Vancouver Impreza Club
Old 03-28-2009, 06:25 AM   #1
banman
Member#: 12408
2006 Legacy GT
Default Question for 1st Gen Legacy owners
Who else has one besides know1?
Anyway, a friend of mine just got a free 1993 Legacy wagon (I think it's an L, so don't get too excited). I'm trying to troubleshoot it by proxy . . .
Anyway, apparently the engine occasionally stalls when warm when the clutch is depressed. He thinks it might be the idle air control unit, but I'm not so sure. Any other ideas, or diagnostic tests to narrow it down?
banman is online now   Reply With Quote
Old 03-28-2009, 06:38 AM   #2
MacNews
Member#: 186100
2006 B9 Tribeca
I've got a first gen Legacy, but no knowledge so I can't help.
Bump!
MacNews is offline   Reply With Quote
Old 03-28-2009, 08:54 AM   #3
bender
Member#: 1839
the first thing that I would do is check the throttle body.
is it badly gummed up?
is it coated in oil? (blow by)
if it is, try cleaning it with carb cleaner
bender is offline   Reply With Quote
Old 03-28-2009, 02:43 PM   #4
Splinter
Member#: 106510
98 Widebody 3.4L
Smooth Safety Blue
Take off the IAC and clean it out with some brake cleaner (not carb cleaner, it leaves a film)
Splinter is offline   Reply With Quote
Old 03-28-2009, 03:28 PM   #5
GlobalWaste
Member#: 74792
gasoline works really well too
GlobalWaste is offline   Reply With Quote
Old 03-28-2009, 06:31 PM   #6
Joynt93
Member#: 173738
STG2 93' Legacy SS
Can't thouch This
that was my first thought too
Joynt93 is offline   Reply With Quote
Old 03-28-2009, 08:03 PM   #7
banman
Member#: 12408
2006 Legacy GT
Thanks, guys. I've passed on your suggestions and I'll post up with the results if I hear any.
He also updated with a few more specific details which might help:
So it seems the stalling happens only when pushing the clutch in while braking, when the engine's moving at high-ish revs. So what happens is the engine slows to idle, overshoots a bit, and then stabilises. But if it's coming from 2000rpm or more, it
overshoots far enough to stall.
Old 03-28-2009, 10:35 PM   #8
brendan_mac
Member#: 125055
12 STI hatch
It's also possible there's a vaccum leak. Old OBD systems like that can give you a fluctuating idle. One solution would be to increase the idel a bit if you can't kind the leaky hose.
brendan_mac is offline   Reply With Quote
Old 03-28-2009, 11:41 PM   #9
Splinter
Member#: 106510
98 Widebody 3.4L
Smooth Safety Blue
I found with the several first gen legacys Ive had, a vacuum leak simply causes a higher idle.
Old 03-29-2009, 12:28 AM   #10
Joynt93
Member#: 173738
STG2 93' Legacy SS
Can't thouch This
thats like running my bov on my leggy, if i hit the gas and quickly release it will stall or try to fix itself.
so im wondering if there is a good vacuum leak although it should idle rough if it is.
maybe his alternator/ battery system is real bad and when he hits the brakes, to much juice is used and stalls the car?
Old 04-05-2009, 05:24 AM   #11
banman
Member#: 12408
2006 Legacy GT
Ok, good news is that cleaning the throttle body seems to have fixed the problem.
Bad news is that he discovered that the oil level was almost off the end of the dipstick, and there was almost no power steering fluid left.
question for 05-07 legacy owners no good Legacy Forum 6 10-17-2006 07:53 PM
Will a 1st gen Legacy rear sway ('92) fit a 2nd gen Legacy ('99)? whtlegacy Brakes, Steering & Suspension 2 06-24-2004 02:38 PM
Will Legacy GT Sideskirts fit 1st Gen Legacys? EJ22T Legacy Forum 1 11-17-2002 04:05 AM
AfterMarket Fogs For 1st Gen Legacies ejicon Legacy Forum 8 12-10-2001 07:51 PM
Front pipe for 1st Gen. Legacy turbo? Ben Legacy Forum 0 02-15-2001 01:23 AM
