Old 06-04-2013, 12:36 PM   #7351
Layvon
Member#: 195711
STi 04/05/06/07
I'm not sure what the zeitronix has but you can get them with AN fitting on the end for fuel system ease of use. I did look at the LCD display a while back, but didn't want the gaudy display,
Put in the return side of the system. I will take a picture specifically of that to help out.
Layvon is online now   Reply With Quote
Old 06-04-2013, 03:44 PM   #7352
WRXt4cy
Member#: 172698
11 STi BW 8374 E85
02 v8 Spec C E85
Doing a little digging, it appears that the Zeitronix sensor is nothing more than a re-badged sensor that is made by Continental. Haltech seems to use the exact same part and re-badges it as well for the flex fuel add-on to their ECM.
Digging around, I found the continental sensor for sale much cheaper here:
http://paceperformance.com/i-8396469...ensor-e85.html
Then I noticed a smaller and cheaper version that appears to work the same here:
http://paceperformance.com/i-1080149...ensor-e85.html
I assume they use the same harness but I am trying to determine that. Zeitronix sells a harness for $30 or you might be able to get the OE one cheaper and use that. There seem to be two different harness options this place sells and I'm not sure of the difference.
WRXt4cy is offline   Reply With Quote
Old 06-04-2013, 03:58 PM   #7353
Layvon
Member#: 195711
STi 04/05/06/07
Good find. When I bought mine a few months ago, pace was at $159.99 for the top link. I found mine with the AN fittings on it for 189 shipped. I overpaid slightly but didn't want to deal with the push to connect fittings so I let them be someone else's problem.
I still need to see if I can get the temperature to work with the link. It is off by a factor and I'm not sure why. Link released the continental sensor a few months back and I have it wired up like the Siemens sensor ... which is ever so slightly different. Hoping that when I wire it up I get accurate fuel temps
Old 06-05-2013, 09:47 AM   #7354
blowbyu24
Member#: 84482
2005 STI.UR gt4088r
E85 pro comp sti
Originally Posted by manitou View Post
LOL, nice Levon! We don't all have Vipec's or Link's. Good for you though. Does that automatically adjust the fuel trims, boost and timing accordingly once you have it set up with pump and E85 tunes?
I'll bet the day that Cobb has the ethanol sensor flex fuel thing figured out is not that far down the road.
I can't remember where I read it, maybe off that Paul Yaw article about the grading of E85 and that it can be upto 55% ethanol or something there about. I know the winter blend goes to E70. I don't drive my XTI in the winter but I did drive it a bunch this January and Feb. when the roads where dry and at the Meijer stations I get it at it never tested below 82% and mostly higher up to 87%.
So what are you doing with that gas? Can you flash in a pump gas map and add some 93 or do you have to drain it out.
I go back and forth on fuel a bit, not a lot of switching but I like to run pump gas when I'm traveling farther with my car. My practice in switching fuels is:
I don't drain the tank completely, it's not great on the pump to do that. I run it down low <2 gallons (when the light comes on I have roughly 3 gallons) and re-fill with the new fuel.
If it's switching from pump to E85 I let it run for a while on the pump tune after filling with E85 before re-flashing the E85 map in to make sure I flushed all the pump gas out of the lines and I stay out of WOT for a while after the re-flash.
When going from E85 to pump, I just re-flash the pump map in after fueling and go but stay out of WOT for a bit to make sure the lines are full of pump gas before going WOT and targeted boost!
i took off the return line to the fpr last night and hooked that up to a fuel line that dumped the fuel into a 55 gallon poly drum...i tested stuff i had picked up about 2-3 weeks ago from the same place and it tested to E86, so i should be good to go now...i left my name and number at the gas station for the manager to call me so i could tell them
blowbyu24 is offline   Reply With Quote
Old 06-06-2013, 05:27 PM   #7355
juanmedina
Member#: 133146
07 FPgreen [email protected]
WRX VF39+E85 12.0, 121mph
This is a good video about modding cars
Old 06-06-2013, 05:39 PM   #7356
WRXt4cy
Member#: 172698
11 STi BW 8374 E85
02 v8 Spec C E85
"I got spanked like an Asian toddler that just drew on the wall with his mother's lipstick"
Old 06-06-2013, 06:21 PM   #7357
manitou
Member#: 193757
2006 XTI Limited
OBP, Junior tuned 573WHP
Too damn funny! I love that line! Hey Juan are you doing some soul searching here? "I said I want a 10 second car not a 10 minute car"
Old 06-06-2013, 10:20 PM   #7358
manitou
Member#: 193757
2006 XTI Limited
^^^ sorry about the comment above Juan ! I did not know that you put your car up for sale yesterday. I can see the attraction of both of those cars especially after Junior's GTR posts. We're talking a big league jump to both of those circles!!
Old 06-06-2013, 11:00 PM   #7359
juanmedina
Member#: 133146
np, Is just a feeler. My car is running perfect right now
Old 06-06-2013, 11:09 PM   #7360
Michael634
Member#: 358706
^ single walbro pump?
i have 1150's with a gt35r, thinking of switching to e85
Oakley Sunglasses
Michael634 is offline   Reply With Quote
Old 06-08-2013, 11:35 AM   #7361
Andrewxxcarlson
Member#: 316415
2006 WRX
Helllllo fellow subians! Just made the switch to e85, being tuned by Eric @ TP!
06 wrx
Catless
Cobb sf
Walbro 255
Stock 565cc injectors
When tuning is complete ill update with IDCs. Initial impression, boost onset is quicker, idle is better, smells fantastic and pulls hard on the little td04. I didn't upgrade turbo because I don't see alot of guys makin the switch to e85 on these small turbos and I'm a torque fiend!
Andrewxxcarlson is offline   Reply With Quote
Old 06-08-2013, 11:41 AM   #7362
wrxsubiemod
Member#: 165104
E85 SoCalPorting
Owner
Originally Posted by juanmedina View Post
Video Link: http://youtu.be/YrM9NFHhl0Q
Now I want 2000hp :/
wrxsubiemod is offline   Reply With Quote
Old 06-12-2013, 02:06 PM   #7363
340Duster
Member#: 52314
2002 PSM WRX 16G-XT
'13 500 Abarth
Any advice for tuning the MAF Comp (IAT) table? I'm adjusting the 2 highest temp ranges to better fit where my IAT values are in the summer and if I need to richen the AFR range, I need a positive value in the MAF Comp %, correct?
340Duster is online now   Reply With Quote
Old 06-12-2013, 02:13 PM   #7364
Phatron
Member#: 36033
CEO PhatBottiTuning
2006 STi GTX3582 + Meth
Yes, positive adds fuel
Old 06-14-2013, 07:56 PM   #7365
BigRob74
Member#: 305107
2016 GT 5.OHH
DIB
finally on e85, couldnt be happier
BigRob74 is offline   Reply With Quote
Old 06-16-2013, 09:19 AM   #7366
thumpetto007
Member#: 156358
2001 Miata LS
Gay Blue
Here's a dyno run of my car. This is running the stock ecu, untuned, naturally aspirated, 420 wrx injectors, and E85. The car put down 162/149 (IIRC)
At the next dyno session, the car will have a 2005 intake manifold, and be tuned on a LINK G1 ECU. Looking for around 200whp on Pure tunings dyno.
thumpetto007 is offline   Reply With Quote
Old 06-16-2013, 10:21 AM   #7367
rexworx
Member#: 103232
05GD 04XT11WRX2.5XTR
PPG,4.44,LSD,E85,6spdx2
Rob, Sounds GREAT!
rexworx is offline   Reply With Quote
Old 06-16-2013, 10:32 AM   #7368
BigRob74
Member#: 305107
2016 GT 5.OHH
DIB
Originally Posted by rexworx View Post
Rob, Sounds GREAT!
thanks ian, very happy with 330/375. there is more in it, but i dont feel like upgrading to an sti trans anytime soon dave was really good with the tune, car rips on the street
Old 06-16-2013, 10:41 AM   #7369
rexworx
Member#: 103232
Great. My Queen Bee just sold her 2006 wrx. She also just picked up a new 13 swp wrx. We are rather rather happy with the purchase.
Old 06-16-2013, 10:47 AM   #7370
BigRob74
Member#: 305107
2016 GT 5.OHH
DIB
hope the accessport is the first mod..lol
Old 06-26-2013, 07:38 PM   #7371
nate_fisher
Member#: 270482
2011 turbotek fxt
[email protected] 4eat xt record?
Need the gurus help on some advice quick. I am currently running id1000 and a 300lph drop in pump with my td06 20g and am maxing my idc out. Due to the better E at the pump ( local pump is e90) and my new found boost I am maxed out as soon as I hit full boost and am going lean. So I already ordered a DW hardwire kit for my pump and I also am going to get a fpr and custom make some some lines and fittings. My question is what is a decent and affordable fpr i just want to bump it to 55psi ? There are so many out there I don't really know the difference except the amount of adjustability so i thought i would post here befor i pull the trigger on one. Thank you in advance.
nate_fisher is offline   Reply With Quote
Old 06-26-2013, 07:57 PM   #7372
Phatron
Member#: 36033
CEO PhatBottiTuning
Ur better off Getting a dw400 and doing the rewire.
Raising the fuel pressure on the smaller intank pumps usually doesn't work cause it just makes the pump flow less.
Just start with the rewire....that should give u 10-20% extra idc.
Old 06-26-2013, 08:14 PM   #7373
nate_fisher
Member#: 270482
2011 turbotek fxt
Cool i will start with that and see what happens. Any one else, my tuner thinks that may not be enough and i don't want to hack my pump housing apart to fit a larger pump.
Old 06-26-2013, 08:44 PM   #7374
manitou
Member#: 193757
2006 XTI Limited
Ron's advice is right on. With a big Walbro you'll probably be fine at stock base pressure with your ID1k's and your 20g. If you want to verify the fuel requirements there are some good calculators online where you can plug in all the variables and see what your needs are.
Old 06-26-2013, 08:52 PM   #7375
Phatron
Member#: 36033
CEO PhatBottiTuning
you've pretty much listed all your options already...i just approach it from a cost stand point and do things in the order of least cost. rewire, pump, fpr/fittings/lines, then injectors....but any bigger injectors u throw in there with that same pump arent gonna perform up to their rating with the fuel flow falling off at increased boost pressures.
Motion Lab Tuned: Juanmedina's 2007 WRX E85 ARMY Motion Lab Tuning Proven Power Bragging 125 04-12-2010 02:57 AM
jid2 Track Car - e85 ARMY jid2 Member's Car Gallery 38 01-22-2010 10:44 PM
The Honduran army is the bravest in the world... wrxcelent Off-Topic 36 07-07-2009 08:21 AM
Spacific E85 Tuning thread Here ? discopotato03 Engine Management & Tuning 1 09-09-2008 11:01 AM
Did anyone hear the one about the Italian army and the IRAQI satiation? Asinine Off-Topic 3 09-20-2005 07:06 PM
