Old 01-30-2014, 09:24 PM   #7951
alcoolaid
Member#: 134949
'07 SWP STi
Instagram | arthurlam89
Originally Posted by 06rexwagon View Post
Single 044 is enough pump to handle about 585whp uncorrected on our dynojet. The 1300's will likely be tapped before that.
Thanks Cam! I'll just see how far the single will take me for now. Good excuse to keep the boost lower.
Edit: well that didn't last long. I just bought another 044 since I found one for like $140 shipped on eBay. Apparently this vendor has sold a few hundred genuine 044's for this price
alcoolaid is offline   Reply With Quote
Old 02-02-2014, 10:23 AM   #7952
1MOFOSTI
Member#: 375748
04 STi
Need help ! Just installed AEM Wideband AFR gauge. Anyone know if we need to calibrate it since we are using E85?
1MOFOSTI is offline   Reply With Quote
Old 02-02-2014, 11:16 AM   #7953
Andrewxxcarlson
Member#: 316415
2006 WRX
No, I never switched settings.
Andrewxxcarlson is offline   Reply With Quote
Old 02-02-2014, 12:37 PM   #7954
06rexwagon
Member#: 114730
2006 WRX Limited Wag
[email protected]
Use it as gasoline
06rexwagon is offline   Reply With Quote
Old 02-02-2014, 08:52 PM   #7955
340Duster
Member#: 52314
2002 PSM WRX 16G-XT
'13 500 Abarth
Use it as gasoline
This.
340Duster is online now   Reply With Quote
Old 02-02-2014, 11:17 PM   #7956
1MOFOSTI
Member#: 375748
04 STi
ok , so im good to leave it as it came outta the box?
Old 02-03-2014, 12:22 AM   #7957
340Duster
Member#: 52314
2002 PSM WRX 16G-XT
'13 500 Abarth
Yes, no need to change it to lamba or anything.
Old 02-03-2014, 12:23 AM   #7958
340Duster
Member#: 52314
2002 PSM WRX 16G-XT
'13 500 Abarth
Just be aware of what target AFRs you need for E85.
Old 02-03-2014, 01:00 AM   #7959
1MOFOSTI
Member#: 375748
04 STi
ok. Do you mean what i need to be tuned for on E85, or just monitor what my tune is set at..?
Old 02-03-2014, 02:59 AM   #7960
1MOFOSTI
Member#: 375748
04 STi
Originally Posted by amalgrover View Post
If you wanted to modify as little as possible, just keep one stock regulator and delete the other one.
Yea but since im in it this deep now and fuel flow will be raised even more once the 2nd pump kicks in, i may as well go balls out and get a proper AFPR 3port setup. (just finished pulling everything apart for the new install)
From what i have seen its looking like aeromotive 3port is the way to go. Anyhow ill post up when its all complete and for you guys to see . Thanks to all who chipped in to saving my motor, appreciate it. -1MOFO
Originally Posted by yamahaSHO View Post
Lots of decent aftermarket FPR's out there and plenty of fitting options out there to let you keep your current lines. You may have to start researching the Googles.
As far as the tune... It should probably be touched up regardless.
1MOFO's All up and running like a champ. Turns out the 2nd FPR vac line was getting crushed under the 3'' inlet clamp. How it happened i dont know but thanks to all for the advise as cylinders 2 and 4 would of ran lean resulting in a blown engine.
*****Lesson to anyone reading this, Don't ever Run twin oem FPR's like i did. Recipe for disaster*****
screen shot software
Old 02-03-2014, 07:47 PM   #7961
340Duster
Member#: 52314
2002 PSM WRX 16G-XT
'13 500 Abarth
Both.
Old 02-03-2014, 10:27 PM   #7962
1MOFOSTI
Member#: 375748
04 STi
Both.
whats the rough target for E85 on 25-27PSI ? I've got a Custom Tune coming up, Can you point out what i should look for...
Old 02-03-2014, 11:31 PM   #7963
340Duster
Member#: 52314
2002 PSM WRX 16G-XT
'13 500 Abarth
I would shoot for 11.5 AFR at WOT. You need to talk to your tuner about it though, since they will be setting it up.
Old 02-04-2014, 10:21 AM   #7964
1MOFOSTI
Member#: 375748
04 STi
ok noted, thanks Duster
Old 02-15-2014, 11:36 AM   #7965
STIinthefe
Member#: 314642
2004 STI
Just installed a walbro 255 and DW 850s in my 04 Sti. I'm just waiting to hear back from my tuner to send me a limp map to get to his shop and be road tuned. I'm just wondering if you guys have any advice for me on this process, what I should look for or ask during the road tune, and using e85 daily?
STIinthefe is offline   Reply With Quote
Old 02-15-2014, 11:52 AM   #7966
Brown Ops
Member#: 291770
2004 Impreza WRX STI
Java & satin black
I have the same setup in my 04 STI too. I do know to run 93 every once and a while to help clean everything up a bit. This is a good read and has some E-85 info in it as well;
http://forums.nasioc.com/forums/show....php?t=2277357
Brown Ops is offline   Reply With Quote
Old 02-15-2014, 01:48 PM   #7967
nofriends
Member#: 65169
2010 Outback
2016 STI CBS
Car: 2014 WRX
Facility: 5150 Racing
Facility Website: https://www.facebook.com/5150.Racing.Dyno
Tuner: Jon Drenas
Type of Dyno: Mustang Dyno
Baseline Numbers for a Stocker on the Dyno: Unknown
Ambient Temperature: 75 degrees F
Target Boost / Actual Boost: 18.0 PSI / 17.9 PSI
Fuel: E-85
SAE Corrections: Unknown
Peak HP: 295
Peak Torque: 319
Mod(s): Cobb Catted DP, Cobb SF intake w/ box, RRE 3-Port EBCS, ID1000's, DW65c
E-85 and 91 Tune side by side.
nofriends is offline   Reply With Quote
Old 02-15-2014, 09:21 PM   #7968
ToyotaMike
Member#: 286007
2007 WRX TR STI Swap
OBP 399.9 WHP E85 PAS/CTC
ToyotaMike is offline   Reply With Quote
Old 02-19-2014, 02:43 PM   #7969
jusgunn3
Member#: 323550
2007 sti
blue
Default E85 track days
So im going to track at thunderhill next month and I was wondering how much fuel I will need. Its my first session and im running a stage 2 protuned 07 sti. Any help would be great thanks !!
jusgunn3 is offline   Reply With Quote
Old 02-19-2014, 03:24 PM   #7970
WRXt4cy
Member#: 172698
11 STi BW 8374 E85
02 v8 Spec C E85
There are a lot of factors but 20 - 25 gallons should be enough.
I've used up to 25 gallons at one open lapping track day when running E85 on the stock turbo. That was probably around 5 to 6 15-20 minute sessions.
It burns really fast.
WRXt4cy is offline   Reply With Quote
Old 02-19-2014, 04:20 PM   #7971
STIinthefe
Member#: 314642
2004 STI
just converted to e85 today. im going to get road tuned tomorrow. i wont be able to post dyno numbers but im happy to be apart of the e85 army.
Old 02-19-2014, 09:12 PM   #7972
jusgunn3
Member#: 323550
2007 sti
blue
Ya I'm scared I won't have enough haha. So you think 25 total including the cars tank or 25 and a full tank?
Old 02-19-2014, 09:15 PM   #7973
WRXt4cy
Member#: 172698
11 STi BW 8374 E85
02 v8 Spec C E85
Yeah. 25 total. I came with with a full tank and used 15 gallons of extra fuel to keep the tank over 1/2 full at all times. Left the track with with a bit over 1/2 a tank.
Old 02-19-2014, 09:26 PM   #7974
jusgunn3
Member#: 323550
2007 sti
blue
Ok sounds good I have two 5 gallon cans now I will grab one more! Thanks for the input sir!!
Old 02-22-2014, 11:32 PM   #7975
awenthol
Member#: 355024
2013 DGM STi Sedan
Rather than start a new thread...
I have a '13 STi w/all bolt-ons but stock turbo. I recently decided to E85 but had just put 1-step colder plugs in. Should I be swapping them back to stock temp? Was told w/E85 I no longer needed 1-step colder...
awenthol is offline   Reply With Quote
Motion Lab Tuned: Juanmedina's 2007 WRX E85 ARMY Motion Lab Tuning Proven Power Bragging 125 04-12-2010 02:57 AM
jid2 Track Car - e85 ARMY jid2 Member's Car Gallery 38 01-22-2010 10:44 PM
The Honduran army is the bravest in the world... wrxcelent Off-Topic 36 07-07-2009 08:21 AM
Spacific E85 Tuning thread Here ? discopotato03 Engine Management & Tuning 1 09-09-2008 11:01 AM
Did anyone hear the one about the Italian army and the IRAQI satiation? Asinine Off-Topic 3 09-20-2005 07:06 PM
