Welcome to the North American Subaru Impreza Owners Club Monday July 14, 2014
Old 04-19-2009, 12:46 AM   #76
ChandlerWRX06
Member#: 184206
2013 X1 sDrive 28i
gray
I'm so happy I joined the Army
ChandlerWRX06 is offline   Reply With Quote
Old 04-20-2009, 02:32 PM   #77
Guy on the corner
Member#: 169591
05 LGT
Got dyno'd today at Super Rupair in Boulder, CO. Dyno Dynamics, 1.15CF, 5800'
Guy on the corner is offline   Reply With Quote
Old 04-20-2009, 04:12 PM   #78
thefoos
Member#: 144751
02 WRX BW EFR E85
7064 TS WRB
figured I would add 1/4 mile info...
13.1 @ 105
thefoos is offline   Reply With Quote
Old 04-20-2009, 04:36 PM   #79
roninsoldier83
Member#: 61966
Been running 100% E85 for about 8 months now, no real issues. As per my last tuning session, here were the results:
-Tuned via OpenECU at 19psi
-Stock VF39 turbo
-811cc injectors at 75% IDC
-6000 ft elevation
Supporting mods:
-APS TMIC
-GMS inlet hose
-AEM CAI
-Cobb catted downpipe
-Borla XR-1 cat-back
-811cc injectors
-Walbro 255lph fuel pump
Although these numbers will not be accurate for long, as I just ordered a Blouch 20G Which, I'm sure with a 20G on E85, boost will be limited due to my 811cc injectors, even at altitude, and will likely upgrade them in the future. Probably just switch back to 91 pump gas for the time being once the 20G gets here. I'm actually curious to see how my VF39 on E85 stacks up against a 20G on 91 pump. I'll be sure to post results.
roninsoldier83 is offline   Reply With Quote
Old 04-20-2009, 04:49 PM   #80
jason miller
Member#: 158313
2003 WRX
For all of you guys running e85, how consistent has it been? I've got access to several e85 pumps in my town, but the octane consistency is keeping me away. It seems like something you'd have to log for constantly to monitor...
jason miller is offline   Reply With Quote
Old 04-20-2009, 04:58 PM   #81
neo277
Member#: 131432
2004 WRX-On Corn!
FP TDO5 18G! DCCD 07 6mt
Can't wait to join the Army, We just got a station close to my area who sells E85. now i have to find some 1000cc injectors and E85 here i come. : )
neo277 is offline   Reply With Quote
Old 04-20-2009, 05:53 PM   #82
putz
Member#: 154987
06 wrx tr 28k mile
for sale in MN
well, 06' wrx tr
1150 cc low impedence
td06h 20g
cycle duty?????
400' above maybe? st cloud mn 56304.
made 338awhp and 398wtq on winter mn blend e70.
putz is offline   Reply With Quote
Old 04-20-2009, 07:10 PM   #83
jason miller
Member#: 158313
2003 WRX
Originally Posted by putz View Post
well, 06' wrx tr
td06h 20g
cycle duty?????
1030 feet if you really wanted to know...
Old 04-21-2009, 02:02 AM   #84
C J
Member#: 132587
2006 JrTuned STi
E85 GT3582r/10.83@126mph
just ordered my 840cc injectors and fuel pump today, joining the army soon!
C J is offline   Reply With Quote
Old 04-22-2009, 02:39 PM   #85
WickedRydaX
Member#: 31900
2002 wrx Hydra ECU
1600cc FIC top feeds
56% @18 PSI
S200 turbo
5300 ft
2005 FXT AP e85 map
stock 565cc
not sure will check
TD04
5300 ft
1993 Impreza L with 1.8SB 2.0LWRX heads/manifold Hydra ECU
modded stock about 840cc top feeds
60ish% @15 PSI
VF22
5300 ft
All are 100% e85, but I do have a 91 map built for the FXT since it may get driven out of known E85 range.
MCL
WickedRydaX is offline   Reply With Quote
Old 04-22-2009, 09:59 PM   #86
juanmedina
Member#: 133146
07 FPgreen 7.37@95
WRX VF39+E85 12.0, 121mph
updated
juanmedina is online now   Reply With Quote
Old 04-23-2009, 04:54 AM   #87
billionaire7
Member#: 122428
586 AWHP @ 22 PSI E85 ONLY!
5300 ft. Elevation
Ambient Temp = 62
2006 Subaru STi
Garrett - T4 Twin Scroll GT4088-R, 1.08A/R Ex.
Full-Race - Twin Scroll Exhaust Manifold + TS Up-Pipe
RAW Performance - Stage 5, 2.5 Liter STi semi-closed deck case, Darton Ductile Iron Sleeve Liners,
Modified forged EJ257 crankshaft ,High Performance Main & Rod Bearings, Custom Pauter Machine Forged Rods,
Custom & Coated CP Forged Pistons, High Performance Piston Rings, Fully Balanced & Blueprinted, 9,500 Rev Limit Recommended*
Cosworth- Head Specifications:
* CNC Ported/Machined finish port
* New Castings
* Hand blended finish work
* Intake 14.63% (average) 22% (max) increased flow
* Exhaust 30.56%(average) 41% (max) increased flow
* 4-angle Inlet Valve job
* 3-angle & radius Exhaust Valve job
* Valves are lapped
* Back-Cut Inlet Valves
* Heads are Ultra Sonic cleaned prior to assembly
* Heads are Serialized and sport a machined Cosworth logo
* +1mm Stainless Steel Intake Valves (1800 degrees max.)
* +1mm Inconel Exhaust Valves (2400 degrees max.)
* Performance Valve Springs
* Titanium Retainers
* Hardened Steel Spring Platforms
* Knife edged ports
Cosworth- Cams 278 Intake, 274 Exhaust
RC- 1600cc Injectors w/ Twin In-Tank Walbrow 255lb/hr FP's
The graph says 24.88 PSI but my Defi gauge read 22 and the Hydra read the same. We could have cracked 600 on 22psi. But because we were losing fuel pressure up top we never tried. The twin in-tank fuel system I am using works great! But the Buschur Modified Walbro's are failing.
billionaire7 is offline   Reply With Quote
Old 04-23-2009, 06:38 AM   #88
jason miller
Member#: 158313
2003 WRX
Beautiful car. When's this monster hitting full boost? It would be great if you could tell us what the mph correspond to in rpm. What's the torque on this? I'm interested to see how close the torque is to the hp at this level and using e85...
Oh, and people seem to like the Bosch 044 pumps for high demand applications.
Edit: Just saw your original thread. Although it would still be nice to see a torque curve too. Do you have that?
Old 04-23-2009, 10:00 AM   #89
bertune
Member#: 107290
Didn't know about this thread
04/05.....STI/WRX
GT37R @ 30PSI
1600cc injectors @ 85% DC
Weldon fuel pump
sea level
E85
RED pull was @32psi
Couldn't go anymore as it started to push coolant, i changed the headstuds yesterday (H11) hoping that will work so i can go to the track.
bertune is offline   Reply With Quote
Old 04-23-2009, 11:07 AM   #90
GeneralTJI
Member#: 152680
I Parted out WRX
for my Pilots License :)
I don't notice much difference until they step down to E80 or E75 when the weather starts getting cold.. and then when they step it back up. Day to day differences are not enough to worry about around here anyway.
GeneralTJI is offline   Reply With Quote
Old 04-23-2009, 07:05 PM   #91
billionaire7
Member#: 122428
I do not have a torque chart. The Dyno used didn't pick up the RPM very well. The graph shown was only taken up to 7k. I'm not completely certain but for every 1k-500 RPM increase we noted a 7mph average increase.
As for the fuel situation Bosch is apart of the initial plan.
I'll make sure to keep the threads updated!
Thanks for the invite E-85 Army!
-Mario
Old 04-26-2009, 02:05 PM   #92
gaby
Member#: 94097
2004 WRX Hybrid GT35
11.2@130.7
Subscribed.
gaby is offline   Reply With Quote
Old 04-26-2009, 02:11 PM   #93
TDagen
Member#: 163648
2002 Wrx,2.5L,HTA86
E85,2007 6mt,No traction
Bertune sweet jesus, you must wear a neck brace for when that turbo hits... 700whp no wonder the heads are lifting... Thats so SICK!
TDagen is offline   Reply With Quote
Old 04-26-2009, 10:00 PM   #94
bertune
Member#: 107290
Thanks, what surprised me was the TQ.
Old 04-29-2009, 01:02 AM   #95
bertune
Member#: 107290
Update! Update? Juan!!
Precision billet 6765
Weldon fuel pump
1600cc injectors maxed!
Have alot more in it but maxed the injectors and had to back it down, i guess like anything else there are pros and cons (E85)
Old 05-04-2009, 04:44 PM   #96
STiyiyi
Member#: 88067
Power mods and supporting mods are:
Turbonetics GT-K 500 rotated turbo
Treadstone 3.5" cold air intake with K&N cone air filter
Treadstone 304 stainless steel up pipe
Treadstone 304 stainless steel downpipe with replumbed dump tube
Cusco exhaust manifold header
HKS Carbon-TI exhaust
Tial 44mm external wastegate
Tial Bv 50mm VTA blow off valve
GrimmSpeed 8mm phenolic spacers
GrimmSpeed TGV deletes
GrimmSpeed PnP intake manifold
TurboSmart eBoost2 40psi Sleeper Series EBC
Ultimate Racing 1260cc top-feed fuel injector and fuel rail kit (being installed this week)
Walbro 255 lph fuel pump (adding a second Walbro this week)
NGK one step colder plugs
Cobb AccessPORT v2
Snow Performance Stage 2 boost cooler methanol injection kit
Snow Performance Safeinjection failsafe
Snow Performance V-100 boost controller upgrade
With the above setup my '05 STi pulled 438whp/440wtq @26psi on 92 pump/meth and 462whp/460wtq @29psi on Q16 on a Dyno Dynamics dyno. That was with a single Walbro and Deatschwerks 850cc injectors.
Here's my dyno maps on the numbers above
The car is being fitted with an Ultimate Racing 1260cc top-feed injector and fuel rail kit and a dual Walbro setup and tuned with E85 on Friday. If all goes well, we hope to have her at the track Friday night. I hope to hit close to 475-485 whp/wtq, perhaps more on the dyno tune.
I am looking forward to joining the army!
STiyiyi is offline   Reply With Quote
Old 05-05-2009, 11:25 PM   #97
HamFist
Member#: 2112
2000 Impreza 2.5RS
BRP
Sorry guys...time to whip out my Swiss Army knife .
-1 E85/hydrous ethanol/Butanol 150cc scooter (doing scooter rear wheel swap. Already has GS425 front fork + bobber seat.)
-1 FA30S Saito on "General Tso's" Blend. (world's smallest biofuel 4 stroke! Vids in a bit.)
-1 N/A E85 2.5RS that just smoked a stage 1 Clutchmaster clutch. (Boring on camera at the moment. Stg3 clutch on order.)
-1 work in progress E85 '90 T-Leg (About a day away. New daily driver.)
-1 work in progress E85 metric bobber bike (Summer project.)
I am honestly comfortable actually not making a ton of power on any of this. I'm happier that it all runs like clockwork and is easy to work on and tinker with. "Fast" is relative, but all of these different things are definitely fun and faster than gas. The 5cc 4 stroke Saito sounds like a little badass (yes, 5cc). I <3 biofuel hobbies!
HamFist is offline   Reply With Quote
Old 05-20-2009, 07:54 PM   #98
rexblake
Member#: 178426
2010 Audi S4
02 WRX, conservative tune, 265whp and 247wtq.
1) Your injectors size: DW 750
2) Injector duty cycle (if you have it): 77% at 22 psi
3) Elevation: 1200
4) Turbo: fp small 16g
rexblake is offline   Reply With Quote
Old 05-20-2009, 08:42 PM   #99
pekoso1
Member#: 168988
Last year I used E85 all year I live in Minnesota, then winter came along and I start having real bad detonations on the cold morning starts, after a few failed attemps to fix it, the tuner change it back to 92, after that find out I had bad injectors (Agency Power Stock modified) replace those and now I am looking foward to get back on E85.
Last year data:
1) Your injectors size: Agency Power Modified stock 816cc
2) Injector duty cycle (if you have it): Dont know (Tuner say max out 18 psi)
3) Elevation: Dont Know (Minnesota)
4) Turbo: fp green Tial 38mm
Results 357 awhp 360 TQ @18 psi Mustang Dyno
pekoso1 is offline   Reply With Quote
Old 05-20-2009, 08:48 PM   #100
juanmedina
Member#: 133146
07 FPgreen 7.37@95
FINALLY UPDATE AS OF 05/20/09
Motion Lab Tuned: Juanmedina's 2007 WRX E85 ARMY Motion Lab Tuning Proven Power Bragging 125 04-12-2010 02:57 AM
jid2 Track Car - e85 ARMY jid2 Member's Car Gallery 38 01-22-2010 10:44 PM
The Honduran army is the bravest in the world... wrxcelent Off-Topic 36 07-07-2009 08:21 AM
Spacific E85 Tuning thread Here ? discopotato03 Engine Management & Tuning 1 09-09-2008 11:01 AM
Did anyone hear the one about the Italian army and the IRAQI satiation? Asinine Off-Topic 3 09-20-2005 07:06 PM
