Old 03-28-2009, 03:42 AM   #1
subaru fan
Member#: 127910
04 STI silver
Default quick question on my vf 39 build
I have a 04 sti
flashed with cobs stage 2 map
mods
cobb catted down pipe
gready ti c cat back
cobb intake heat box is coming
turbo xs top mount
now in the future i wana put a 20 g on but for now i plan on getting my tune with these parts on it that i have waiting to be installed for my tune
44mm ewg
port and polish and heat warped exhaust manifold
tgv deleats
255 lph fuel pump
prodrive boost Solenoid
gimmick turbo inlet
then my tune
Now my question is.
are bigger fuel injectors such as 850cc really worth the extra 500 bucks for my vf39 or should i hold out on them until i put the 20g on as well?
hold out on the injectors?
or get some and put them on before my tune?
subaru fan is offline   Reply With Quote
Old 03-30-2009, 08:28 PM   #2
Scoooooootles
Member#: 191791
2006 Impreza WRX
Wait for the 20G.
Scoooooootles is offline   Reply With Quote
Old 03-30-2009, 08:33 PM   #3
hustleshark206
Member#: 182227
2000 MPS Built RS
1991 Leggy Turbo EJ22t
wait for 20g. You will have to tune after the new turbo anyways.
hustleshark206 is offline   Reply With Quote
Old 03-30-2009, 11:53 PM   #4
Team Scream
Member#: 121532
2006 FXT/STi 6MT
01 Aerosim GC8 Coupe
I think both of teh replies above are incorrect.
I say the only way to know if your injectors will be sufficient is the day you get tuned and log idc's you will discover in short order if your injectors are up to the task.
I have a 39 on my car right now and at peak load I hit 90% idc.
That is on a conservative 10.5:1 AFR at the same load however.
Team Scream is offline   Reply With Quote
quick question on my vf 39 build subaru fan Newbies & FAQs 3 03-28-2009 03:31 AM
quick question on my turbo swap mystilexzero Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 3 02-27-2008 04:40 PM
A couple quick questions on my hybrid RS-T build silentt Normally Aspirated with bolt-on Forced Induction Powertrain 5 06-23-2007 10:34 PM
Quick question on my speeding ticket... Beam Tri-State Area Forum 4 06-12-2003 12:30 AM
