven cylinder distribution or meth system failure. and e85 provides better cooling, power, lower egts, and knock protection than a single nozzle of meth. and meth runs out super fast on small turbos since you are into the meth activation point with barely any throttle input.
Sweet deal, e85 it is then.
scoobasaurusrex is offline   Reply With Quote
Old 02-21-2013, 02:28 AM   #7005
manitou
Member#: 193757
2006 XTI Limited
OBP, Junior tuned 573WHP
Originally Posted by Maxwell Power View Post
D25 heads combined with e85 is an awesome combo.
My D25 heads along with higher compression pistons are great with E85 but also great with pump gas! I recorded 25mpg on a 900 mile trip traveling at 80ish mph on mostly interstate highway driving!
Old 02-21-2013, 10:58 PM   #7006
got_matt
Member#: 347730
2004 WRX
Originally Posted by sackytar View Post
Stock engine?
2.1 stroker
Old 02-24-2013, 07:53 PM   #7007
Wes B
Member#: 348148
Those dynographs are a very nice reference for setup standards for the power you want to have
Wes B is offline   Reply With Quote
Old 02-24-2013, 08:13 PM   #7008
2.5L Monster
Member#: 307177
2k4 WRX/WRB
Shuckin' & Drivin'
Someone school me please. I'm moving to Cali this Friday and wanna tune for e85 but completely new to the subject.
I'm running DW 850cc injectors and a Walbro 255 fuel pump. Will these support e85 or no? I'm guessing I'll need aftermarket fuel rails? Anything else to replace/install when going e85? All help is appreciated.
2.5L Monster is offline   Reply With Quote
Old 02-24-2013, 08:20 PM   #7009
maxpowr
Member#: 159243
sg3 Turbo Tek Tuned
Hakt Ecu e85 30r 6spd
is there e85 where your moving?
maxpowr is offline   Reply With Quote
Old 02-24-2013, 08:22 PM   #7010
2.5L Monster
Member#: 307177
2k4 WRX/WRB
Shuckin' & Drivin'
Indeed.
Old 02-24-2013, 08:28 PM   #7011
rexblake
Member#: 178426
2010 S4
Gray
Originally Posted by 2.5L Monster View Post
Indeed.
They certainly can, just depends on your turbo size.
rexblake is offline   Reply With Quote
Old 02-24-2013, 09:06 PM   #7012
sackytar
Member#: 149262
PrimerGrey
2.5 what turbo are you trying to feed? Stock fuel rails should be fine.
Old 02-24-2013, 09:06 PM   #7013
2.5L Monster
Member#: 307177
2k4 WRX/WRB
Shuckin' & Drivin'
I'm running an FP 18g with the listed mods above. Will I be alright or should I upgrade to anything?
Old 02-24-2013, 09:09 PM   #7014
sackytar
Member#: 149262
PrimerGrey
You should be fine.
Old 02-24-2013, 09:14 PM   #7015
2.5L Monster
Member#: 307177
2k4 WRX/WRB
Shuckin' & Drivin'
So your car is a 04 wrx, I am assuming you are still rocking the 2 L or 2.5.
2L currently
Old 02-24-2013, 09:32 PM   #7016
2.5L Monster
Member#: 307177
2k4 WRX/WRB
Shuckin' & Drivin'
You should be fine.
Any clue whatsoever what kind of numbers I'll put down with the following mods and e85?
- FP 18g P/P'd
- APS Turbo-back
- APS Intake
- Godspeed catless DP
- Invidia UP
- JDM V8 STi TMIC
- 3 port ebcs
- DW 850 injectors
- Walbro 255
Soon to go EWG
Old 02-24-2013, 09:37 PM   #7017
sackytar
Member#: 149262
PrimerGrey
You should be able to get over 300 whp easy. I am running an 18g, 38mm ewg, ID 1000cc, process west tmic and getting 330 on a conservative tune.
Old 02-24-2013, 10:07 PM   #7018
2.5L Monster
Member#: 307177
2k4 WRX/WRB
Shuckin' & Drivin'
Great, thanks!
Old 02-25-2013, 11:31 AM   #7019
Boostedbob
Member#: 336241
08 Sti
OPB
Guess I should post this as well,
08 Sti
Built Bottom End
All bolt on's
Tgv Deletes with 3m Phenolic spacers
Currently on a vf48(will be getting a td06 sl2 20g put on in a few weeks
1000cc ID Injectors
300lph Detchworks Fuel pump
IDC 49% with a elevation of 6k+ feet(Colorado Springs)
Havent had a baseline done yet as I a street tuned but thinking im at 300awhp.
Boostedbob is offline   Reply With Quote
Old 02-26-2013, 01:32 PM   #7020
BrkngBnjmnFan
Member#: 330971
2005 STi
CGM
I'm sure this has already been answered in this thread, but forgive me for not wanting to read thru all 281 pages. For the guys running 100% E85 on built motors, what is the typical life expentacy of these motors? I'm strongly considering going to 100% E85 when I build my motor, but its going to be my DD for awhile and I really need it to last me around 50k miles otherwise I'll probably have to stick with just pump gas.
BrkngBnjmnFan is offline   Reply With Quote
Old 02-26-2013, 01:38 PM   #7021
340Duster
Member#: 52314
2002 PSM WRX 16G-XT
Dorothy from OZ, the XT
Your fuel choice isn't going to be the determining factor in engine longevity. It's going to be the quality of the engine build and how well the car is tuned and then maintained.
340Duster is offline   Reply With Quote
Old 02-26-2013, 01:42 PM   #7022
maxpowr
Member#: 159243
sg3 Turbo Tek Tuned
I don't think that a properly built ethanol motor has any less life expectancy than a gas engine.
If its tuned and maintained optimally, I'd bet the e85 engine which burns cooler and cleaner would actually last longer.
Old 02-26-2013, 01:43 PM   #7023
BrkngBnjmnFan
Member#: 330971
2005 STi
CGM
Ok thank you for the response. I had been told before that running only E85 shortens the life of your motor, but if that's not correct then yay for me lol. And yea I know the build quality and tune quality are everything. Now I guess I just gotta find somebody in my area who knows how to tune on E85. Thanks again
Edit: thanks for the response too maxpowr
Old 02-26-2013, 01:50 PM   #7024
340Duster
Member#: 52314
2002 PSM WRX 16G-XT
ninja!
Old 02-26-2013, 03:29 PM   #7025
WRXt4cy
Member#: 172698
11 STi BW 8374 E85
02 v8 Spec C E85
... I had been told before that running only E85 shortens the life of your motor...
Where'd ya hear that? The internet?
A lot of the local Subarus have been on E85 for around a year since people started to switch around here. I've got 12,000 miles on E85 personally. There are people that have been running E85 for much longer than this as well. A few of us have been doing Blackstone oil analysis' and the results seem to indicate that oil breaks down just slightly faster when running E85. Most of us run Rotella T6 at 2000 - 3000 mile intervals depending on usage.
WRXt4cy is offline   Reply With Quote
Motion Lab Tuned: Juanmedina's 2007 WRX E85 ARMY Motion Lab Tuning Proven Power Bragging 125 04-12-2010 03:57 AM
jid2 Track Car - e85 ARMY jid2 Member's Car Gallery 38 01-22-2010 11:44 PM
The Honduran army is the bravest in the world... wrxcelent Off-Topic 36 07-07-2009 09:21 AM
Spacific E85 Tuning thread Here ? discopotato03 Engine Management & Tuning 1 09-09-2008 12:01 PM
Did anyone hear the one about the Italian army and the IRAQI satiation? Asinine Off-Topic 3 09-20-2005 08:06 PM
