Old 06-27-2009, 12:42 AM   #151
Snow Drift
Member#: 75071
15 PGP XV Hyb Trng
Past: 05, 08, 11 Red WRXs
Saw this the other day:
Old 06-27-2009, 01:04 AM   #152
WagonGGA
Member#: 134481
08/4 Subaru
Legacy Spec B/Forester XT
Nice Find!!
WagonGGA is offline   Reply With Quote
Old 06-27-2009, 11:41 AM   #153
subschutjer
Member#: 182916
04 sti
hey guys if i don't sell my ride soon i'm wantin to join the army. any idea of what type injectors i would need? here's my mods(the ones that would matter i think)
Cobb shortblock (forged internals)
TGV delete
one step colder plugs
DOM III turbo
XS FMIC
Turbo smart Re-circ
Invidia TBE (no cats)
Grimmspeed Boost solenoid
Wallboro
XS SRI
Hi-flow oil pump
currently making 400hp 425 ft/lb tq, 315 awhp at elevation of 5,012 :|
currently running modded 816 injectors. please pm with suggestions on size/impedence/brand stc.
thanks!
subschutjer is offline   Reply With Quote
Old 06-27-2009, 12:16 PM   #154
2.5i
Member#: 112986
N/A Cam'd & Cornfed
DOM TUNED 06 Impreza
I am currently running 100% e85 all day everyday... no horsepower numbers yet though. I have to fix a couple problems with my engine right now, but once it gets back together I'll have the duty cycle and dyno numbers. Oh yea the car is N/A so I'll be similar to Hamfist.
2.5i is offline   Reply With Quote
Old 06-29-2009, 02:01 PM   #155
subschutjer
Member#: 182916
04 sti
no suggestions on injectors?
Old 06-29-2009, 02:25 PM   #156
tazswing
Member#: 63767
2009 OXT 5-spd
2011 STi hatch
HTA68
DW 850s
Turbo-back (duel catted DP)
Stock TMIC and internals.
AEM CAI
colder plugs
400ft., 80 degree shop temp.
tazswing is offline   Reply With Quote
Old 06-29-2009, 02:40 PM   #157
C J
Member#: 132587
2006 JrTuned STi
[email protected]
nice, looks like it holds well. Turn that boost up! Easily can do 25psi!
C J is offline   Reply With Quote
Old 06-29-2009, 03:07 PM   #158
juanmedina
Member#: 133146
07 FPgreen [email protected]
WRX VF39+E85 12.0, 121mph
Originally Posted by tazswing View Post
HTA68
DW 850s
AEM CAI
colder plugs
What is the injector duty cycle?, does injectors seem to small for a 47lb turbo at your altitude IMO
Old 06-29-2009, 05:31 PM   #159
klattery
Member#: 48503
2004 STi ATP3071
If you are keeping your setup the same, and just changing to E85, then you should measure your injector duty cycle via RomRaider or something. Then a guideline to required size would be:
Current Injector Size x Current Max Injector Duty Cycle x 1.3 / .9
The first product tells you how much injector you are actually running. The 1.3 gives you the extra fuel for E85 at 100% duty, and dividing by .9 gives you a safer 90% duty cycle. So in all the formula gives you a 90% Injector duty cycle ESTIMATE for a similar tune, but on E85. It would probably be enough to get a good tune, though you may still max the injectors out, and should probably bump up the number a bit to give some headroom.
Just my two cents. Feel free to chime in with other opinions.
klattery is offline   Reply With Quote
Old 06-29-2009, 09:38 PM   #160
Cejpat
Member#: 145776
2006 STI
OB
Old habits die hard. Here in Kentucky I'm trying to get some excitement for e85.
Keep the faith & keep the performance #s rolling in.
Cejpat is offline   Reply With Quote
Old 06-29-2009, 10:11 PM   #161
HamFist
Member#: 2112
2000 Impreza 2.5RS
BRP
Butanol/Nitrometh Homelite I tweaked this afternoon.
/ninjack
HamFist is offline   Reply With Quote
Old 06-29-2009, 10:58 PM   #162
neversummer489
Member#: 153729
PSM Bugeye
Missing rod bearing??
where are the stickers!!!????
neversummer489 is offline   Reply With Quote
Old 06-29-2009, 11:15 PM   #163
juanmedina
Member#: 133146
I been too busy trying to fix my car
Old 06-30-2009, 01:32 AM   #164
C J
Member#: 132587
2006 JrTuned STi
[email protected]
Just curious but what are the AFR's everyone is hitting under boost?
Old 06-30-2009, 01:44 AM   #165
juanmedina
Member#: 133146
mine used to be in the 11.7-11.9
Old 06-30-2009, 01:57 AM   #166
C J
Member#: 132587
2006 JrTuned STi
[email protected]
Yeah I have someone arguing with me about stoich for e85 is 9.7:1 and that there is no way our cars are running around with 11.5ish afr's
I don't know how to explain it since I had nothing todo with the tuning, it was all CAMTuning magic.
Old 06-30-2009, 09:05 AM   #167
06rexwagon
Member#: 114730
2006 WRX Limited Wag
[email protected]
CJ, you and the guy you're arguing with are both right. Stoich for e85 is around 9.8. So 1 lambda is 9.8/9.8. Because your wideband is scaled for 1 lambda equals 14.7/14.7, it shows 11.7 in gasoline afr terms. If you programmed it for e85 it would show 7.67 because you're running .79 lambda (.79 x 9.8). It's all relative.
06rexwagon is offline   Reply With Quote
Old 06-30-2009, 12:26 PM   #168
C J
Member#: 132587
2006 JrTuned STi
[email protected]
Thanks man.
Old 06-30-2009, 12:42 PM   #169
thefoos
Member#: 144751
02 WRX BW EFR E85
7064 TS WRB
Bump for E85 Army stickers...I want to see a design!
Hopefully will be updating in a month or two. I've got a road dyno showing ~320 whp now and I'm sure its got 12's in it, but I haven't had a chance to prove it by getting a time slip...
thefoos is offline   Reply With Quote
Old 06-30-2009, 12:47 PM   #170
juanmedina
Member#: 133146
Thanks man.
CJ post your logs on the official road dyno thread. I want to see what you get from wrxsti.l? I was doing something wrong with my road dyno interpolation, he did mine and I got completely different numbers FTW
I can't wait to fix my car issues and see if I gain anything with my higher compression, ported heads and cams
Old 06-30-2009, 02:06 PM   #171
C J
Member#: 132587
2006 JrTuned STi
[email protected]
I will when I get home from work, the numbers Cam came up with using the same software are very similar to yours. Pretty sure they were 360/420 to be exact, just the other day someone locally here argued that 400+whp out of the stock turbo was impossible
Old 06-30-2009, 02:33 PM   #172
juanmedina
Member#: 133146
yeah 346whp on airboy's spreadsheet is like 380-390whp dynojet
and lets not talk about the torque 450wtq + on a dynojet
Old 06-30-2009, 02:57 PM   #173
tazswing
Member#: 63767
2009 OXT 5-spd
2011 STi hatch
I am scared with stock internals, but 26psi would be the target, if possible, with forged internals.
Yup, I think we were getting close to 95% by the end. It would be fun to build inside and see what the limits of those injectors are. I know that DW has some "true" 1000cc and that might be what it would take to run the E85 with this turbo at 26psi.
Sorry, no plans to build any time soon. I will go through tires fast enough with the torque as is
Old 06-30-2009, 03:40 PM   #174
C J
Member#: 132587
2006 JrTuned STi
[email protected]
26psi is no problem on stock internals with e85 and proper tuning, guys go 30+ with race fuel. Its not so much the boost pressure that blows engines its everything else related to the tune!
Old 06-30-2009, 07:39 PM   #175
C J
Member#: 132587
2006 JrTuned STi
[email protected]
btw who is doing stickers? Juan whats going on?!?
Motion Lab Tuned: Juanmedina's 2007 WRX E85 ARMY Motion Lab Tuning Proven Power Bragging 125 04-12-2010 03:57 AM
jid2 Track Car - e85 ARMY jid2 Member's Car Gallery 38 01-22-2010 11:44 PM
The Honduran army is the bravest in the world... wrxcelent Off-Topic 36 07-07-2009 09:21 AM
Spacific E85 Tuning thread Here ? discopotato03 Engine Management & Tuning 1 09-09-2008 12:01 PM
Did anyone hear the one about the Italian army and the IRAQI satiation? Asinine Off-Topic 3 09-20-2005 08:06 PM
