Old 12-16-2009, 12:54 AM   #101
bl_easy
Member#: 91407
Ver. 2 WRX STi wagon
BRetty green
How can one tell more information on the car without the VIN plate... just the VIN etched on the firewall? I have what is from my understanding a 93 WRX, but the half cut came without a VIN plate.
bl_easy is offline   Reply With Quote
Old 12-16-2009, 01:43 AM   #102
suberdave
Member#: 101865
88 GL-10 STi
look on the front of the engine, with any luck the engine number will still be on the sticker on the timeing belt cover, this will tell you some more info...
-=Suberdave=-
suberdave is offline   Reply With Quote
Old 12-16-2009, 02:38 AM   #103
Chi_San
Member#: 53558
2005 Baja Sport
Gray/Silver two tone
-=Suberdave=-
More info on this? I've got an EJ20G longblock I'm about to disassemble, and it appears to be open deck. I do happen to have the sticker you just mentioned...
Block's at school, won't be able to see it again until some time in January.
Chi_San is offline   Reply With Quote
Old 12-16-2009, 04:57 AM   #104
Marnix
Member#: 51480
1984 AM5, 1984 AF1,
1994 BC4, 2015 Outback
Check the code on the sticker with the list in a quote on the previous page. If it's not on there, drop me a line. Oh and if you can get your VIN before you get access to the block, post it here and I'll be able to tell more.
Marnix is offline   Reply With Quote
Old 12-16-2009, 11:07 AM   #105
bl_easy
Member#: 91407
BRetty green
I know which sticker you guys are talking about, however my engine did not come with that sticker intact.
My VIN is GC8-006986.
I was at the car last night and didn't think to look at the bellhousing to see if it was finned or not. And the turbo heat shield is still there so I haven't seen what kind of turbo it has.
Old 12-17-2009, 10:34 AM   #106
Matt Monson
Member#: 832
99 2.5RS, '85 911
'73 914 and 2012 BRZ
Let's make this easy. Pull up the carpet and get us the part number and alphanumeric code off the ECU.
Old 12-17-2009, 10:42 AM   #107
bl_easy
Member#: 91407
BRetty green
I believe that it is either a 2C or a 3S. I've got a few ECUs at home so I can't remember exactly which one came off this car
Old 12-17-2009, 02:12 PM   #108
Matt Monson
Member#: 832
99 2.5RS, '85 911
Well, the 2C ECU would be the one from the 1993 WRX GC8. A 3S is from a wagon and a couple of years later. Looks like you've got a standard 240ps '93 WRX cut there.
Old 12-17-2009, 02:24 PM   #109
Marnix
Member#: 51480
1984 AM5, 1984 AF1,
It is a GC8A48D, built in March 1993, sedan WRX with EJ20G engine.
Engine is either an EJ20GDW1HD or EJ20GDW1HE; ECU is most propably 22611AA810 (U8). Standard power output 240 PS and 31.0 kg-m running on a TD05.
Old 12-17-2009, 05:17 PM   #110
bl_easy
Member#: 91407
BRetty green
Thanks! What database are you getting this information from?
Old 12-18-2009, 01:01 AM   #111
Marnix
Member#: 51480
1984 AM5, 1984 AF1,
Original JDM parts CD-ROM.
Old 12-18-2009, 10:40 AM   #112
bl_easy
Member#: 91407
BRetty green
Oh, sweet.
You were right about the ECU being a 22611AA810, but I didn't see a U8 on it anywhere, just a 2C. I don't know where I was thinking of a 3S from, since the other one I had at home next to it was a B5... all this ECUs
Old 12-18-2009, 12:02 PM   #113
Marnix
Member#: 51480
1984 AM5, 1984 AF1,
Oh OK the AA810 ECU's I've seen had the U8 code, so I learned something again today
Matt, do you know the difference between 2C, U8 etc. although they have the same factory part number?
Old 12-18-2009, 12:25 PM   #114
Matt Monson
Member#: 832
99 2.5RS, '85 911
I don't know this, but I suspect that one is 1993 and the other is 1994. Same thing tough, AFAIK.
Old 12-18-2009, 07:40 PM   #115
bl_easy
Member#: 91407
BRetty green
Perhaps the difference in ECU codes also correlates with the engine codes Marnix suggested for my car. Unfortunately my motor has no sticker.?
Old 01-21-2010, 02:45 AM   #116
i_c_the_light
Member#: 88618
1994 Legacy
"The Silver Slug"
Just a small bump...
I've recently purchased a JDM 1990 Legacy GT auto with the VF-10 and I can't see any cross-hatching on the top of the block, so I'm going to assume it's OD. Which is interesting since my GT manual of the same year had the hatching.
Chassis codes for the manual and auto respectively are: BF5-023639 and BF5-023393. The only differences between the two is the transmission, ABS and cruise control. Other than that they are the same.
i_c_the_light is offline   Reply With Quote
Old 01-21-2010, 04:31 AM   #117
Marnix
Member#: 51480
1984 AM5, 1984 AF1,
Not all early Legacy's had the closed deck block. All EJ20 turbo's and EJ20 non-turbo's build before 1991-7 have closed deck blocks, after that I believe only all manuals and only some autos.
Old 01-21-2010, 02:09 PM   #118
i_c_the_light
Member#: 88618
1994 Legacy
"The Silver Slug"
Both were registered in 1990 though, and I had the build date checked on the manual for ****s and giggles. I know it was 1990, however I always get the build month for the manual GT and my old turbo Leone Coupe confused. One was March, the other was November and I can't remember which one was which. I could just get the build date checked on the auto if I felt like it.
Old 07-28-2012, 05:35 PM   #119
jtwrx02
Member#: 327235
2002 wrx
So I have an 02 wrx an I am looking for am engine an transmission. How this is listed I would like help an engine from a legacy gt & rs twin turbo engine transmission an ecu ej20 will fit correct? I am not installing having a pro do it but need help an wanting to learn more about subies
jtwrx02 is offline   Reply With Quote
Old 07-28-2012, 07:24 PM   #120
i_c_the_light
Member#: 88618
1994 Legacy
"The Silver Slug"
Why do these pop up all the time? Why are people wanting the most LEAST RELIABLE Subaru turbo engine in their cars? What is it about the sequential twin fail that makes it so appealing?
Old 07-28-2012, 08:06 PM   #121
jtwrx02
Member#: 327235
2002 wrx
I want to find out which is a reliable.affordable engine an I just don't have the knowledge so do you have a suggestion I c the light ?
Old 07-29-2012, 02:37 AM   #122
i_c_the_light
Member#: 88618
1994 Legacy
"The Silver Slug"
Yes. A USDM EJ205 for 2002 wrx.
Old 07-29-2012, 03:17 AM   #123
Marnix
Member#: 51480
1984 AM5, 1984 AF1,
All the post 1999 JDM EJ205 engines have the higher compression ratio (9.0) so make them less suitable for US fuels.
Want a reliable engine? Rebuild your own (presumably failed) engine with forged rods and pistons.
Old 07-31-2012, 07:40 AM   #124
impreza_GC8
Member#: 123295
2001 RSTI Version 6
STM
I absolutely love threads like these, I have a soft spot for pre-2002 factory turbo power train useless knowledge. Keep the info flowing, ya'll are my kinda people.
impreza_GC8 is offline   Reply With Quote
Old 07-31-2012, 04:05 PM   #125
i_c_the_light
Member#: 88618
1994 Legacy
"The Silver Slug"
I fail to see how this information is useless. Unlike USDM turbo engines, specifications are far from straight forward or consistent for us. But thanks
what is an acessport and what is turbo pressure meter for? lasercombo Newbies & FAQs 43 02-13-2006 11:56 PM
WHAT IS AN ALK???? Frey Bone Newbies & FAQs 9 06-01-2001 06:51 PM
What is an Air Assist Solenoid? KeithRS Normally Aspirated Powertrain 8 05-08-2001 11:22 PM
What is an S-AFC? datpnoy2nv Normally Aspirated Powertrain 5 05-03-2001 04:25 AM
('93-'01) What is an Impreza C-21???? TurboRX Impreza Forum 0 04-12-2001 11:07 AM
