Old 04-17-2009, 04:56 AM   #76
Marnix
Member#: 51480
1984 AM5, 1984 AF1,
1994 BC4, 2015 Outback
The early Legacy EJ20G heads (rocker HLAs) and Impreza EJ20G heads (direct HLAs) can be disguised by the quantity of ribs on the valve cover: the rocker heads have those ribs above and below the plug holes, the later heads only have them above the plug holes.
And all EJ208 (manual twin turbo) and EJ206 (auto twin turbo) are open deck - I've dismantled quite a few of them.
Marnix is offline   Reply With Quote
Old 04-17-2009, 09:51 AM   #77
adbramsay
Member#: 152345
2000 R34 GTS-T sedan
Originally Posted by RallyColtTurbo View Post
Before you get hammered by the regulars.....MOST Turbo EJ motors have been open. From the EJ20Gs all the way up to the EJ205s.
Most CURRENT EJ turbo motors are semi closed.
i thought that in this thread we just went over the fact that the ej20g was closed? i know that the ej20k/r are semiclosed as i have ripped them apart. the ej207 is semi closed as we all know, so how many are open and how many are semi closed and how many are closed deck? i am getting confused here. sorry, can we just get a list going here? please modify list accordingly please.
and thanks Marnix for correcting me on the ej208
semi-closed:
ej20k
ej20r
ej207
closed:
ej20g
ej22g
open:
ej206
ej208
adbramsay is offline   Reply With Quote
Old 04-17-2009, 10:13 AM   #78
Matt Monson
Member#: 832
99 2.5RS, '85 911
'73 914 and 2012 BRZ
adbramsay,
I think you are getting confused because you've got the definitions wrong. Go back to page one and look at the picture of the semi-closed deck Ej207. You will notice that it has braces on the end and the sides of the cylinder. The open deck engines don't have braces on the sides.
Ej20K is open deck by that definition, as is Ej206, Ej205, Ej20h and Ej208.
Not ALL Ej20G's are closed deck. I gave a generalized explanation of what years and models were closed deck earlier in this thread. However, I think it's safe to say that 90% of the Ej20G's ever made were OPEN deck. Closed deck Ej20G's are more rare than generally assumed.
Also, you left the Ej22T off your list of closed deck engines. The Ej22G is not the same thing as an EJ22T. Different block from different castings. There are 2 different closed deck 2.2l blocks out there.
Old 04-17-2009, 12:36 PM   #79
adbramsay
Member#: 152345
Originally Posted by adbramsay View Post
semi-closed:
ej207
closed:
ej20g(casting lines 10%-15%)
ej22g
ej22t
open:
ej20k
ej20r
ej20g(no casting lines 85%-90%)
ej20h
ej205
ej206
ej208
Originally Posted by Matt Monson View Post
adbramsay,
thanks matt!!! although i am still not so sure that all the ej20k/r are all open i will check and see if i can find out.
Old 04-18-2009, 02:40 PM   #80
Marnix
Member#: 51480
1984 AM5, 1984 AF1,
All EJ20K and EJ20R are open deck. And to add to the confusion: the EJ207 of the GC8 (MY99-00) is also open deck; the first EJ207 to be semi-closed was introduced in the MY01 GDB STI and carried over right into the new GRB.
Old 04-18-2009, 05:45 PM   #81
adbramsay
Member#: 152345
kewl thanks!!!
Old 04-18-2009, 09:45 PM   #82
94 GT
Member#: 193676
94 legacy GT
silver (grey soon!!)
I"m quite sure that this is a 1995 STi Ej20g with a 90 degree turbo sorry as I'm not sure of what turbo it is but I think it is a TD05 I may be wrong there!!!! I have no idea what it is out of??? as the place I got it had not much of a clue as I could probly guess better thanks to nasioc!!! it is a closed deck the coils have 1 bolt retaining them I'm not sure of the ribs on the valve cover that Marnix is talking about but I will find out soon!!!
BUt is it normal for these engines to have a noisy valvetrain??? the 22T's was quiet but the heads were rebuilt earlier this year!! (unfortuneatly the bottom end was not!!!) but yeah I need to know if this noise is gonna wreck the valvetrain??
The wreckers said that the engine had like 70,000k's on it but they hardly knew bout it so yeah !!
What cars did a engine like this come in?? only Impresa's or whould it come in a leggy too??
Thanks Jesse
94 GT is offline   Reply With Quote
Old 04-21-2009, 06:41 PM   #83
Matt Monson
Member#: 832
99 2.5RS, '85 911
94 GT. If you are sure that it's a '95 and it's closed deck then it's definitely an STi variant. Nothing but STi engines (and even then not all of them) were closed deck by then. 90 degree inlet with a td05 is some version of a 93-96 WRX sedan EJ20G.
Try seafoaming the engine and see if that helps. It sounds like grungy HLA's. Often after these engines sit for a while they take some time to clean themselves out and get full pressure in the HLA's. They may just stop making noise on their own, though it's possible a couple of them are blown. On the other hand, it's very very unlikely that you would have solid lifters but it's possible.
Old 05-05-2009, 08:27 AM   #84
RealDealTarheel
Member#: 142447
06 Outback
Not true, on several counts
Only really early Ej20G's(like 89-91) or STi's(up through 1995) were closed deck. 90% of them were not.
Originally Posted by RealDealTarheel View Post
So when my 94 WRX gets it's heads pulled for an HG change I will find an open deck block?
Originally Posted by Cbgrandtheftauto View Post
Yes and yes...they are all the same as far as strength.
Originally Posted by WRX_RA View Post
no and yes..
just pulled the heads off my 93 wrx and its a closed-deck block.
Originally Posted by i_c_the_light View Post
I'd say they decided much like the same way Japanese car manufacturers choose model names: throw random words into a vacuum cleaner and put it into reverse.
Just to throw some water to a drowning man, here is the block out of my 94 WRX, plain jane WRX sedan. TD05H 16G turbo of course.
RealDealTarheel is offline   Reply With Quote
Old 05-06-2009, 07:47 AM   #85
Marnix
Member#: 51480
1984 AM5, 1984 AF1,
The very first series of WRX's (build from November 1992 into somewhere in 1993) had the closed deck block, too
Old 05-06-2009, 09:58 AM   #86
RealDealTarheel
Member#: 142447
06 Outback
Hmmm, I thought that 94 was a V2 WRX? Closed deck motors don't grow from trees, and you have to know what to look for, but they aren't too hard to run across over here.
Old 05-06-2009, 03:02 PM   #87
Splinter
Member#: 106510
98 Widebody 3.4L
Smooth Safety Blue
The very early WRXs seem to be odd ducks indeed.
My friend has a 92, and it has alloy control arms and a 16G turbo, which is very clearly stock. His VIN denotes a non-RA wrx.
Next time I see him I'll look for the crosshatching on the block, I never thought to look before.
Splinter is offline   Reply With Quote
Old 05-22-2009, 07:41 AM   #88
James Gt EB
Member#: 127514
2000 Impreza
Here in South Africa there has been a lot of discusion about why more people dont run these blocks..., there seems to be the suggestion that a closed deck block runs hotter than semi closed or open and therefore wouldnt suit our climate....??? any opinions or proof on that note...??? Are closed decks only to be used in colder climates...????
James Gt EB is offline   Reply With Quote
Old 05-22-2009, 10:03 AM   #89
Matt Monson
Member#: 832
99 2.5RS, '85 911
I am adding this over here since this thread gets pulled up a lot in searches. This is the single best post I have seen about the whole open deck versus closed deck question with respect to which cars had what.
More info on engine codes:
Closed deck (according to JDM factory parts CD-ROM):
EJ20GDW1HD 1992-05-01 to 1993-08-31 WRX.EJ20G
EJ20GDW1HE 1992-05-01 to 1993-08-31 WRX.EJ20G
EJ20GDW1HJ 1992-05-01 to 1993-08-31 WRXRA.EJ20G
EJ20GDW1HR 1992-05-01 to 1993-08-31 WRXRA.EJ20G
EJ20GDW2HD 1993-05-01 to 1994-09-30 S.WRX.MT.EJ20G
EJ20GDW2HE 1993-05-01 to 1994-09-30 S.WRX.MT.EJ20G
EJ20GDW2HJ 1993-05-01 to 1994-09-30 WRXRA.EJ20G
EJ20GDW2HR 1993-05-01 to 1994-09-30 WRXRA.EJ20G
EJ20GDW4HJ 1993-06-01 to 1995-08-31 WRXRA.EJ20G
EJ20GDW5HJ 1995-09-01 to 1996-08-31 WRXRA.EJ20G (STI VERSION)
Open deck:
EJ20GDX1ND 1993-05-01 to 1994-09-30 AT.EJ20G
EJ20GDX1NE 1993-05-01 to 1994-09-30 AT.EJ20G
EJ20GDW1ND 1993-05-01 to 1994-09-30 W.MT.EJ20G
EJ20GDW1NE 1993-05-01 to 1994-09-30 W.MT.EJ20G
EJ20GDW4HD 1994-06-01 to 1995-08-31 S.WRX.EJ20G
EJ20GDW4HE 1994-06-01 to 1995-08-31 S.WRX.EJ20G
EJ20GDW4ND 1994-06-01 to 1995-08-31 W.WRX.MT.EJ20G
EJ20GDW4NE 1994-06-01 to 1995-08-31 W.WRX.MT.EJ20G
EJ20GDX4NE 1994-06-01 to 1995-08-31 WRX.AT.EJ20G
EJ20GDW5HE 1995-09-01 to 1996-08-31 S.WRX.EJ20G
EJ20GDW5NE 1995-09-01 to 1996-08-31 W.WRX.MT.EJ20G
EJ20GDX5NE 1995-09-01 to 1996-08-31 AT.EJ20G
EJ20GDX5HD 1995-09-01 to 1996-08-31 S.WRX.EJ20G
EJ20GDW5PE 1995-10-01 to 1996-08-31 W.WRX.MT.EJ20G (STI VERSION)
EJ20GDW5PE 1995-10-01 to 1996-08-31 WRXSTI.EJ20G
EJ20GDW5PJ 1995-10-01 to 1996-08-31 WRXRASTI.EJ20G
Please note that this is based on factory information although I'm almost certain that a part of it cannot be correct!
Old 05-22-2009, 10:09 AM   #90
Matt Monson
Member#: 832
99 2.5RS, '85 911
That's been debated here in the states as well. I don't know if anyone has a defnitive answer. The one thing I can say is that Subaru continues to use a closed deck Ej20 in the WRC until this day. Those cars suffer through some extreme conditions in very hot environments around the world. It's a tough comparison to make though since those engines are generally torn down and refreshed after every race.
I think that's really a point that's often ignored. If someone wants to build a high powered street car that sees the occasional track day or weekend race event it's one thing. If it becomes a dedicated racecar in any type of racing it's got to be refreshed with regularity. It's just the nature of the beast. My business is gearboxes. I've got race customers who send us their box two or three times a year for cars they use in amateur racing. Even though they aren't pros, these cars are purely racecars and they're driven in a dozen or more events a year with it being a mix of 1 hour events and 3 hour enduros. You reach a point where it becomes about how many hours you race between rebuilds.
For a street car, regardless of final power goals, I personally think there's nothing to worry about with respect to additional heat retention on a closed deck engine. And if it's a racecar you've just got to be sure to rebuild it often enough. If you don't, you'll spin a rod bearing in competition and then you might lose your whole block when you put a rod through it.
Old 05-22-2009, 01:34 PM   #91
James Gt EB
Member#: 127514
2000 Impreza
Thanks Matt, yeah I agree with you, I suppose theres one thing for it and that is to give it a bash and see how it turns out..., there is one available that I know of.., maybe I make him an offer and turn into a long term project.
I dont see why it shouldnt work, if it does run hot surely a radiator upgrade is the answer..?? (a stronger than std head gasket would also help)....
Old 05-22-2009, 08:17 PM   #92
dboostjuice
Member#: 206216
all the 2.0's i have been in had nothing going on below 35-4krpm.
the 2.2s and 2.5's have all this grunty torque for a 4 zyl. down low!
2.2 closed deck is where its at!
dboostjuice is offline   Reply With Quote
Old 05-23-2009, 03:13 AM   #93
James Gt EB
Member#: 127514
2000 Impreza
Old 05-23-2009, 10:02 AM   #94
Matt Monson
Member#: 832
99 2.5RS, '85 911
Originally Posted by dboostjuice View Post
yo "G" is for gangsta!
D (as in dboostjuice) is for acting like a dumbarse.
Old 05-25-2009, 08:47 PM   #95
i_c_the_light
Member#: 88618
1994 Legacy
"The Silver Slug"
You're a tool.
i_c_the_light is offline   Reply With Quote
Old 06-03-2009, 08:54 PM   #96
Turbotime05
Member#: 178524
2006 Evo IX
Tarmac black
So i have an 02 wrx with a spun bearing.. been reading about hybrid builds for days and prolly gonna go that route. But a guy near me is selling a closed deck forged ej20g for cheap. This wont work with my 02 heads on it due to a bump in compression? How bad will the diffrence be?.
Turbotime05 is offline   Reply With Quote
Old 06-03-2009, 11:08 PM   #97
RealDealTarheel
Member#: 142447
06 Outback
It should be a pluck and chuck operation if you're just using the block. Just use the right HG and you shouldn't run into any issues. Correct me if I am wrong Guru's.
Old 12-03-2009, 03:04 AM   #98
Chi_San
Member#: 53558
2005 Baja Sport
Gray/Silver two tone
Sorry to bump an old thread, had a question that I couldn't answer by searching.
What is the compression ratio on a stock EJ20G?
Chi_San is offline   Reply With Quote
Old 12-03-2009, 08:49 AM   #99
Marnix
Member#: 51480
1984 AM5, 1984 AF1,
8.0 or 8.5 or 9.0 depending on year and application.
Old 12-03-2009, 02:06 PM   #100
Chi_San
Member#: 53558
2005 Baja Sport
Excellent. Since I have no idea the year or application the motor is I'm getting, this really will be fun!
what is an acessport and what is turbo pressure meter for? lasercombo Newbies & FAQs 43 02-13-2006 10:56 PM
WHAT IS AN ALK???? Frey Bone Newbies & FAQs 9 06-01-2001 05:51 PM
What is an Air Assist Solenoid? KeithRS Normally Aspirated Powertrain 8 05-08-2001 10:22 PM
What is an S-AFC? datpnoy2nv Normally Aspirated Powertrain 5 05-03-2001 03:25 AM
('93-'01) What is an Impreza C-21???? TurboRX Impreza Forum 0 04-12-2001 10:07 AM
