Old 09-21-2013, 10:54 AM   #7651
amalgrover
Member#: 183480
2011 Audi A3 Quattro
2009 Forester XT
Yup! Like I said before, I loved mine. I had my DW300 pump running 13.5V below 5psi of boost, and then 18V above that. It worked perfectly and kept things very nice at idle and cruising, and still gave me enough fuel up top where I needed it. I put down 565whp VD dynojet setting, and with FIC 1250's targeting 11.7:1, my IDC's were only 81%.
amalgrover is offline   Reply With Quote
Old 09-21-2013, 11:00 AM   #7652
WRXt4cy
Member#: 172698
11 STi BW 8374 E85
02 v8 Spec C E85
I don't know when it changed, but at some point, Subaru started running higher gauge wires back to the stock FPC. On the 2011 STi, they are 14 gauge as far as I can tell. By my math and the amperage ratings, this seemed like plenty for running the walbro 400 up to 25 psi at stock base pressure which is all I wanted to begin with so I got the FuelPro and clipped of the stock FPC plug and ran all the wires into the FuelPro except the ground. I found that using the OEM ground caused the FuelPro to seem to lose or not have the power it needed to ramp up the pump going into higher loads. I grounded the FuelPro directly to the chassis as suggested by jockygolfs and this solved that issue.
I am at 75% IDC at 25 psi on a Dom 3.5 with FiveO 1400's and still using stock rails, lines and FPR. I'll be adding rails, lines and an fpr soon to see how much that drops IDC (if any) and when the built bottom end goes in over the winter, I'll probably re-wire so I can bump base pressure and have the fueling for a little more boost.
I've been meaning to post up my results from my new setup here but I have been really busy lately. I'll get to that soon.
WRXt4cy is offline   Reply With Quote
Old 09-21-2013, 11:27 AM   #7653
05_wRex
Member#: 170097
2007 WRX STi PTE6266
1250's? That's impressive. My id2000s are at 80% at 30 psi. Stock lines and rails though.
05_wRex is offline   Reply With Quote
Old 09-21-2013, 12:26 PM   #7654
amalgrover
Member#: 183480
2009 Forester XT
100% stock rails, lines, regulator, etc.
Old 09-21-2013, 01:12 PM   #7655
05_wRex
Member#: 170097
1250's and not 2150's? I assume since you didn't correct me, that they're 1250's.
Of course on a vd dynojet plot my car made 686 whp from a logged run on the dyno that read 559 whp. So who knows.
I think my pump falls off just a little since my base pressure is 50 psi. So plus 30 would put the pump trying to keep up with id2000s at 80 psi fuel pressure. Lol. Stock lines and rails. Fuel lab regulator now because I thought I might get some headroom with a small bump in base pressure. It didn't change really other than possibly making the pump struggle just a little up top with higher pressure.
Old 09-21-2013, 01:45 PM   #7656
Mark2JZ
Member#: 83818
just to add,
2005 STi
DW 850cc injectors (swapping out to DW1100cc's this week)
DW300 fuel pump
Blouch Dom3XT-R 10cm, oem inlet size, 20psi
IDC's are mid 90's at the top of 3rd gear (will change obviously once i get the 1100's in)
11.5-11.75 AFR gas eqiv.
romraider tuned
sea level
403whp/360lbft 3rd gear pull on VD
ignore the afr on the plot, its from the oem primary o2.
quite a big jump from 340whp/330tq on pump 91 at the same boost. i can't wait to take advantage of the larger injectors, but will stop when i reach a comfortable IDC at whatever PSI that is, OR the limit of my oem clutch (with about 10k miles on it), OR until the DW300 can't keep up.....
im just glad i live reasonably close, 8 miles, from the nearest e85 pump. mpg isn't horrendous, about 13-14 mpg.
Mark2JZ is offline   Reply With Quote
Old 09-22-2013, 12:08 PM   #7657
manitou
Member#: 193757
2006 XTI Limited
OBP, Junior tuned 573WHP
What do you think of the FuelPro and in your opinion is it a good upgrade to supply higher voltage and amperage to the Walbro 465 pump?
Old 09-22-2013, 07:22 PM   #7658
05_wRex
Member#: 170097
What he said.
Old 09-22-2013, 07:43 PM   #7659
stretchedk7
Member#: 170602
06 Wrx RWD Auto
76MM-AEM-2200's
Weldon 2035 ftw lol. 24% percent duty cycle at 40 psi and 8500
stretchedk7 is offline   Reply With Quote
Old 09-23-2013, 10:53 AM   #7660
WRXt4cy
Member#: 172698
11 STi BW 8374 E85
02 v8 Spec C E85
Its really hard to say because I can't compare the fuelpro to anything else and I didn't try to see what the stock FPC would do at high boost. It was fine at 21 psi but it would get very hot and I didn't want to worry about it failing while I was out on the road. From Walbro's chart, the 400 draws a lot of current, much more than I'm sure the stock FPC is going to handle for long. I'm not surprised people have seen them fail when they switch to the 400.
I will say that the classic GR "stumble" is actually finally gone for the first time ever. I've tried everything from the GD FPR, 3 foot fuel hose mod, endless tuning compensation adjustments, etc. My stumble was very slight and didn't even bother me but it was always there. It shifted a bit with the 1400cc injectors but after the fuelpro went in, it finally is at a point where I don't feel it at all. I think the fuelpro does do a better job with being smooth in ramping up the pump duty. Perhaps this is a big part of the issue.
Again, my plan to is add rails, lines and an adjustable FPR. Then, when I am ready to crank the boost up next year, I'll find out if direct wiring the FuelPro for power and running high gauge lines from it to the pump helps with fuel delivery or not.
My goal with my '11 is for it to be a car that I can road trip 1000 miles, run low 11's at the strip, and run competitive times at the road course. I don't want a surge tank or 3 pumps in my trunk. I don't want to hardwire my pump either and have it running 100% all the time. I think the 400, the fuelpro and some 1400's are the ticket for my needs. Time will tell though. My confidence level for longevity is not real high yet but once I have some more miles on it, I'll feel better. My trunk currently contains a zip lock bag with everything needed to wire my stock FPC back on in the event of a failure.
Old 09-23-2013, 11:01 AM   #7661
nate_fisher
Member#: 270482
2011 turbotek fxt
[email protected] 4eat xt record?
Haha I thought I was the only one my trunk has all I need to convert the pump back to 100% duty in the case of my fpc failing lol. I am pretty intrigued by the fuelpro and may go that route in the future. I just switched my 400 from running 100% to running off the fpc and so far so good. I still have it wired from the battery to the relay with 10g wire but I have the pump grounded through the fpc instead of to the chassis for better control. If it fails all I have to do is ground the pump back to chassis again and it will be back at 100%.
nate_fisher is offline   Reply With Quote
Old 09-23-2013, 11:43 AM   #7662
WRXt4cy
Member#: 172698
11 STi BW 8374 E85
02 v8 Spec C E85
Haha - I've seen too many friends get stranded with fuel system control failures. I'll even pack an old fuel pump for the first few months when I install a new one.
Old 09-23-2013, 03:34 PM   #7663
nate_fisher
Member#: 270482
2011 turbotek fxt
Well great minds think alike I suppose lol.
Old 09-23-2013, 03:35 PM   #7664
manitou
Member#: 193757
2006 XTI Limited
^^I've had my 465 installed since last summer and then re-wired through the stock fpc since last November. So far so good but I would like to make sure it has a good voltage and amperage supply when it's in the 100% duty.
If the FuelPro does this then I think I may install one. I emailed with Jeff Reid over the weekend and he said it's imperative to mount it to a metal surface and make sure it has good ventilation. I have a few computer component heat sinks kicking around so I may mount the FuelPro to one of those and then mount it near the fuel pump area where I have my 30 amp fuel pump relay mounted.
That's not a bad idea to have parts on hand in the trunk for the conversion to 100% and or back to the stock controller I may just wire modular so i can switch back without tools!
Old 09-23-2013, 04:35 PM   #7665
WRXt4cy
Member#: 172698
11 STi BW 8374 E85
02 v8 Spec C E85
When you open the FuelPro (which you need to do to wire it up) you unscrew and remove the top cover from the plastic hobby box that the circuit board sits in. You'll find that on the inside the pastic cover is a trimmed piece of aluminum that appears to be hot-glued down. (it can wiggle a bit) This metal "heatsink" touches a metal pronged piece coming off circuit board when the cover is screwed on. The metal pronged piece is obviously what gets really hot and it is supposed to transfer the heat into the metal sheet.
So - installation - Jeff does say to mount it to a metal surface but how is that supposed to work? The bottom of the box does not get hot at all. The top cover is what cooks, even at idle. So should the top of the box be secured down to a metal surface? How would you then open the lid without having to remove it from its mounting. Its like the heatsink should be in the bottom of the box and the circuit board could be mounted to the top cover. Then it would make sense to fasten the bottom of the box down to a metal surface.
I chose to take the bracket off my stock FPC, 3M'd it to the fuelpro bottom and then installed the fuelpro into the location where the stock FPC mounts. It should see some air in this location and be able to shed heat, at least that's my thinking. After a drive out to Byron, IL and back, it feels like the top cover might have warped a bit from the heat but I haven't had it out to inspect it yet.
I feel like the fuelpro has a solid circuitry design and works exactly as it should but the case and heatsink feel "cheap" to me. I can't argue with the price of it though, it seems like a great value. I just wish it cooled better and I'm also temped to mod the cooling like you are talking about.
Old 09-24-2013, 12:21 PM   #7666
manitou
Member#: 193757
2006 XTI Limited
I have not seen one in real life, I'm just repeating what Jeff emailed me. Here's his note:
Hi Allan,
Well if he is using the original wiring gauge that will certainly put more pressure on the controller.
Has your friend installed it on a metal surface (back on a large flat metal surface?) and all the the other surfaces
uncovered (allow air flow)? This is very important to keep the controller cool. Is he using it within the current
specification?
FuelPro supports your pump so no problem here. Please let me know if you have further questions.
Kind regards,
-Jeff Reid
DCCDPro.com
From your description it sounds like the cover should be made out of aluminum then if it has the heat sink plate mounted to it. I'm looking at the photo on the website, is that the aluminum plate with his logo and serial # printed on it?
I would think that the plastic box actually would act like an insulation around the circuit board. He also said that his minimum requirement for wire size feeding it was 16 ga., so that does not sound like the issue.
Old 09-24-2013, 02:09 PM   #7667
WRXt4cy
Member#: 172698
11 STi BW 8374 E85
02 v8 Spec C E85
Hi Allan,
specification?
Kind regards,
-Jeff Reid
DCCDPro.com
He told me that my original wiring was fine since it was 14g but who knows... I bought some 12g to run from direct from the battery through a 40a relay to be switched by the power wire from the oem fpc power wire. I just haven't hooked that up because I wanted to see this controller just wired in place of the stock one and because Jeff seemed to indicate that this would be fine. My math on the current draw suggested it was fine as well.
The issue isn't even in boost. You can start the car up and just let it idle and that box will just cook the top. Like I said, mine is mounted on the metal surface where the stock FPC sits. It is open on all sides like he suggests but I don't see any point in fully mounting the bottom to a metal surface. It doesn't shed any heat out of the bottom. I think the top of the box should be a large metal heatsink with cooling fins, somewhat like the stock FPC uses.
Old 09-24-2013, 03:03 PM   #7668
stretchedk7
Member#: 170602
06 Wrx RWD Auto
76MM-AEM-2200's
I can honestly say the fuel pump will be happier if the power comes from the battery not the fpc. In the long run this will save the fpc.
Old 09-24-2013, 03:11 PM   #7669
WRXt4cy
Member#: 172698
11 STi BW 8374 E85
02 v8 Spec C E85
I completely agree. My quest is to find the best solution to pass power to the pump but without running it directly and at full power all the time.
For a weekend/track car, its not a big deal (to me) but for a DD that I take on road trips from time to time, I'd rather have my pump running at a lower duty while I'm cruising for hours at a time.
That reminds me of my other issue with the FuelPro - just like with hardwiring, it runs the pump all the time, even when the engine is off. I was hoping it would work like the stock FPC and shutoff when the duty signal goes to 0 volts (indicating that the engine is off) but it doesn't work that way. It does use the duty voltage signal to ramp up the pump but it doesn't use it to turn off the pump. That's kind of a safety concern. If you get in a bad accident and your pump keeps supplying fuel that is leaking out... you run a big risk there. Again, with a weekend/track car or safety kill switches, etc its not a big deal. But in my opinion, this is dangerous for a DD car. I know the fuelpro, like so many other aftermarket products is "for off road use only" so its a use it at your own risk deal to begin with but obviously most of use our cars on the road anyway.
Old 09-24-2013, 03:25 PM   #7670
05_wRex
Member#: 170097
I would imagine that it would get the hottest with lower pump duty cycle. It is just limiting current to the pump, right? So it would make sense that, with the same amount of current going in and less to the pump (lower duty cycle), it would dissipate in the form of heat.
Old 09-24-2013, 03:40 PM   #7671
WRXt4cy
Member#: 172698
11 STi BW 8374 E85
02 v8 Spec C E85
This is getting to the end of my understanding but I believe the pump duty is actually lowered by cycling the current on/off at a varying rate. So at 100%, the current is constant but at 50%, the current is switched off half the time. I guess maybe the switching is what creates the heat but I'm not certain on that.
Old 09-24-2013, 03:42 PM   #7672
manitou
Member#: 193757
2006 XTI Limited
It's only going to flow what it's going to use. There must be some capacitors and resistors limiting/ controlling voltage and current so I would think it's going to create heat regardless. Smaller wire feeding it may make it work harder for the higher duties which will also cause heat. I don't know for sure but I'd like to discuss this all with Jeff a bit more before I buy one.
Sounds to me like he undersized the heat sink(s) a bit. This is one of the biggest drop in pumps so it's probably taxing the limits of this controller.
Jeff asked me to send him the specs on the Walbro 465a s he wasn't intimately familiar with it, which I did.
There is always the Kenne Bell BAP and that's proven itself.
Old 09-24-2013, 04:50 PM   #7673
stretchedk7
Member#: 170602
06 Wrx RWD Auto
76MM-AEM-2200's
If you guys could- run the pump off the fpc at normal voltage or as low as possible. Power the boost a pump off battery and have that send the extra juice to the fpc.
I think the issue is these bad boy pumps want juice and this taxes the fpc when you go wot and the fpc is forced to try its best to supply. At least that would be my guess
Old 09-26-2013, 11:25 AM   #7674
Boostedbob
Member#: 336241
08 Sti
OPB
Speaking of the Kenne bell boost a pump I tried installing it last night and kept popping my fuse to the fuel pump, I'm not sure I was tying into the right wire..
I found the main power wire going directly to my fuel pump hanger but still keep popping the fuse..I think I'm missing something here..
Boostedbob is offline   Reply With Quote
Old 09-26-2013, 01:25 PM   #7675
Layvon
Member#: 195711
STi 04/05/06/07
JBP / OBP for now
Did you dead short it by mistake?
Layvon is offline   Reply With Quote
Motion Lab Tuned: Juanmedina's 2007 WRX E85 ARMY Motion Lab Tuning Proven Power Bragging 125 04-12-2010 02:57 AM
jid2 Track Car - e85 ARMY jid2 Member's Car Gallery 38 01-22-2010 10:44 PM
The Honduran army is the bravest in the world... wrxcelent Off-Topic 36 07-07-2009 08:21 AM
Spacific E85 Tuning thread Here ? discopotato03 Engine Management & Tuning 1 09-09-2008 11:01 AM
Did anyone hear the one about the Italian army and the IRAQI satiation? Asinine Off-Topic 3 09-20-2005 07:06 PM
