Old 03-28-2009, 12:50 AM   #1
kh15
Member#: 132400
Default how many gauges off one power source?
right now im running a 20amp fused wire directly from the ign harness to my wb02, and boost gauge to power them.
I just ordered a oil pressure, and egt gauge that i plan to use the same power source for. Can i just keep using the ign harness for power as long as i use the correctly rated fuse in-line?
Im pretty sure after i install these additional 2 gauges i will be done. I may get a fuel pressure gauge in the future though.
thanks in advance
kh15 is offline   Reply With Quote
Old 03-28-2009, 07:36 PM   #2
kh15
Member#: 132400
bump!!!
Old 03-28-2009, 07:45 PM   #3
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
If only gauges are on that circuit, a 20A fuse is way too much. Gauges don't draw a lot of current, when you have all of them installed a 5A fuse will be more than enough. Also it depends on whether you are running the illumination through that circuit, the lighting will draw more current than the gauges themselves.
Old 03-29-2009, 02:20 PM   #4
kh15
Member#: 132400
for the illumination source im using the wire that goes to the clock pod.
how many gauges is to many? kh15 Electrical & Lighting 3 07-06-2008 03:45 PM
so how many complaints must one receive zmw Texas Impreza Club Forum -- TXIC 25 08-24-2004 09:27 PM
How many and which ones? Cronos Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 01-25-2004 08:08 PM
3 Gauges from one power source? SJwrx Electrical & Lighting 2 11-08-2003 05:54 PM
Can I run 2 amps off one power cable? mms4ba Car Audio, Video & Security 12 10-17-2002 12:19 PM
