Go Back   NASIOC > NASIOC Classifieds > Vendor 'For Sale' Classifieds > Suspension/Brakes/Handling
Closed Thread
Old 03-27-2009, 04:12 PM   #1
RaceComp Engineering
Vendor Sales Rating: (30)
Member#: 54202
ASK ABOUT NEW RCE
SWAY BARS FOR STI
Default Doooood!!! Ohlins Fixed Perch Struts with RCE Yellow Springs!!!!!!
We have a couple of Ohlins Fixed Perch Struts IN STOCK that we need to get out of here to make room for new 08 and 09 parts!
We've put together a package deal using the classic Ohlins + RCE Yellow combo that's perfect for the all around spirited daily driver.
RCE Yellow Springs
$2350 shipped
RCE Yellow Springs
Group N front and rear top hats
$2720 shipped
$2520 shipped with just front Group N's
Call 410-579-1501 to order!
__________________
Racecomp Engineering
512 Shaw Ct, Suite 104
Severn, Maryland 21144
410-846-5407
RaceComp Engineering is offline
Old 03-27-2009, 04:12 PM   #2
Member#: 54202
ASK ABOUT NEW RCE
SWAY BARS FOR STI
zomg!!
racecomp engineering black and yellow springs in stock
We have just received a fresh batch of these bad boys. There are so many boxes stacked up in the office, we can barely find the phone.
Racecomp Engineering Super Sport Street/Track Springs
The highly anticipated Super Sport Street/Track Springs, an OEM replacement spring for 2004-2007 Subaru WRX STi from Racecomp Engineering. Designed for use with standard STi inverted struts or Ohlins Fixed Perch Replacement Struts, these springs are intended for both the daily driven street driver as well as the autocross and track day weekend warrior. Finally, after years of being the authority on Subaru suspension options for everyone from the daily driver to the professional racer, Racecomp Engineering can now provide their own solution to owners looking for the ultimate OEM replacement spring for their Subaru Impreza WRX STi. Using the very popular JDM STi springs that we brought to the U.S. market in mid 2003 as the benchmark, Racecomp focused on improving on track and autocross performance, while maintaining acceptable ride quality. Extensive research, design, and testing was performed to develop a completely new spring unlike anything currently available. With springs rates increased approximately 25% stiffer then the popular JDM Pink Springs, the springs are perfect for those with wider tires worried about rubbing, as well those looking for a little more rear spring rate to promote a more neutral handling characteristic. Much care was taken not to exceed the limits of the stock struts. The mildly progressive design and spring rates properly matched with the dampers ensure that ride quality is not diminished over stock. The car is lowered 20mm in the rear and 23mm in the front for an even look.
For iwsti members $309 Shipped.
Racecomp Engineering Black "Regular Guy" Springs
Introducing the RCE Regular Guy Springs (RCE Blacks), an OEM replacement spring for 2004-2007 Subaru WRX STi and the next in the Racecomp Engineering growing line of performance springs for Subaru Impreza, Subaru Legacy, and Mitsubishi Evolution. Designed for use with standard STi inverted struts or Ohlins Fixed Perch Replacement Struts, these springs are intended for both the daily driven street driver as well as the autocross and track day weekend warrior. Using similar spring rates as the extremely popular and successful RCE Yellow Springs, but having a much more subtle/mild drop in comparison, these are perfect for STi owners not looking for a ride height much lower then stock, and yet are still looking for increased spring rates. Spring rates are still 10% stiffer then JDM Pinks with an emphasis on the rear rate, so you will still be outpacing just about everything on the track and auto-x course.
Call or PM us to place an order. Provided we can find the phone when you call
__________________
410-846-5407
Old 03-27-2009, 04:13 PM   #3
Member#: 54202
ASK ABOUT NEW RCE
SWAY BARS FOR STI
GTWorx Camber Plates by Racecomp Engineering for Subaru Impreza
Hanover, Maryland March 26th, 2009.
Introducing the first in an all new line of parts from GTWorx, the sister company of Racecomp Engineering. Drawing upon the extensive chassis design knowledge and experience that comes from designing several suspension and brake components with RCE, GTWorx is proud to announce their Camber Adjustment Pillowball Mounts for 2002-2007 Subaru Impreza. 2008+ Subaru Impreza GR chassis and 2005+ Legacy will be available shortly. These camber plates are currently intended for coilovers only, however, testing is underway for use with OEM style fixed perch struts.
Key features of these new front camber plates include a very low stack height, which means that these top mounts are non-raising at most camber settings. For a coilover at a given ride height, the user will have MORE bump travel with the GTWorx plate when compared to most other currently available plates on the market which raise the car substantially.
In addition, +.8 degrees of caster are built in to the camber plate, which helps minimize dynamic camber loss in a turn for the camber challenged Impreza chassis.
These lightweight alloy camber plates use the same high quality PROVEN pillowball bearing used in the popular Racecomp Engineering Camber Plates, which are known for smooth, long lasting, and quiet operation. Hardware is zinc coated stainless steel. Each bearing is rated at 37,000 lbs radial and 7,730 lbs axial force.
A fact worth noting is that the relatively straightforward and simple design means that these durable plates are available at a realistic price much cheaper than the popular Racecomp Engineering camber plates.
Below as shown with KW 60mm perches.
For more information or to place an order, please call 410-579-1501!
$359 + shipping
__________________
410-846-5407
Old 03-27-2009, 04:14 PM   #4
Member#: 54202
ASK ABOUT NEW RCE
SWAY BARS FOR STI
2008+ STI and WRX Starter Kit
Improve all aspects of your GR Impreza with this starter kit.
Better handling, better response, and more power!
Cobb Accessport Engine Management
Whiteline 22mm adjustable front swaybar
Whiteline 22mm adjustable rear swaybar
Kartboy Pitch Stop Mount
Whiteline Steering Rack Bushings
$1240 shipped
Starter Kit PLUS Package
STI Group N Front Top Mounts
$1390 shipped
Regular Guy Starter Package
Racecomp Engineering Regular Guy Performance Springs
Super mild drop to preserve damper travel. Spring rates designed to match the stock valving and improve performance. Stay tuned for more details.
$1730 shipped
Call 410-579-1501 to order or discuss options!
__________________
410-846-5407
Old 03-27-2009, 04:16 PM   #5
Member#: 54202
ASK ABOUT NEW RCE
SWAY BARS FOR STI
The New Yorker Project STI Package
Transform your GR into the ultimate Subaru
Racecomp or Vorshlag Front Camber Plates
Racecomp Engineering Clubsport Coilovers
Whiteline Roll Center Kit
Whiteline Anti-Lift Kit
Cusco Front Lower Brace Type-2
Cusco Front Strut Tower Brace Type-OS
Whiteline Rear Camber Adjustment Kit
$3694 shipped
Call for additional options like swaybars, custom spring rates, Cobb Accessport, and more!
__________________
410-846-5407
Old 03-27-2009, 04:17 PM   #6
Member#: 54202
ASK ABOUT NEW RCE
SWAY BARS FOR STI
Racecomp Engineering T2 Clubsport Coilovers by KW
Racecomp Engineering is proud to announce their Clubsport Coilovers for the 2008 STi! One of the most anticipated suspension options for the new body style Impreza is available now!
These are a true 2008 STi Impreza fitment with valving and spring rates specific to the completely new 2008 chassis. These are not cobbled together from existing parts....these are designed from the ground up to provide a track worthy, easily serviceable and long lasting threaded body coilover suspension system for the 2008 STi.
These coilovers feature the same inox-line stainless steel corrosion resistant construction as previous versions of KW suspensions. Spring rates are 8kg front and 8kg rear. These are aggressively valved, 2 way adjustable, performance coilovers. These are valved more aggressively then the standard KW Variant 3's, yet still offer an amazing ride quality not felt with other brands. These do not come with strut top mounts, but we have a few options available.
$2295 shipped for coilovers only
$2570 shipped with Group-N front tops and STi rear tops, fully assembled
$2655 shipped with Cusco front camber plates and STi rear tops, fully assembled
Ohlins 2008 STi Sportline DFV Coilovers
Ohlins has announced their new DFV Sportline Height Adjustable coilover suspension for the 2008 STI.
Long known for their excellent racing and street dampers, Ohlins is now able to offer a street/track solution for the new 2008 Subaru Impreza.
Highly flexible damping range allows for comfortable street ride and excellent track performance. New DFV (Dual Flow Valve) technology allows for more advanced valving on both the rebound and compression side, resulting in even better ride quality and performance. A first for Ohlins Sportline on a Subaru, these coilovers are dual height adjustable, allowing separate preload and ride height adjustments.
Combined with the 2008 Impreza's redesigned rear suspension, Ohlins is able to take the tenacious grip offered by the new STI one giant step forward, while allowing the user to fine tune the balance and handling of the car.
*Includes front camber plates and rear pillowball top mounts
*Separate ride height and preload adjustment
*Spring rates are 500 lbs/in front and 400 lbs/in rear
*Custom spring rates and valving are available
$CALL!
__________________
410-846-5407
Old 03-27-2009, 04:18 PM   #7
Member#: 54202
ASK ABOUT NEW RCE
SWAY BARS FOR STI
Racecomp Engineering GR Chassis Camber Plates
Based off of the highly successful GD style RCE camber plates, we have extended our lineup to include the GR chassis. Basically identical to the previous generation's camber plate except for the obvious new strut top design that came along with the new chassis. These will be offered in both lowering and non-lowering versions. We are accepting preorders now for these which will be available shortly.
$499 shipped
Racecomp Engineering GR Chassis Sway Bars
These are in the works, more information to follow shortly. Please give us a call to discuss what we have planned and to get on the preorder list.
Whiteline GR Chassis Sway Bars
Whiteline 22mm Front Adjustable Sway Bar - $175 shipped
Whiteline 24mm Front Adjustable Sway Bar - $197 shipped
Whiteline 20mm Rear Adjustable Sway Bar - $197 shipped
Whiteline 22mm Rear Adjustable Sway Bar - $197 shipped
Cusco GR Chassis Suspension Parts
Cusco OS Front Strut Tower Brace - $168 shipped
Cusco Type-2 Front Lower Arm Brace - $170 shipped
This mount is a huge upgrade over the stock piece. No added harshness, no negatives to this upgrade. Really improves comfort and feel and its cheap! This piece will fit the 2008 Imprezas.
$120 shipped
The KCA334 Anti-Lift/Caster Kit is designed by Whiteline and adds approximately +0.5 deg static caster to both front wheels while changing the nature of front anti-dive and anti-lift geometry. The low-compliance polyurethane bushings also maintain higher dynamic positive caster.
$121 shipped
__________________
410-846-5407
Old 03-30-2009, 10:51 AM   #8
Member#: 54202
ASK ABOUT NEW RCE
SWAY BARS FOR STI
Bump!
__________________
410-846-5407
Old 03-31-2009, 03:11 PM   #9
Member#: 54202
ASK ABOUT NEW RCE
SWAY BARS FOR STI
Bump!
__________________
410-846-5407
Old 04-02-2009, 10:16 PM   #10
Member#: 54202
ASK ABOUT NEW RCE
SWAY BARS FOR STI
pull it up to the bumper bay bee.........
__________________
410-846-5407
Old 04-03-2009, 12:47 PM   #11
Member#: 54202
ASK ABOUT NEW RCE
SWAY BARS FOR STI
Bumper!
__________________
410-846-5407
Old 04-06-2009, 11:20 AM   #12
Member#: 54202
ASK ABOUT NEW RCE
SWAY BARS FOR STI
Bumps!
__________________
410-846-5407
Old 04-07-2009, 01:25 PM   #13
Member#: 54202
ASK ABOUT NEW RCE
SWAY BARS FOR STI
Bump!
__________________
410-846-5407
Old 04-09-2009, 11:07 AM   #14
GTWORX.com
Vendor Sales Rating: (10)
Member#: 97303
2009 WRX and Boxster
Gray and Black
Bumps!!!
__________________
GTWORX - 410-846-5633
- BILSTEIN- Cobb - WHITELINE- Kartboy - KW - AST - STOPTECH - SPARCO-JRZ
GTWORX.com is offline
Old 04-10-2009, 12:01 PM   #15
GTWORX.com
Member#: 97303
Gray and Black
Bump!!!
__________________
Old 04-13-2009, 10:31 AM   #16
GTWORX.com
Member#: 97303
Gray and Black
Bump!
__________________
Old 04-14-2009, 01:01 PM   #17
GTWORX.com
Member#: 97303
Gray and Black
Bump Up!!
__________________
Old 04-16-2009, 12:14 PM   #18
GTWORX.com
Member#: 97303
Gray and Black
Bump Bump Bump Bump
__________________
Old 04-17-2009, 12:47 PM   #19
Member#: 54202
ASK ABOUT NEW RCE
SWAY BARS FOR STI
tops!
__________________
410-846-5407
Closed Thread
FS NJ: Ohlins Fixed Perch Struts and RCE V2 Yellow Springs OppositeLock Suspension/Brakes/Handling 30 02-11-2009 06:32 PM
NJ FS: Ohlins Fixed Perch Struts and RCE V2 Yellow Springs OppositeLock Tri-State Area Private Classifieds 13 02-11-2009 06:30 PM
fs: Ohlins Fixed Perch struts and RCE yellows steve VIC Private Classifieds 19 05-19-2008 11:59 AM
fs: Ohlins Fixed Perch struts and RCE yellows steve Canada Region Private Classifieds 0 05-01-2008 01:52 PM
Ohlins Fixed perch struts,Race comp Engineering Springs & Camber plates,Group N rears Delta22 Suspension/Brakes/Handling 25 06-12-2007 10:49 PM
