Old 03-27-2009, 10:53 PM   #1
D Money
Member#: 109948
. Most famous car
on Nasioc ever. :/
Default Jet hot coating?
So as many of you know I have a fully built motor and have NO idea where my egt's may be once the car gets running. I have somewhat of a simple question, just need a little guidance.
Jet-hot offers a sick looking polished aluminum ceramic coating finished called extreme sterling which can substain egts up to 1700 degrees. My questions is what should I expect my egts to be cruising, WOT, and max? Would I see something like 1500 on the regular? If so, this coating may not work from what the guy at Jet-hot told me. Well he said, "You'd blister that son bitch" in the most North Carolina voice i've ever heard.
I planned on doing my up-pipe, exhaust housing, and down pipe.
link to jet-hot coatings and pics:
http://www.jet-hot.com/headercoatings.html
I basically need to know:
1. The egts i'd most likely be around (if that's possible to estimate)?
2. If anyone else runs a jet-hot ceramic coat and if so which one?
3. Should I stop worrying about bling and just get the jet-hot 2000 coating which is just flat black but will substain any egt temp I could see in this car?
D Money is offline   Reply With Quote
Old 03-27-2009, 11:41 PM   #2
andya
Member#: 200134
You can use the "Bling" on the down pipe, but high temp on the up-pipe and turbo housing....... outside only.. just in case it starts to flake and gum up the works.
andya is offline   Reply With Quote
Old 03-28-2009, 08:30 AM   #3
Unabomber
👌 Big Ron 👌
Member#: 18062
on car parts so PM
me b4 j00 buy
Old 03-28-2009, 03:11 PM   #4
D Money
Member#: 109948
. Most famous car
on Nasioc ever. :/
is swaintech really better? I checked there site but can't find their ceramic coatings...
Does anyone know where the egts should be on a wrx?
Old 03-28-2009, 09:41 PM   #5
Dasani
Top Scoob 005
Member#: 58098
10.4 @ 137.46mph
Cosworth, TSR70, MZM Tune
I used the Jet-Hot 2000 coating on the same parts you mentioned.
It's not bling-blingy, but it does an excellent job.
I wouldn't use their Sterling/Extreme coatings on a turbo application. I do however have the Extreme coating on my Ninja's header.
-D
Dasani is offline   Reply With Quote
Old 03-28-2009, 11:53 PM   #6
06njsti
Member#: 150986
06 #001 LSB STi
D this summer im gonna be doing ceramic coating on little misc **** up at my dads shop. I will be getting all the necessary supplies, and if you wanna do your stuff at the same time you can. Not sure how soon you need them though
06njsti is offline   Reply With Quote
Old 03-29-2009, 02:53 PM   #7
D Money
Member#: 109948
. Most famous car
on Nasioc ever. :/
-D
Dasani, I totally get what you're saying but that gray kills me. I couldn't do it. I'd rather chance it haha. Do you have pics of your ninja header? I was curious to see the sterling silver on something.
haha thanks for the offer man but I need this done this week. haha
Old 03-29-2009, 03:15 PM   #8
jays05
Member#: 78165
05 STI 35r + e85
I see 1300-1400f at cruise, and max EGT in 5th gear is 1670-1690f. 1-4th WOT is usually under 1600f.
jays05 is offline   Reply With Quote
Old 03-29-2009, 04:50 PM   #9
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
QuickSilver Metallic
Do the EGTs get that high at shows?
Old 03-29-2009, 08:31 PM   #10
D Money
Member#: 109948
. Most famous car
on Nasioc ever. :/
Damn so this is a no go then. I need the jet-hot 2000 only.
haha you're such a queer.
Old 03-29-2009, 08:49 PM   #11
mannslayer
Member#: 94978
Originally Posted by D Money View Post
sick looking
mannslayer is offline   Reply With Quote
Old 03-29-2009, 09:33 PM   #12
waynoSTI
Member#: 162151
2.6L BLUE THUNDER
LOW&WIDE&SHAVED
the company over here in Canada fireball coatings coats the inside with the black 2000 and then the outside with the xmc polished silver!
waynoSTI is offline   Reply With Quote
Old 03-29-2009, 09:40 PM   #13
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
I had my last header coated by Jet Hot with Extreme Stirling. I was actually very disappointed in how little difference it made compared with bare metal.
Old 03-29-2009, 11:39 PM   #14
D Money
Member#: 109948
. Most famous car
on Nasioc ever. :/
Can you post their contact information? I'd like to see their work.
What do you mean? As far as holding the heat in or how it looked?
Old 03-29-2009, 11:41 PM   #15
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
Holding the heat in. Well, not holding the heat in was the problem. Massively increased under hood temps compared to the stock header plus it was letting the exhaust cool to the point the cats wouldn't light off. Obviously, the thinner aftermarket piping itself lets more heat off but the hope had been that the ceramic coating would help enough to offset that. It didn't.
Headers are now wrapped and there's been a HUUUUUGE drop in underhood temps!
Old 03-29-2009, 11:47 PM   #16
D Money
Member#: 109948
. Most famous car
on Nasioc ever. :/
Well I didn't plan on ceramic coating my header since it's wrapped. I wanted to do my down pipe, up pipe, and dump tube because it looks like ass. UR kits aren't exactly the most eye appealing and I want this engine bay to look like you can eat off of it.
Here is an example of what I wanted done, but im not sure it will last long...
Old 03-30-2009, 08:18 AM   #17
MartinSTi05
Member#: 145145
2006 wrx STi
Had my first set of FR stuff coated with it. It is more like a silver paint than a ceramic coating. I would not recommend it unless you only wanted something for appearance. Plus Dmoney, I would not be the least bit surprised if the heat raidated off of a poorly insulated turbo system F'ed up the paint applied to surrounding surfaces. If I were you I would use the Swaintech White lightening coating that Unabomber suggested, much thicker and better at retaining heat. If worst comes to worst you can coat the White Lightening with whatever color VHT Flameproof paint you would like.
But if It was me I would wrap it;-)
MartinSTi05 is offline   Reply With Quote
Old 03-30-2009, 08:24 AM   #18
rjrutzky
Member#: 30367
2005 Legacy GT
NASA SE PTB Champ
Assuming that you want looks first and performance second, don't get the swain tech. It works the best, but it is by far the ugliest.
rjrutzky is offline   Reply With Quote
Old 03-30-2009, 09:15 AM   #19
D Money
Member#: 109948
. Most famous car
on Nasioc ever. :/
Thanks Martin! I also contacted full-race about this and they said this is what they use. Did the jet hot extreme sterling coating turn gray after it was used or it stayed in that finish?
obviously I need the performance aspect too, seeing as the car will be setup to be raced and make power. I just wanted it to look good as well considering the time and money spent in the engine bay tucking, shaving, replacing every bolt, powdercoating all pieces, and making everything look brand new. Why would I not want to continue that process?
Anyways, thanks for being a dick man. I guess you don't remember me when I sent you the money for parts I bought from you...
Old 03-30-2009, 10:06 AM   #20
rjrutzky
Member#: 30367
2005 Legacy GT
NASA SE PTB Champ
I wasn't being a dick. I know that you would hate the swain tech, so I advised against it. The swain tech is good, but ugly as sin. It gets all pimply looking when hot.
Old 03-30-2009, 10:36 AM   #21
D Money
Member#: 109948
. Most famous car
on Nasioc ever. :/
You laughed at the old man who always talks **** to me, that made me furious. Anyway, I checked out the swaintech and it looks good IMO. I think that and jet hot 2000 both look good, just not as good as the extreme sterling. I guess I will go black and get a turbo blanket.
Will the down pipe be just as hot as the up pipe and turbo housing? Maybe I can still do that in extreme sterling.
Old 03-30-2009, 10:59 AM   #22
ownnij
Member#: 70459
2002 AW Bugeye ej257
6spd, GT3076R, Alky & EWG
what the hell do you do for a living D?
ownnij is offline   Reply With Quote
Old 03-30-2009, 11:20 AM   #23
D Money
Member#: 109948
. Most famous car
on Nasioc ever. :/
Travel Agent and full-time student.
Old 03-30-2009, 01:43 PM   #24
frayz
Member#: 106909
2002 V7 STi Prodrive
Edition... Black!
Long way to send stuff but without doubt, the best money can buy...
http://www.zircotec.com/
My headers are done with this and my new turbo system will be also. If its good enough for F1 and the likes of the gobstopper... it will do me just fine
frayz is offline   Reply With Quote
Old 03-30-2009, 02:43 PM   #25
Baay
Member#: 139645
07 WRX
UGM
D, as said before you can Swaintech your stuff then just use a high temp rattle can paint to give the white some color, its not gonna look all smooth but will work way better than thin coatings.
Baay is offline   Reply With Quote
Jet HOT coating/ Ceramic coating drale954 Mid West Subaru Owners Club Forum -- MWSOC 11 04-18-2004 11:25 AM
Jet Hot coating... Is it that beneficial?? jetfan8178 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 17 01-06-2003 02:07 PM
Jet Hot Coating Locally? subachad Bay Area Impreza Club Forum -- BAIC 2 12-03-2001 03:50 PM
Where can I get Jet-Hot coating in the East Bay? P.K. Motorsports Bay Area Impreza Club Forum -- BAIC 0 02-07-2001 10:58 PM
