Old 03-30-2013, 01:56 PM   #7201
manitou
Member#: 193757
2006 XTI Limited
OBP, Junior tuned 573WHP
With the 1100's and a base of 55 psi at 85% IDC, you need a pump that can can flow 253 l/hr, at 100% IDC you need 298 l/hr. With 55 psi base plus 17 psi boost equals 77 psi, the 340 at 13.5 volts and will only flow around 225 l/hr. You'll either need a boost a pump, a bigger pump or lower your base and HP goals.
Old 03-30-2013, 05:53 PM   #7202
amalgrover
Member#: 183480
2011 Audi A3 Quattro
2009 Forester XT
Like he said, the fuel pump is what is maxing out, not the injectors. You need a walbro 416 or a boost-a-pump...either one will bump your pump output up to well above 300lph.
amalgrover is offline   Reply With Quote
Old 03-30-2013, 09:07 PM   #7203
lil jon
Member#: 19044
Thank you. Picking up a walbro 465 on Monday and go from there
lil jon is offline   Reply With Quote
Old 03-30-2013, 09:50 PM   #7204
manitou
Member#: 193757
2006 XTI Limited
Do the hard wire while you are at it!
Old 03-30-2013, 09:52 PM   #7205
breaksOFTEN
Member#: 260549
'69 Camaro '76XS750
'77CB750
Is base pressure measured with vac connected?
I tried to play with my base pressure vac connected, I have an aeromotive fpr and for some reason I can't get it to go above 43 psi once the car is warmed up?
If I start it up cold and change the fuel pressure I can get it higher. Then I'll do a few pulls and check it again and the gauge will only be at 43 again???
breaksOFTEN is offline   Reply With Quote
Old 03-30-2013, 10:02 PM   #7206
manitou
Member#: 193757
2006 XTI Limited
without vacuum!
Old 03-30-2013, 10:32 PM   #7207
breaksOFTEN
Member#: 260549
'69 Camaro '76XS750
'77CB750
I have a really low base pressure then haha.
Old 03-30-2013, 10:44 PM   #7208
lil jon
Member#: 19044
i have that done all ready thanks tho!!
Old 03-30-2013, 10:50 PM   #7209
Phatron
Member#: 36033
CEO PhatBottiTuning
2006 STi GTX3582 + Meth
Increasing the fuel press on an already maxed pump is just going to make it worse
Edit: nvm diff person lol
Old 03-31-2013, 05:10 AM   #7210
breaksOFTEN
Member#: 260549
'69 Camaro '76XS750
'77CB750
What do DW1100side feeds like more? high base fuel pressure or low base fuel pressure? Any one played with a fpr to find that "sweet spot"?
I have a lot of adjustability in my fuel system and I want to turn my BAP down so I'm not working the pump so hard, and keep a safe IDC.
Old 03-31-2013, 09:43 AM   #7211
Layvon
Member#: 195711
STi 04/05/06/07
JBP / OBP for now
DW 1100s like being swapped out for ID1000s (or ID1300s here soon )
Layvon is offline   Reply With Quote
Old 03-31-2013, 10:04 AM   #7212
manitou
Member#: 193757
2006 XTI Limited
Hey I resemble that remark! Haha
Old 03-31-2013, 10:26 AM   #7213
Layvon
Member#: 195711
STi 04/05/06/07
JBP / OBP for now
Sorry - Had to
I was feeling Witty this morning
Old 03-31-2013, 10:38 AM   #7214
manitou
Member#: 193757
2006 XTI Limited
No worries, it's funny and its true!
Old 03-31-2013, 10:55 AM   #7215
xluben
Member#: 261612
2002 WRX - 800HP
9.5s @ 150mph
Anyone running a hardwired Walbro 465 in the 08+ plastic housing? Are you able to get down to stock base pressure? I'm using the Fuelab 545 FPR and can't get below 55psi. Current theory is that the plastic housing is restricting the return and holding the pressure up. Anyone have experience with this before I start cutting up the plastic housing?
xluben is offline   Reply With Quote
Old 03-31-2013, 02:25 PM   #7216
breaksOFTEN
Member#: 260549
'69 Camaro '76XS750
'77CB750
I'll swap when they come out with the 1300's but till then I just need to make what I have works a bit more efficient.
Old 04-02-2013, 10:24 AM   #7217
lil jon
Member#: 19044
The walbro 465 solved my problem. Now to boost lol
Old 04-02-2013, 10:37 AM   #7218
manitou
Member#: 193757
2006 XTI Limited
Good on ya! Keep your base at 50 psi or less if you can, it'll be easier on your pump.
Old 04-02-2013, 02:21 PM   #7219
lil jon
Member#: 19044
Thanks for the tips!!! My tuner (mr slowbaru) will be tuning while I'm in Cali. Hope he races Evo day for me and wins lol. Just trying to have a uber fast ej205 went 11.6 on pump with less boost with bad 60ft. Hope this makes her rip now
Old 04-02-2013, 07:04 PM   #7220
maxpowr
Member#: 159243
sg3 Turbo Tek Tuned
Hakt Ecu e85 30r 6spd
phil from flat 4 motorsport is sending my modded pump hanger and walbro 400.
im gonna running it 12v and see the difference of running it 14v.
if i can make 25# of boost on e85 with walbro 400@ 12v @ less than 80% IDC with dw1300s...
im good.
maxpowr is offline   Reply With Quote
Old 04-02-2013, 07:25 PM   #7221
amalgrover
Member#: 183480
2009 Forester XT
According to the flow charts for the walbro 400@12V, you are going to have to run like 20psi up top to prevent your injectors from out-flowing your fuel pump. At 85% IDC, your walbro should max out close to 20psi...so...you might be able to run 25psi at peak, but then you are going to have to taper it down closer to 20psi by about 5500rpm.
...that is unless you don't care about turning your return style fuel system into a returnless one or about your fuel pressure once this happens...
Old 04-03-2013, 03:17 AM   #7222
breaksOFTEN
Member#: 260549
'69 Camaro '76XS750
'77CB750
Two questions:
1. Does anyone know why I can not turn my base fuel pressure up past ~43psi?
I crank the allen screw in on the Aeromotive FPR trying to raise the base pressure but it won't go any higher? I can drop it pretty low, but not any higher. Fuel pump is the Aeromotive 340 powered by the MSD BAP.
2. What's wrong with my fuel pump?
Old 04-03-2013, 09:35 AM   #7223
manitou
Member#: 193757
2006 XTI Limited
Originally Posted by breaksOFTEN View Post
Two questions:
How is your pump wired from battery etc....?
How is your fuel system plumbed? Do you have any photos of the fuel system plumbing?
Old 04-03-2013, 10:40 AM   #7224
wrxsubiemod
Member#: 165104
E85 SoCalPorting
Owner
Two questions:
Video Link: http://youtu.be/8ZEjBSyebpo
Saw a car with the same issue and Sounded the same. He hooked the fpr backwards
wrxsubiemod is offline   Reply With Quote
Old 04-03-2013, 10:45 AM   #7225
manitou
Member#: 193757
2006 XTI Limited
That would explain it!
Motion Lab Tuned: Juanmedina's 2007 WRX E85 ARMY Motion Lab Tuning Proven Power Bragging 125 04-12-2010 03:57 AM
jid2 Track Car - e85 ARMY jid2 Member's Car Gallery 38 01-22-2010 11:44 PM
The Honduran army is the bravest in the world... wrxcelent Off-Topic 36 07-07-2009 09:21 AM
Spacific E85 Tuning thread Here ? discopotato03 Engine Management & Tuning 1 09-09-2008 12:01 PM
Did anyone hear the one about the Italian army and the IRAQI satiation? Asinine Off-Topic 3 09-20-2005 08:06 PM
