South West Impreza Club
Go Back   NASIOC > NASIOC Chapters > South West Impreza Club Forum -- SWIC
Old 03-27-2009, 01:43 PM   #1
SpankySuby
Member#: 122305
2002 wrx half breed
Default Oil cooler adapter plate?
Hey my ? is where did you guys get your oil cooler adapter plates im trying to find one that has AN-10 or 5/8" all the ones ive found are only 1/2" or AN-8 the oil cooler im getting is a Setrab that has AN-10 fittings now should i just stick with the AN-8 and get an expander to AN-10 and everything will be fine or is there one out there that has AN-10 that i just cant find. Thanks for anyones help.
SpankySuby is offline   Reply With Quote
Old 03-27-2009, 01:44 PM   #2
v8eaterWRX
Member#: 108547
2013 RAM 2500 4x4
6.7l Cummins
I have a Process West sending unit. I have had it since 2005 so I cannot recall where I ordered it. I like it a lot but I am not sure what fittings they make them for.
v8eaterWRX is offline   Reply With Quote
Old 03-27-2009, 02:35 PM   #3
WgnWheel
Member#: 63605
04 Wrx Wgn TimeAtk
10 Golf TDI, 08 Stang GT
try calling joe @ goodspeed? i have the greddy cooler and the adapter that came with it, is probably the nicest one i've seen as far as internal flow design.
WgnWheel is offline   Reply With Quote
Old 03-31-2009, 12:10 AM   #4
nosmo
Member#: 53142
06' STI,02WRX,982.5
www.Flat4lv.com
Mocal with stat. Only way to go SP1FT 20mm
When you go to -10an you'll only have to push it through the same -8an sized hole. Stick with the -8an. The subaru oil pump will thank you for this.
oh, my crack in my mocal core which dropped 3qts in a one block drive.
nosmo is offline   Reply With Quote
Old 03-31-2009, 10:24 AM   #5
SpankySuby
Member#: 122305
2002 wrx half breed
Good point but i have a high flow oil pump and im making 95 psi at WOT.
Old 03-31-2009, 10:57 AM   #6
bhhamblin
n00b Moderator
Member#: 99397
15 WRX, 83 DR30,
93 R32 GTS-T, 93 R32 GTR
I am using the Setrab core with the Mocal adapter plate with thermostat and have had zero issues. But it is -8AN
bhhamblin is offline   Reply With Quote
anyone try either of these oil cooler adapters? dan az Built Motor Discussion 31 11-20-2009 09:20 PM
has anyone tried either of these two oil cooler adapters? dan az Water/Methanol Injection, Nitrous & Intercooler Cooling 0 11-08-2009 12:40 PM
Oil cooler adapter plates. SpankySuby Private 'Wanted' Classifieds 1 03-27-2009 09:19 PM
Looking for thermostat controlled oil cooler adapter Mactizen Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 5 05-08-2007 11:44 PM
oil cooler adapter with t-stat - need info Mactizen Newbies & FAQs 2 05-04-2007 10:07 PM
