Old 11-14-2013, 09:44 AM   #7776
bmwpride
Member#: 240027
Bmwpride
2002 wrx sedan
Ej20+tdo6 20g
N/a
890cc IDC 87%
784ft
bmwpride is offline   Reply With Quote
Old 11-14-2013, 06:23 PM   #7777
yamahaSHO
Member#: 73932
2005 STi BROtuned
2004 S2000
Originally Posted by WRXt4cy View Post
I got my car on they dyno last weekend. Torque was lower than VD showed (as I expected) but HP peaked higher than I expected, especially with only running it at about 24.5-25 psi
For comparison, a stock 11 WRX put down 219/240 before my car went on.
Setup details are up on post #7761
Here's the video:
http://www.youtube.com/watch?v=aUHepAOVsXQ
Is this the same setup that did a 119 trap speed?
With SD, why is it shooting flames on the dyno?
yamahaSHO is offline   Reply With Quote
Old 11-14-2013, 07:03 PM   #7778
WRXt4cy
Member#: 172698
11 STi BW 8374 E85
02 v8 Spec C E85
Looking at the logs from my 119 pass - I was running a bit under 24 psi. On this dyno pull I was hitting 25 psi and was seeing cooler ambient temps.
119 at my weight suggests 480 whp which is about where I figured it would dyno. 1 psi might be good for 15 - 20 whp I suppose or perhaps this dyno reads high.
I still need to locate and adjust the injector overrun tables. Stock values are a bit much for 1400s
WRXt4cy is offline   Reply With Quote
Old 11-14-2013, 07:18 PM   #7779
yamahaSHO
Member#: 73932
2005 STi BROtuned
2004 S2000
The trap still seems low with that ET.
I bet some more time spent in those VE areas will take care of the flames, without adjusting any overrun values.
Old 11-15-2013, 10:16 AM   #7780
WRXt4cy
Member#: 172698
11 STi BW 8374 E85
02 v8 Spec C E85
My trap speed was consistent over the four passes I made. My ET ranged from 11.5 - 12.1 depending on if I had to deal with the clutch not grabbing or missing a gear. 11.5 was my pass where I hit all my shifts about as well as I could.
I felt like I might have been able to get a higher trap speed by shifting sooner into 4th and 5th so I could carry 5th longer but I thought that might reduce my ET. I'm not experienced with drag racing, this was my first time. I still have a lot to learn.
What VE areas are you talking about? The areas it moves into when I lift? I was pretty certain its overrun fueling. I can see the injectors staying on well after I lift and the throttle is closed. I've adjusted this on other cars and this condition goes away. I just haven't taken the time to dig out the tables in my own rom and adjust it.
Old 11-15-2013, 12:32 PM   #7781
yamahaSHO
Member#: 73932
2005 STi BROtuned
2004 S2000
With a power band like that, bang them out at redline... or higher.
As far as the DFCO when you lift... Somewhere in the VE table where you're crossing when you lift is giving you a good bit more fuel than you need, so you're going to see them stay open longer, despite the size injector you have in. Find that, adjust it, and you shouldn't have to touch any overrun properties.
Old 11-22-2013, 03:57 PM   #7782
neo277
Member#: 131432
2004 WRX on Ignite E
Gtx3076 - 07 6mt
354whp 341wtq /04 WRX / EJ205 OEM @ 112,000miles + FP TDO5 18g 7cm2 / Bosch EV14 1000cc + 91% /500 ft (Ron Watson AKA Phatbotti E-Tooned)
neo277 is offline   Reply With Quote
Old 11-28-2013, 02:16 PM   #7783
Rogue_P
Member#: 371737
2003 **** Your
Fake Parts
Anyone running ProEFI with the flex-fuel setup? I'm currently running a series 1 AEM EMS and I'm pretty sure it can't support flex fuel.
Rogue_P is offline   Reply With Quote
Old 11-28-2013, 03:57 PM   #7784
05_wRex
Member#: 170097
2007 WRX STi PTE6266
The aem series 2 was supposed to have capability for flex fuel now. Not sure if they got it or not. I have a vipec v88 with a continental ethanol sensor. Works great.
I know, no info on the proefi unit. Just thought I'd share how I did it.
05_wRex is offline   Reply With Quote
Old 11-28-2013, 10:59 PM   #7785
yamahaSHO
Member#: 73932
2005 STi BROtuned
2004 S2000
The AEM EMS2 did get flex fuel support.
Old 12-01-2013, 10:29 PM   #7786
99STM
Member#: 219160
2002 Impreza WRX
AW (6MT, E85, EWG, VF39)
Don't listen to this guy, he doesn't know anything!
99STM is offline   Reply With Quote
Old 12-03-2013, 08:13 PM   #7787
05_wRex
Member#: 170097
Anyone running 10:1 pistons? My current engine is 9:1 and I love it. I just bought a closed deck short block with cup 10:1 pistons and now I'm getting cold feet. E85 (79-82%) will be run 99% of the time, but I want to be able to run 93 occasionally when I take 1-3 day trips to the tail of the dragon. I don't want to haul 20-30 gallons of ethanol up there. I would be fine running 15-19 psi on pump gas if that's what it took to run 10:1 pistons.
Thoughts?
Old 12-03-2013, 08:50 PM   #7788
manitou
Member#: 193757
2006 XTI Limited
OBP, Junior tuned 573WHP
Originally Posted by 05_wRex View Post
Anyone running 10:1 pistons? My current engine is 9:1 and I love it. I just bought a closed deck short block with cup 10:1 pistons and now I'm getting cold feet. E85 (79-82%) will be run 99% of the time, but I want to be able to run 93 occasionally when I take 1-3 day trips to the tail of the dragon. I don't want to haul 20-30 gallons of ethanol up there. I would be fine running 15-19 psi on pump gas if that's what it took to run 10:1 pistons. Thoughts?
Junior tuned Paul Szuba's 10:1 CR motor with a 6266 and a built auto in his Forester. Jrtuned it a few days after my last tune in July. It made 610whp if I remember correctly. I'd ask junior how much boost he used but I'd bet it's not much more than 30-32psi.
Dom told me to target 19-21psi on 93 with my 9.6:1 motor with his short block and my D25 PnPd +1mm valve heads. Junior ended up targeting 22psi on 93 and 29ish on e85 after I installed the id1300's.
Old 12-03-2013, 10:05 PM   #7789
05_wRex
Member#: 170097
I'd be ok if 35 psi got me 750 ish. I'm pretty sure it would be just fine with e85. It seems that it will be fine on pump gas as well at lower boost. I am fine with low boost since I won't be able to put that much power to the ground in the twisties anyways. Probably be more fun wuth just the right amount of power versus way too much in the mountains. It's just not something easily changed and this is a big chunk of money. haha.
Old 12-04-2013, 01:10 AM   #7790
baseballdbk1
Member#: 242700
2015 Impreza Wrx
About to be running 10:1 in my new motor using ethanol majority of the time and run gate pressure(20 psi) when I want to run 93 octane
I wouldn't worry about running a higher cr than people normally do, just be smart about it
baseballdbk1 is offline   Reply With Quote
Old 12-04-2013, 06:11 AM   #7791
dfmags
Member#: 375280
2013 WRX
Dark Grey
Default looks pretty good!
[quote=neo277;41003223]354whp 341wtq /04 WRX / EJ205 OEM @ 112,000miles + FP TDO5 18g 7cm2 / Bosch EV14 1000cc + 91% /500 ft (Ron Watson AKA Phatbotti E-Tooned)
[Looks pretty good]
dfmags is offline   Reply With Quote
Old 12-04-2013, 02:05 PM   #7792
neo277
Member#: 131432
Gtx3076 - 07 6mt
Thank you. Pulls good for an old school little ol 2liter hehe.
[quote=dfmags;41061986]
[Looks pretty good]
Old 12-05-2013, 06:37 AM   #7793
sackytar
Member#: 149262
03WR Rallycar/FXT/OB
PrimerGrey
Neo277. What other mods to get that much hp? Front mount?
sackytar is offline   Reply With Quote
Old 12-05-2013, 08:38 AM   #7794
340Duster
Member#: 52314
2002 PSM WRX 16G-XT
'13 500 Abarth
The power looks good, but where it starts to spool and make power doesn't look like it'd be great to drive even semi daily on the street. That's the reason why I don't want to go bigger than my 16G-XT on 2 liters.
340Duster is offline   Reply With Quote
Old 12-05-2013, 09:01 AM   #7795
sackytar
Member#: 149262
PrimerGrey
Full boost at 3800 3900 isn't too bad. Thats why I wanna know if he's rocking a Top or Front mount. Very similar to my setup. Wasn't great to DD but is Fun on the Track and RallyX events!
Only difference is I have 155K on my SB!!! LOL
Old 12-10-2013, 09:10 AM   #7796
1MOFOSTI
Member#: 375748
411whp /1MOFOSTI / 04 STI /EJ207+FPRED 8cm @21PSI /1/4 time??? / DW 1000cc /90% IDC / 55ft .
how to screenshot on windows
jpg images
1MOFOSTI is offline   Reply With Quote
Old 12-10-2013, 07:32 PM   #7797
yamahaSHO
Member#: 73932
2005 STi BROtuned
2004 S2000
That's a really narrow power band.
Old 12-10-2013, 07:47 PM   #7798
manitou
Member#: 193757
2006 XTI Limited
I'm sorry and don't mean to be a bummer, I know this is a 2L but this build is pretty darn laggy! My spool and boost happens 1000-1100 rpm's sooner with a similar sized Blouch turbo!
Old 12-10-2013, 08:01 PM   #7799
WRXt4cy
Member#: 172698
11 STi BW 8374 E85
02 v8 Spec C E85
Peak power seems consistent with the lower boost he's running.
I'd guess that the slow spool might be that his cam timing wasn't working or that he's at a high altitude but in general, the 207 isn't particularly quick to spool anything but it sure is amazing from about 5k to 8k. I have no idea why his log stopped at 7k.
Old 12-10-2013, 08:12 PM   #7800
snake32
Member#: 167338
02 Silver dollar
why to bother putting a 207 in place of a 257?? someone i know has a 207 high compression fully built bottom end with built 205 heads, he's running a 35r .63 spooling like my old 30r .82 on a 257, now that's a bad ass 2L build.
snake32 is offline   Reply With Quote
Motion Lab Tuned: Juanmedina's 2007 WRX E85 ARMY Motion Lab Tuning Proven Power Bragging 125 04-12-2010 02:57 AM
jid2 Track Car - e85 ARMY jid2 Member's Car Gallery 38 01-22-2010 10:44 PM
The Honduran army is the bravest in the world... wrxcelent Off-Topic 36 07-07-2009 08:21 AM
Spacific E85 Tuning thread Here ? discopotato03 Engine Management & Tuning 1 09-09-2008 11:01 AM
Did anyone hear the one about the Italian army and the IRAQI satiation? Asinine Off-Topic 3 09-20-2005 07:06 PM
