Old 03-30-2009, 03:01 AM   #26
i_c_the_light
Member#: 88618
1994 Legacy
"The Silver Slug"
Originally Posted by RealDealTarheel View Post
^^This, I don't think even Subaru really has a firm grasp of which motor they put in which car, much less someone in the states buying front clips and tearing down motors.
I'd say they decided much like the same way Japanese car manufacturers choose model names: throw random words into a vacuum cleaner and put it into reverse.
i_c_the_light is offline   Reply With Quote
Old 03-30-2009, 01:57 PM   #27
spazmoo
Member#: 140183
2005 Legacy GT
Originally Posted by Flat4TW View Post
why cant your friend do the search himself? if hes engine is fine stick with it until it dies... if he got the dough go for either an ej207 or ej257 build.
my friend doesn't have the patience to do the search, and i am always interested in doing a little bit of research. His oil line to his turbo was leaking and he ended up running out of oil. He says it runs real rough now and he already had hopes of putting a stronger engine in. I did a search initially for the EJ20G and didn't find much concerning why so many people liked it. All I found were mods and such.
spazmoo is offline   Reply With Quote
Old 03-31-2009, 02:54 PM   #28
94 GT
Member#: 193676
94 legacy GT
silver (grey soon!!)
the way to find a closed or open deck blocks are to look down in front of the starter hump on the engine block and look for the casting lines with 2 little nubs sticking up the open deck ones are smooth!!!
94 GT is offline   Reply With Quote
Old 03-31-2009, 03:43 PM   #29
spazmoo
Member#: 140183
2005 Legacy GT
a picture would seriously help.
Old 03-31-2009, 05:09 PM   #30
RallyColtTurbo
Member#: 16819
RallyColtTurbo is offline   Reply With Quote
Old 03-31-2009, 06:27 PM   #31
Matt Monson
Member#: 832
99 2.5RS, '85 911
'73 914 and 2012 BRZ
Originally Posted by RallyColtTurbo View Post
Another tell is the crosshatching you can barely see on the hollow "tube" where the head bolts run into the block, which is directly below where the black coolant line is bolted down in the foreground of the above picture.
Also, there are multiple casting molds of the closed deck blocks. I've seen them both with and without crosshatching on the mating line of the block halves directly above where the crank sensor bolts down.
Old 04-01-2009, 11:22 PM   #32
spazmoo
Member#: 140183
2005 Legacy GT
wow, those pictures are perfect. Thank you so much.
I had a long chat with my friend and he said he was only looking for horsepower in the 350-450 horsepower range. He said he wanted that much power to the wheels. Is 25% a good number to use to calculate loss of efficiency through drivetrain? If the EJ257 block is stout to those numbers, I will tell my friend that he is wasting his money.
Old 04-02-2009, 12:19 AM   #33
Hareball
Member#: 165025
I'm in kind of the same boat as far as wondering wtf an EJ20K is, I recently purchased a 1998 WRX STi Type-R coupe w/ an ej20k and while I know a bit about ej205/255 engines I'm slightly befuddled by my new ej20k.
Hareball is offline   Reply With Quote
Old 04-02-2009, 12:53 AM   #34
RallyColtTurbo
Member#: 16819
EJ20K is the evolution of the EJ20G. Heads are the main difference. They switched from a HLA (hydraulic lifter) under the cam bucket on the EJ20Gs to solid shim adjusted bucket. This allowed the engine to rev higher reliably. Some versions have the shims under the bucket where they cannot be "spit" out, for one more level of reliability. Cams are generally "hotter" on the EJ20Ks also.
The EJ20K was the last of the phase 1 motors to go into the Impreza. Phase 2 was a minor block redesign with the biggest change being moving the crankshaft thrust surface from the center (#3) journal to the rear (#5) journal. Phase 1 motors end with a letter (EJ20G, EJ25D, etc.) while phase 2 motors end with a number (EJ205, EJ251, etc).
Old 04-02-2009, 01:16 AM   #35
sense of nature
Member#: 112759
2002 STi Mikey Tuned
SexyRP
As Tony says G stands for GGGGGGGGggrrrrrrrrrrreeeeaaaaaat ! IMO anyway
sense of nature is offline   Reply With Quote
Old 04-04-2009, 02:26 PM   #36
adbramsay
Member#: 152345
2000 R34 GTS-T sedan
Originally Posted by scby rex View Post
www.rogerclarkmotorsport.co.uk/shop_detail.asp?productID=1036
EJ20 closed-deck block is one of the strongest Scooby starting points around and one of that was equipped with oil squirters to aid pistons cooling. Closed-deck blocks are the strongest blocks of Subaru and endure high boost and high horse power (700+hp). Heres a pic of a jdm ver7 ej207 and a ej20g.
are you sure thats an ej207 on the left? that doesnt look anything like my motor and i have a jdm ver 7 sti limited.
adbramsay is offline   Reply With Quote
Old 04-04-2009, 02:40 PM   #37
Matt Monson
Member#: 832
99 2.5RS, '85 911
There's a pretty short list of Subaru engines that used a semi-closed deck block...
Old 04-04-2009, 03:38 PM   #38
adbramsay
Member#: 152345
ej207, ej208, and the ej257. and i think that the motor on the right is not the ej20g but in fact the ej22 motor from the 22b, it used a closed deck block with ver 4 sti heads. that motor was crazy!!! IMO I dont think that there was a better 2.0-2.5 litre turbo motor ever made from the factory.
Old 04-04-2009, 03:48 PM   #39
RallyColtTurbo
Member#: 16819
Originally Posted by adbramsay View Post
.........and i think that the motor on the right is not the ej20g but in fact the ej22 motor from the 22b, ...........
Oil squirters indicate it's most likely a Legacy motor. Either USDM EJ22T or EJ20G. (I'm guessing 20G, from the bore size) I'm not sure if the early STIs/RAs still had the squirters.
EJ22G from the 22B did not have oil squirters.
I'm sure Matt will speak up if I missed anything.
Old 04-04-2009, 07:10 PM   #40
94 GT
Member#: 193676
94 legacy GT
The cross hatching on the front were the block halves meet! Are they STi or RA motors??? my Ej22 closed deck block did'nt have them but my STi Ej20G block has them! was that a way of denoting higher from lower performance Engines at the factory????
Old 04-04-2009, 07:53 PM   #41
scby rex
Member#: 104878
02 wrxbastardchild
aw, MPS 2.34 breaking in
Yes the pic I posted has a ej207 ver7 on the left and a eg20g on the right. 100% sure as a friend is building the G.
scby rex is offline   Reply With Quote
Old 04-04-2009, 08:14 PM   #42
Matt Monson
Member#: 832
99 2.5RS, '85 911
The Ej22T's don't have it.
I've only ever seen it on 1995 STI Ej20G blocks. All of the ones I've seen earlier than 1995 that were closed deck didn't have it either.
Oil squirters have nothing to do with STi engines. In fact, Reddevil has even confirmed that he's found them on open deck Ej20H blocks.
Old 04-04-2009, 09:21 PM   #43
suberdave
Member#: 101865
88 GL-10 STi
i have a EJ20H Block that has oil squirters...
it is nothing special...
-=Suberdave=-
suberdave is offline   Reply With Quote
Old 04-07-2009, 08:10 PM   #44
94 GT
Member#: 193676
94 legacy GT
yeah my 4A-GE toyota non torbo or supercharged has then too!!! it is a good idea though keep that Detionation away buy keepin them kool!! (I don't know how much it would actually help detionation but good lubing anyways!!
Old 04-08-2009, 04:59 AM   #45
ncarn8
Member#: 71419
i closed the oil squirters up on both my builds. Runs fine, im more interested in bearings getting oil at 8200rpm than pistons get arbitrarily splashed
ncarn8 is offline   Reply With Quote
Old 04-08-2009, 08:42 AM   #46
Matt Monson
Member#: 832
99 2.5RS, '85 911
Exactly. I suspect Subaru drew the same conclusion since there are no squirters on a 22B.
Old 04-08-2009, 12:48 PM   #47
adbramsay
Member#: 152345
i know kinda off topic and am sorry for hijacking the thread but as far as i can tell you guys seem to know the most about jdm engines on this site. what in order are the top 5 strongest?
afaik they are
1) ej22g (22b)
2) ej207 (ver 7+ sti)
3) ej208 (b4/gtb legacy)
4) ej20k (ver 4+ sti)
5) ej20r (98 gtb)
Old 04-09-2009, 10:05 AM   #48
spazmoo
Member#: 140183
2005 Legacy GT
the hijack works in my favor. I want to be able to tell my friend about the strongest blocks we have.
Old 04-09-2009, 08:12 PM   #49
94 GT
Member#: 193676
94 legacy GT
do the oil squirters run off the crank main??? that is probly the earlier turbo engines burned through rod bearings!! THAT Happened to my 22T and I think that it is starting on my STi tooo!!! (Ihope not) what do you have to do to block tham (if that in fact will bring better crank pressure??
Old 04-09-2009, 08:33 PM   #50
scby rex
Member#: 104878
02 wrxbastardchild
afaik they are
1) ej22g (22b)
5) ej20r (98 gtb)
Why would you have the open deck blocks in 2nd and 3rd?
what is an acessport and what is turbo pressure meter for? lasercombo Newbies & FAQs 43 02-13-2006 10:56 PM
WHAT IS AN ALK???? Frey Bone Newbies & FAQs 9 06-01-2001 05:51 PM
What is an Air Assist Solenoid? KeithRS Normally Aspirated Powertrain 8 05-08-2001 10:22 PM
What is an S-AFC? datpnoy2nv Normally Aspirated Powertrain 5 05-03-2001 03:25 AM
('93-'01) What is an Impreza C-21???? TurboRX Impreza Forum 0 04-12-2001 10:07 AM
