Go Back   NASIOC > NASIOC General > Motorsports > Autocross
Old 03-28-2009, 10:25 AM   #1
theBrick714
Member#: 121967
06 STi
Default First time on Rcomps ???
Can someone put me in the ball park with what psi I should be at with my new v710's. I was usually around 32-34 psi in my star specs last year. Also, is 45-50 degrees too cold for them? should I go with the 275 rcomps or stick with my 245 dunlops? Thanks
theBrick714 is offline   Reply With Quote
Old 03-28-2009, 11:25 AM   #2
Whiteghost 2.5
Member#: 72994
2001 Racekor
Emerald Green
I ran around 32-31 frt/29-28 rear
Yea it might be a little to cold to get heat into them. but that really depends on how long the course is.
Josh
Whiteghost 2.5 is offline   Reply With Quote
Old 03-28-2009, 01:41 PM   #3
Storm
Member#: 5218
96L Most Over-
Developed Beater
I think your piggish STi will heat up the 710s. They'll be loose until they heat up....but Josh's pressures are about right. Chaulk the shoulders to determine rollover and adjust as necessary.
Jay
Old 03-28-2009, 01:47 PM   #4
Scooby South
Subtly Outspoken
Member#: 238
99 Ver6 Recreation
JDM Speedwagon 3 LSDs..:)
on my STi when I ran the 710's...32/32 hot...is about where it liked it...of course it depends on your suspension also.. I was on Coilovers 12/8 Springs...
Bill
Old 03-28-2009, 09:23 PM   #5
Whiteghost 2.5
Member#: 72994
2001 Racekor
Emerald Green
Yea I didnt take ito consideration that you had an Sti. My RS wouldnt get heat in the tires on a cold morning.
Josh
Old 03-28-2009, 11:21 PM   #6
Butt Dyno
Street's closed, pizza boy
Member#: 17301
is the "dark side"
06 Evo #7 STU, 03 IS300
You're talking about autox, right?
Old 03-28-2009, 11:31 PM   #7
wrxwhat
Member#: 87653
500 hp STI / 1100hp
Supra T / Stock G35
Jay
Yeap, 31/30 is what I run hot
Josh
Absolutely wait until you get some heat in them, they really are a good tire though.
wrxwhat is offline   Reply With Quote
Old 03-28-2009, 11:53 PM   #8
Mechie3
Member#: 120152
Nice info on the pressures. I've always run mine 38 hot, though I haven't experimented with them too much. My one time co driver liked them at 43, though he was a (very good) Camaro driver and liked it super tail happy. I'll have to play with the pressures a bit tomorrow.
Mechie3 is offline   Reply With Quote
Old 03-29-2009, 03:20 PM   #9
controler
Member#: 100271
I had a used (almost dead) set of v700s I bought with a set of wheels. I noticed better traction with higher pressure, 35-40 than with below 35. Granted I was on a mostly stock suspension at the time, so your results may vary.
controler is offline   Reply With Quote
Old 03-30-2009, 02:19 PM   #10
HoRo1
Member#: 15618
38-40lbs HOT
HoRo1 is offline   Reply With Quote
videos of my first time on the track grandmasterchan Member's Car Gallery 2 05-13-2002 04:52 PM
First time on 1/4 mile... Nzo Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 34 05-09-2002 07:20 PM
First time on dirt chkltcow South East Region Forum 1 10-31-2001 02:58 PM
First time on dirt Scoobyslack1 Motorsports 6 09-26-2001 08:27 AM
First time on a manual HydeX Transmission (AT/MT) & Driveline 12 09-23-2001 10:41 AM
