Old 03-27-2009, 02:16 PM   #1
shadymilkman129
Member#: 53651
Cert Suby tech
specialist for hire!
Exclamation Removing Cam Pully... PLEASE help
Working on an 05 sti motor and I have come to a grinding halt. I am trying to remove the cam pullys which are held in by the 9mm hex's
(thanks subau for not sticking with the 17mm nuts that worked great before)
and they absolulety will not come out.
I have tired a 450 lb impact, A breaker power with a torque extention which was bending before the hex nut even began to turn. Are these reverse threaded or somthing? Someone please let me know any experiance you have with removing the cam pullys, TY!
shadymilkman129 is offline   Reply With Quote
Old 03-27-2009, 02:22 PM   #2
mick_the_ginge
Citizen Mick
Member#: 27646
2003 Sleeved 2.5
Oil Dry Sump Goodness
They are 10mm, I use a breaker bar with a 3 foot extension to break them free. They are threaded normally
mick_the_ginge is offline   Reply With Quote
Old 03-27-2009, 02:33 PM   #3
shadymilkman129
Member#: 53651
Cert Suby tech
Ok, I will try a 10mm 1/2 hex and let u know if it works! Thanks in advance
Old 03-27-2009, 02:56 PM   #4
gabedude
Member#: 10108
07 STI
60Trim spun rod bearing
I leave the timing belt on and use a (1/2) 18 inch breaker bar with an impact wrench hex head while jamming something in the flywheel (on the stand). Works great but sometimes I think I am going to break the bolt right off. I found that just pushing really hard works better than trying to hammer on it.
gabedude is offline   Reply With Quote
Old 03-27-2009, 03:41 PM   #5
shadymilkman129
Member#: 53651
Cert Suby tech
WEll it turns out i was using a 10mm, however it was a 3/8 socket. Looked everywhere for a 1/2 10mm hex socket, but none of the parts stores have them. Hopefully snap on, matco, cornwell, or mac will have one when they stop by next week.... This is really anoying. Anyone out there able to get it off with a 3/8 10mm? I put a 1/2 converter on it and used a tourqe bar, but still just flex in metal, no loosing of the bolt.
Old 03-27-2009, 03:44 PM   #6
mick_the_ginge
Citizen Mick
Member#: 27646
2003 Sleeved 2.5
I've only snapped 3/8's 10mm's they are not beefy enough to break the cam bolts free
Old 03-27-2009, 03:46 PM   #7
shadymilkman129
Member#: 53651
Cert Suby tech
Ok ill wait for a tool truck. I just used my IR titanium 450 lb or tq and it didnt budge... Ill have to wait for the 1.2 insaid of the 3/8 with a 1/2 adapter.
Im definatley replacing these with the 17mm bolt style when I put it all back together
Old 03-27-2009, 03:46 PM   #8
Trox
Member#: 36785
05 STi (broke)
03 Focus
Be thankful it has not rounded
Trox is offline   Reply With Quote
Old 03-27-2009, 03:52 PM   #9
alcoolaid
Member#: 134949
'07 SWP STi
Instagram | arthurlam89
Leaving the timing belt and all the guides on with something jamming up the flywheel works.
10mm 3/8 drive will usually break. Try it with a 3/8 to 1/2" drive adapter and the adapter will usually break. 10mm 1/2" drive is the only thing that works. One was so tight I stripped the Mac Tool 10mm I was using. Just gave up drilled it out and bought a new bolt for $1.78.
alcoolaid is offline   Reply With Quote
Old 03-27-2009, 05:01 PM   #10
n2oiroc
Member#: 141952
15 legacy 16 wrx
drill the heads off.
n2oiroc is offline   Reply With Quote
Old 03-27-2009, 05:55 PM   #11
shadymilkman129
Member#: 53651
Cert Suby tech
I suppose if im replacing it with the 17mm nut style anyways i can just drill the front off the bolt..
Old 03-27-2009, 05:58 PM   #12
darksc00by
Member#: 102140
2016 Herp Derping
Engineer For Hire, yo.
not sure if it works like that, but I stripped a bunch on mine. I just use a normal impact to remove them now.
one time I had to cut into the bolt, notching it.. stuck a pry bar in there, and welded the two together, then put a pipe wrench on the bar, and got it off immediately.
darksc00by is offline   Reply With Quote
Old 03-27-2009, 06:25 PM   #13
carnz-pj-410
Member#: 110994
2004 Impreza WRX STi
Genius Tools makes a 10mm 1/2 inch drive one you can use. I've used mine many times along with a 24 inch SK breaker bar and I've gotten them off pretty successfully
carnz-pj-410 is offline   Reply With Quote
Old 03-27-2009, 08:24 PM   #14
Fongers
Member#: 118239
2002 Built Wagon
Wife- 2004 Outback SE
Do it by hand so you don't strip the hex. Just man up with a breaker bar and it will come open. I actually even used a 3/8th drive one with a 1/2 adapter.
Fongers is offline   Reply With Quote
Old 03-31-2009, 01:03 PM   #15
shadymilkman129
Member#: 53651
Cert Suby tech
I purchased an impact half inch hex drive set and aired up my impact that puts out 350 lbs, still nothing. Tried it by hand, still nothing. Im lost and dont understand why they are not breaking free...
Funny thing is, I work on subarus ALL the time, and this is my first build and i cant even get the freakin cam pull bolts out...
Old 03-31-2009, 01:10 PM   #16
ec2k1gt
Member#: 129631
06 Obp Sti
back to slow lolz
Have you tried using a long breaker bar (2-3ft) on the 1/2 socket?
ec2k1gt is offline   Reply With Quote
Old 03-31-2009, 01:14 PM   #17
shadymilkman129
Member#: 53651
Cert Suby tech
Yup tried that along with using a breaker bar to prevent belt movment and still nothing...
Old 03-31-2009, 01:20 PM   #18
madmax718
Member#: 172501
You can get away with a 3/8th, but it will most likely snap. If not on the first, then on the second... I went through 3 3/8th craftman (not the best quality), before I got the gearwrench 10mm half inch drive.
I do not recommend impact with it though, if you can avoid it. Increased possibility of rounding out the inside. 3-4 ft cheater bar, along with a friend to make sure its "square" in the hole. Support the cam with the cam tool, on a jack stand. Works great.
madmax718 is offline   Reply With Quote
Old 03-31-2009, 01:26 PM   #19
bigmike25rs
Member#: 83924
2005 HTA 86 STi
10.66 @ 136 mph
Agreed.. The hex bolts will round out if you keep blasting it with an impact. I usually try an impact on each one with the belt on and if it doesn't immediatly come loose, I'll grab a breaker bar.. I've used our 1000ft/lb Ti impact on them and still nothing.. Breaker bar all the way! Haha.. I've even bent both of our COBB cam tools that we have.. I remember pulling on the breaker bar and hearing a creaking noise.. I thought it was coming loose, but it was the COBB tool bending.lol
bigmike25rs is offline   Reply With Quote
Old 03-31-2009, 02:19 PM   #20
n2oiroc
Member#: 141952
15 legacy 16 wrx
it takes 3 minutes a piece to drill the heads off.....
Old 03-31-2009, 04:45 PM   #21
M3GTR
Member#: 21965
V-mounted 40R...what
Just make sure you don't try to reuse ANY of the cam gears. I've seen them shatter after they've been impacted.
M3GTR is offline   Reply With Quote
Old 04-01-2009, 09:16 PM   #22
STiGMATA
Member#: 47564
06 STi
black w/black BBS
removal of those 10mm hex bolts was by far the worst part od disassembly....broke 3 craftsman 10mm and bought a 10mm gearwrench 3/8 socket and they finally came off.....id say about 600lb.ft.
STiGMATA is offline   Reply With Quote
Old 04-01-2009, 09:26 PM   #23
Rickyh
Member#: 40453
Mine popped right off. I used a 10mm allen wrench stuck in the end of a four foot long jack handle. I had the motor on the engine stand and had someone hold it still. All four popped right off.
Harbor freight has 10mm half inch hex sockets. I have also used them with a 3 foot long breaker and they work fine also.
You are gonna have to man up and put some serious leverage on that bolt and hang on that sumbeotch until it breaks loose.
Rickyh is offline   Reply With Quote
Old 04-01-2009, 09:37 PM   #24
kaos200
Member#: 2692
kaos200 is offline   Reply With Quote
Old 04-01-2009, 10:01 PM   #25
robbieshonda
Member#: 122306
2002 Sti PTE 6262
Interlagos Blue 551/441
I do the same thing as the link. I use the vise grips and timing belt trick works liek a charm. Now I have a motor at the shop That i can not break the cam bolts loose to save my life. I had to tig weld a nut to the allen section since it spun it came loose but screw it. I'll buy one of those allenheads and see how they work.
robbieshonda is offline   Reply With Quote
my cam specs please help! INFMIS Built Motor Discussion 10 01-30-2009 02:38 PM
removing rear bumper please help acidrain088 Newbies & FAQs 0 07-05-2007 10:10 PM
CAMs Q? please help. Assami Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 9 12-02-2006 01:59 PM
removing fuse box, please HELP!!! Lordhowe Electrical & Lighting 2 12-30-2004 07:06 PM
Removing superglue residue- please help! topher Interior & Exterior Modification 9 12-18-2001 01:44 AM
