#1 |
Member#: 4739
I have a line on a nice 2002 2.5RS with a bad motor and a 2000 Impreza 2.2 longblock. I'd like to combine the two to keep the car rolling as a DD in preparation for a strong n/a rebuild on the 2.5 or a later turbo swap.
How easy is this swap for a driveway mechanic who can change brakes and suspension? Is all the wiring plug/play? What about fuel lines, A/C, etc? This would be my first major engine/trans related work of any kind. I'd buy or rent an engine lift and torque wrenches. I have a 100 pc Craftsman took kit. I could probably recruit a few gorillas to help too. I'd like to pull the trigger on this in a day or two, so any help would be greatly appreciated. I searched but couldn't find anything right off. Edit: how easy would it be to simply drop and rebuild the shortblock with stock parts? Should I worry about the metal in the oil screwing up the heads? Could I do this with basic tools and a torque wrench? 2nd Edit update: I guess the 2.2 is out of the question. I found a nice 2003 Baja engine with 57k for around a grand. The long-time Subaru tech selling it says it's a direct manifold swap (i.e keep the 2002 RS manifold, use the 2003 Baja longblock) if I plug the 2003's EGR tube. Any thoughts on that? I think I'll be doing this in my driveway next week. Doh! ![]()
#2 |
Member#: 4739
Or would it be even easier to drop the 2.5 shortblock and put in the 2.2 shortblock?
The 2.5 has bad knock and some metal in the oil. Are the heads a concern or should I assume they're OK, use a magnetic oil plug and change the oil every 1,000 a few times? Thanks! |
#3 |
Member#: 38222
Vehicle:'10 &'12 Foresters another Miata convert |
My guess is that the first thing you'd encounter, if nothing else, is a MAF/MAP conflict.
#4 |
Member#: 4739
OK. What about the short block swap? I'll dig around since I know that's been done, but any quick help would help, helpfully.
#5 |
Member#: 180527
South East
Vehicle:2005 Legacy GT 5MT Garnet Red Pearl |
It will probably easier getting the same exact motor, you should be able to find one for $500-600
#6 |
Member#: 28685
Vehicle:2004 FXT 4EAT very STi'd |
Yeah, getting a junkyard motor won't cost more than the rebuild kit really, and the 2 motors aren't plug-and-play. But most late EJ22s are MAP based. That said, the wiring is not directly compatible so it would take a lot of effort. Really, I would just find another phase II EJ25. I am pretty sure a 2000-2005 would be directly compatible with a manifold swap.
#7 |
Member#: 4739
Bump for edit question re: just rebuild it, dummy.
#8 |
Member#: 28685
If it's head gaskets, that's not that hard. If it's a bearing or bearings, that's probably more expensive than a used longblock, plus a lot more work.
#9 |
Member#: 4739
I found a nice 2003 Baja engine with 57k for around a grand. The long-time Subaru tech selling it says it's a direct manifold swap (i.e keep the 2002 RS manifold, use the 2003 Baja longblock) if I plug the 2003's EGR tube. Any thoughts on that? I think I'll be doing this in my driveway next week. Doh! ![]() |
#10 |
Member#: 28685
Sounds like a great option actually.
#11 | |
Member#: 5218
Vehicle:96L Most Over- Developed Beater |
The technician is right. Pull your intake manifold off, and put it on the other motor. FWIW...you can do this with the EJ22 as well. There shouldn't be any issues, as long as you swap the entire manifold and wiring harness so you end up with essentially the same thing as you had before, just less displacement. One thing with the EJ22, would be the exhaust manifold....it's different than the EJ25, so you'd need one specific to it.
Jay Quote:
| Thread Tools | |
| Display Modes | |
| Bad coolant leak, need help quick! | sorrowfulkiller | Factory 2.0L Turbo Powertrain | 16 | 01-22-2009 12:31 PM |
| Need help quickly please. Stage 2 Power Steering Issue. | nofriends | Factory 2.0L Turbo Powertrain | 2 | 12-30-2005 05:36 PM |
| for those with a viper 2 way, need help quick | MtlPete | Car Audio, Video & Security | 15 | 11-15-2005 03:34 PM |
| 225/45 17 on 2000 RS? Need help quickly. | willguidry | Tire & Wheel | 1 | 04-18-2003 11:58 AM |
| Need Help Quick 2.5RS Pointer | UltraGucci | Vancouver Impreza Club Forum -- VIC | 5 | 04-11-2002 06:03 PM |
