03-27-2009, 02:25 PM | #1 |
Member Sales Rating: (4)
Member#: 53651
Vehicle:Cert Suby tech specialist for hire! |
Subaru Serivce Tables...
Someone erequested this. so here it is: Need anything done let me know.
Maintenance Items 3,750 7,500 11,250 15,000 18,750 Air Filter Element Brake Fluid Replace Brake Hose/Line Inspect Inspect Cabin Air Filter Replace Replace Clutch, M/T Inspect Constant Velocity Joint Boot Inspect Inspect Coolant Cooling System Disc Brake System Inspect Inspect Drive Belt Engine Oil Replace Replace Replace Replace Replace Fluid - A/T Replace Fluid - Differential Replace Fluid - M/T Inspect Fuel Filter Inspect Fuel Supply Line Inspect Inspect Oil Filter, Engine Replace Replace Replace Replace Replace Parking Brake System Inspect Inspect Spark Plug Steering and Suspension Inspect Inspect Timing Belt Tires Rotate Rotate Wheel Bearing Maintenance Items 22,500 26,250 30,000 33,750 37,500 Air Filter Element Replace Brake Fluid Replace Brake Hose/Line Inspect Inspect Inspect Cabin Air Filter Replace Replace Replace Clutch, M/T Inspect Constant Velocity Joint Boot Inspect Inspect Inspect Coolant Replace Cooling System Inspect Disc Brake System Inspect Inspect Inspect Drive Belt Inspect Engine Oil Replace Replace Replace Replace Replace Fluid - A/T Replace Fluid - Differential Replace Fluid - M/T Inspect Fuel Filter Inspect Fuel Supply Line Inspect Inspect Inspect Oil Filter, Engine Replace Replace Replace Replace Replace Parking Brake System Inspect Inspect Inspect Spark Plug Steering and Suspension Inspect Inspect Inspect Timing Belt Inspect Tires Rotate Rotate Rotate Wheel Bearing Maintenance Items 41,250 45,000 48,750 52,500 56,250 Air Filter Element Brake Fluid Replace Brake Hose/Line Inspect Inspect Cabin Air Filter Replace Replace Clutch, M/T Inspect Constant Velocity Joint Boot Inspect Inspect Coolant Cooling System Disc Brake System Inspect Inspect Drive Belt Engine Oil Replace Replace Replace Replace Replace Fluid - A/T Replace Fluid - Differential Replace Fluid - M/T Inspect Fuel Filter Inspect Fuel Supply Line Inspect Inspect Oil Filter, Engine Replace Replace Replace Replace Replace Parking Brake System Inspect Inspect Spark Plug Steering and Suspension Inspect Inspect Timing Belt Tires Rotate Rotate Wheel Bearing Maintenance Items 60,000 63,750 67,500 71,250 75,000 Air Filter Element Replace Brake Fluid Replace Replace Brake Hose/Line Inspect Inspect Inspect Cabin Air Filter Replace Replace Replace Clutch, M/T Inspect Inspect Constant Velocity Joint Boot Inspect Inspect Inspect Coolant Replace Cooling System Inspect Disc Brake System Inspect Inspect Inspect Drive Belt Inspect Engine Oil Replace Replace Replace Replace Replace Fluid - A/T Replace Replace Fluid - Differential Replace Replace Fluid - M/T Inspect Inspect Fuel Filter Replace Inspect Fuel Supply Line Inspect Inspect Inspect Oil Filter, Engine Replace Replace Replace Replace Replace Parking Brake System Inspect Inspect Inspect Spark Plug Replace Steering and Suspension Inspect Inspect Inspect Timing Belt Inspect Tires Rotate Rotate Rotate Maintenance Items 78,750 82,500 86,250 90,000 93,750 Air Filter Element Replace Brake Fluid Replace Brake Hose/Line Inspect Inspect Cabin Air Filter Replace Replace Clutch, M/T Inspect Constant Velocity Joint Boot Inspect Inspect Coolant Replace Cooling System Inspect Disc Brake System Inspect Inspect Drive Belt Inspect Engine Oil Replace Replace Replace Replace Replace Fluid - A/T Replace Fluid - Differential Replace Fluid - M/T Inspect Fuel Filter Inspect Fuel Supply Line Inspect Inspect Oil Filter, Engine Replace Replace Replace Replace Replace Parking Brake System Inspect Inspect Spark Plug Steering and Suspension Inspect Inspect Timing Belt Inspect Tires Rotate Rotate Maintenance Items 97,500 101,250 105,000 108,750 112,500 Air Filter Element Brake Fluid Replace Brake Hose/Line Inspect Inspect Inspect Cabin Air Filter Replace Replace Replace Clutch, M/T Inspect Constant Velocity Joint Boot Inspect Inspect Inspect Coolant Cooling System Disc Brake System Inspect Inspect Inspect Drive Belt Replace Engine Oil Replace Replace Replace Replace Replace Fluid - A/T Replace Fluid - Differential Replace Fluid - M/T Inspect Fuel Filter Inspect Fuel Supply Line Inspect Inspect Inspect Oil Filter, Engine Replace Replace Replace Replace Replace Parking Brake System Inspect Inspect Inspect Spark Plug Steering and Suspension Inspect Inspect Inspect Timing Belt Replace Tires Rotate Rotate Rotate Maintenance Items 116,250 120,000 123,750 127,500 131,250 Air Filter Element Replace Brake Fluid Replace Brake Hose/Line Inspect Inspect Cabin Air Filter Replace Replace Clutch, M/T Inspect Constant Velocity Joint Boot Inspect Inspect Coolant Replace Cooling System Inspect Disc Brake System Inspect Inspect Drive Belt Engine Oil Replace Replace Replace Replace Replace Fluid - A/T Replace Fluid - Differential Replace Fluid - M/T Inspect Fuel Filter Replace Fuel Supply Line Inspect Inspect Oil Filter, Engine Replace Replace Replace Replace Replace Parking Brake System Inspect Inspect Spark Plug Replace Steering and Suspension Inspect Inspect Timing Belt Tires Rotate Rotate Wheel Bearing Inspect Maintenance Items 135,000 138,750 142,500 146,250 150,000 Air Filter Element Replace Brake Fluid Replace Replace Brake Hose/Line Inspect Inspect Inspect Cabin Air Filter Replace Replace Replace Clutch, M/T Inspect Inspect Constant Velocity Joint Boot Inspect Inspect Inspect Coolant Replace Cooling System Inspect Disc Brake System Inspect Inspect Inspect Drive Belt Engine Oil Replace Replace Replace Replace Replace Fluid - A/T Replace Replace Fluid - Differential Replace Replace Fluid - M/T Inspect Inspect Fuel Filter Inspect Inspect Fuel Supply Line Inspect Inspect Inspect Oil Filter, Engine Replace Replace Replace Replace Replace Parking Brake System Inspect Inspect Inspect Spark Plug Steering and Suspension Inspect Inspect Inspect Timing Belt Tires Rotate Rotate Rotate Wheel Bearing
FS : (LA) 2006 Subaru WRX STi Aspen White PRICE DROP $19000 obo More Pics page 3 | Dustin77 | Private Vehicle 'For Sale' Classifieds | 68 | 06-16-2010 02:43 PM |
Subaru Rally Team to visit Wyoming Valley Motors / Subaru | SRT USA | Mid Atlantic Impreza Club -- MAIC | 0 | 06-04-2010 09:35 AM |
FS: Solid Oak Dining Table w/ 8 chairs and 2 leafs, end table, and sofa table | grimwagon | RMIC Private Classifieds | 0 | 08-31-2009 03:32 PM |
STAY AWAY from Subaru of Gwinnett Serivce Dept... | JC | South East Region Forum | 76 | 09-22-2005 03:18 AM |
Ggood serivce place in Sonoma County, CA? | bob.lund | Dealership Reviews | 0 | 03-16-2003 09:52 AM |
