Old 03-05-2013, 10:44 PM   #7126
kpadill2
Member#: 266208
What's up guys? The car in question here is mine. I've been sorta unmotivated lately so I appreciate Cameron, who is actually my competition (says a lot about him), for trying to figure out what went wrong here.
We took the car down for end of season, my car hasn't seen a lot of track but it has REALLY gotten beaten on for the small amount of miles. The car was running and had just seen a high mph pull a few days earlier. To all of our absolute complete surprise we found two bent rods. The one cam posted and you'd really have to hold it in your hand to see it in the other rod.
A question that comes to me is when could the rod have folded and how long could it have lasted? Why would the rod fold before any real crushing of the bearing?
I appreciate the good discussion in here about the amount of timing in the tune. We are hoping to have her fired up here in a week.
There was some interesting discussion with Carrillo about this issue. We just received a new design that they had already been working on. I am told they knew exactly how the rod folded when we came to them.
This is the only image I've got of the new design. You can see some thicker ribs but it's also thicker on the rod as well
kpadill2 is offline   Reply With Quote
Old 03-05-2013, 10:56 PM   #7127
Maxwell Power
Member#: 190729
welcome to the thread!
Bearings look freakin' great with some minor pitting.
Maxwell Power is offline   Reply With Quote
Old 03-05-2013, 11:25 PM   #7128
manitou
Member#: 193757
2006 XTI Limited
OBP, Junior tuned 573WHP
I really like your car! Glad you're getting her sorted out and then a better tune! Fellow Killer B header fan!
Old 03-05-2013, 11:57 PM   #7129
amalgrover
Member#: 183480
2011 Audi A3 Quattro
2009 Forester XT
I had an Element H-beam snap clean in two on me last year after making six 0-140mph passes on a pretty aggressive map. The motor had just over 9000 miles on it, and was putting down 511whp/470wtq in Airboy's spreadsheet on this map.
After speaking with some people who also had recently lost some H-beams in similar ways (Eagle and Manley rods to be specific), it appeared that essentially for everyone for the most part it was a combo of pushing the rods too close to their rated chp as well as pushing the tune/engine too close to it's limit in terms of cylinder pressures.
Since these 2011-2012 incidents occurred, quite a few companies have released new or revised versions of their H-beams that are rated much higher than previous ones were. I have not had the opportunity to really speak with or compare the differences between the older H-beams vs. the newer ones, but if I had to guess, I would think it would be similar to the findings that you see in your picture posted above. Just a much better/thicker construction all around.
amalgrover is offline   Reply With Quote
Old 03-06-2013, 06:03 AM   #7130
juanmedina
Member#: 133146
07 FPgreen [email protected]
WRX VF39+E85 12.0, 121mph
I wonder how much added safety are we getting with the new designs?
Also, Cam how much whp and wtq was that car making?
Old 03-06-2013, 06:40 AM   #7131
manitou
Member#: 193757
2006 XTI Limited
Originally Posted by juanmedina View Post
+12345
IIRC it was making 730/670 with a GTX3582 and some correction on a Dynojet.
The rods amalgrover was referring to, the Eagles and Manleys were most likely Chinese made junk. These are the good Carrillo h beam rods, still flawed but its obvious the manufacturers have to overbuild their stuff to accommodate contingencies for poor tuning like the case here. How much strength is enough?
I am using some of Doms +2mm custom super h beams that he has made by Saenz. I believe they are rated for 1000-1200 CHP, I don't remember exactly. They won't see anything close to that in my car. If H beams rods like mine and the Carrillo pro's are not enough then you should use the Pauters or Manly I beams but they are heavier by quite a bit!
Old 03-06-2013, 07:19 AM   #7132
sackytar
Member#: 149262
03WR Rally/XTDD/98SJ
PrimerGrey
730 holy balls.
sackytar is offline   Reply With Quote
Old 03-06-2013, 08:11 AM   #7133
juanmedina
Member#: 133146
I understand that, my worry is that new H-tuff seem to similar to those carrillo rods
Old 03-06-2013, 08:26 AM   #7134
manitou
Member#: 193757
2006 XTI Limited
Originally Posted by sackytar View Post
730 holy balls.
I had been following this car as he and I are both using Killer B Holy headers. It's a beast for sure and a super nice car, very good execution of the work!
http://forums.nasioc.com/forums/show....php?t=2415750
Old 03-06-2013, 08:30 AM   #7135
TPG Tuning
Member#: 185725
Originally Posted by 06rexwagon View Post
Little beat but not horrible. Worse than I would expect from under 3k miles.
Only map he has. This is from the old e70 tune that spun a rod bearing and bent all the wrist pins at around 4k miles.
Timing was increased for the e98 tune but I don't know by how much. The aem has been sent back to get checked.
Idle timing is strange
Important to note that this is a hybrid engine with oem gasket and Cnc head chambers. Not sure of cr.
Woah!
Nate
TPG
TPG Tuning is offline   Reply With Quote
Old 03-06-2013, 08:30 AM   #7136
manitou
Member#: 193757
2006 XTI Limited
I know Juan, I am surprised that the Carrillo H pro beams wrinkled like that! I guess its a testament to the excessive amount of timing that was run in the tune. Like what Dom said from the get go!
I have not looked at the Manley H-Tuff rods. Where are they made? Are you going to tear down your motor to upgrade the rods now?
Old 03-06-2013, 09:08 AM   #7137
06rexwagon
Member#: 114730
2006 WRX Limited Wag
[email protected]
730 holy balls.
730 with a huge sae correction. 20% so uncorrected was 610 to 620.
06rexwagon is offline   Reply With Quote
Old 03-06-2013, 09:09 AM   #7138
jnorth85
Member#: 76785
2000 580Whp The RSTI
SRP
that's very good power for the altitude!
hopefully the new rods hold up to the abuse.
jnorth85 is offline   Reply With Quote
Old 03-06-2013, 09:10 AM   #7139
06rexwagon
Member#: 114730
[email protected]
Yes it is. Living at 5400' is a bummer for hp.
Hopefully mine does too. My car has the same rods and made 824 sae and 711 uncorrected on the same dyno.
Old 03-06-2013, 09:15 AM   #7140
juanmedina
Member#: 133146
I have run tons of timing 30* at redline with a FP green probably making 470whp dynojet with my 07 WRX STi rods and I never had any issues with 60k miles on the rods.
No I am not taking my motor apart, if is not broke don't fix it . But I am building a spare motor better than my current motor . I have wiseco pistons, a stock crank and a case so far and I am planning on buying either BC I-beam rods or the H-Tuff soon. I want to build this motor myself.
Old 03-06-2013, 09:17 AM   #7141
06rexwagon
Member#: 114730
[email protected]
Redline is one thing but peak tq is another. Cylinder pressure is highest at peak tq.
Old 03-06-2013, 09:22 AM   #7142
juanmedina
Member#: 133146
well probably like 18-20 at peak torque... I can remember. Now days is way safer like 9-10* less every where
Old 03-06-2013, 09:57 AM   #7143
stretchedk7
Member#: 170602
06 Wrx RWD Auto
76MM-AEM-2200's
its common knowledge the tune is very important. you can break turbo tuff rods or any other engine related part if the tune is whack....
juan your tune was/is aggressive but its a proper tune not copy and paste. the copy and paste thing happens alot now a days.
2 years ago went to japtrix built motor 35r blah blah blah-327 whp on their dyno at 20 psi.
month later doug tuned at top speed-450 at 25 psi lol. much faster, and smoother feeling car to boot. and richer afr from doug!
stretchedk7 is offline   Reply With Quote
Old 03-06-2013, 09:58 AM   #7144
stretchedk7
Member#: 170602
06 Wrx RWD Auto
76MM-AEM-2200's
and you know 20* at redline isnt the same as 20* at say 4100 rpm lol at wot
Old 03-06-2013, 11:45 AM   #7145
slowgenius
Member#: 48350
04 Jackstands
Dirty PSM
This is a fuel question for dom. When running a series fuel rail setup is it fed in a "U" formation across the alternator head to head or a "Z" formation under the intake manifold?
slowgenius is offline   Reply With Quote
Old 03-06-2013, 11:55 AM   #7146
manitou
Member#: 193757
2006 XTI Limited
Yeah maybe more like 12-14* at peak torque or less depending on build, CR and boost!
Old 03-06-2013, 12:25 PM   #7147
jnorth85
Member#: 76785
SRP
Expanding on the fuel system lay-out, the series/parallel is heavily dependent on the pump/feed line size correct? same with the pulse dampeners.
Dom please shed some light on this subject for us.
Old 03-06-2013, 12:28 PM   #7148
juanmedina
Member#: 133146
I meant that I was running 18-20* at pick torque with my FP green setup. Now I run like 12-13*
Old 03-06-2013, 12:47 PM   #7149
manitou
Member#: 193757
2006 XTI Limited
Looking at my logs I think Jr has my timing at peak tq more like 10-12* with my D25 heads & 9.6:1 CR with 26-27 psi boost.
Old 03-06-2013, 01:08 PM   #7150
stretchedk7
Member#: 170602
06 Wrx RWD Auto
76MM-AEM-2200's
roger that buddy. and dang thats still good timing for the green lol. was it safe?
Motion Lab Tuned: Juanmedina's 2007 WRX E85 ARMY Motion Lab Tuning Proven Power Bragging 125 04-12-2010 02:57 AM
jid2 Track Car - e85 ARMY jid2 Member's Car Gallery 38 01-22-2010 10:44 PM
The Honduran army is the bravest in the world... wrxcelent Off-Topic 36 07-07-2009 08:21 AM
Spacific E85 Tuning thread Here ? discopotato03 Engine Management & Tuning 1 09-09-2008 11:01 AM
Did anyone hear the one about the Italian army and the IRAQI satiation? Asinine Off-Topic 3 09-20-2005 07:06 PM
