Old 04-14-2002, 12:53 PM   #1
AndyM
Member#: 3219
2004 Impreza WRX STi
WR Blue Pearl
Default Advice please nitrous and what plugs to get?
I still need to get plugs Im woundeirng to those nitrous users out there, what plugs you are running I want to get the NGK-BKR7E, but I got a response from Summit Racing saying that the NGK_BKR7E are only 1 step colder than the MY99 R.S. they didnt have listings for the MY00 & MY01 heres the response I got:
The BKR7E is a 14mm 3/4" reach with a 5/8 hex. This plug would be 1 step colder than the plug listed for the 1999 2.5. Unfortunately, I have no listing for the 2001 to determine if there have been any changes.
AC
Should I still get them?
AndyM is offline   Reply With Quote
Old 04-14-2002, 02:07 PM   #2
tec
Member#: 12649
Stay with the stock plug temp, i ran nitrous on my rs and had no problems! your only squeezing for a few seconds at a time. I'v here that the car will run like crap most of the time with a colder plug with out boost?
tec is offline   Reply With Quote
Old 04-14-2002, 02:36 PM   #3
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
'09 Concours 14 ABS Black
andy i'd got with at least 1 stage colder if not 2...the 2 stage colder plugs are BR8ES-11....these are available at pep boys...stock number 7986(at least they used to be available there)
You are supposed to go 2 stages colder for nitrous or turbo.
jeremy
Old 04-14-2002, 04:07 PM   #4
20mm
Member#: 11607
Platinum Silver Metallic
You need to go at least 1 heat range colder to keep things safe when you are "on the bottle". I run NGK BKR7E's in my car and it runs fine on and off the bottle. The stock # is 6097, 'bout $2.50 each. Go get some, and remember to use anti-seize on the threads and dielectric grease on the boots. Good Luck
-Chad.
20mm is offline   Reply With Quote
Old 04-14-2002, 04:54 PM   #5
AndyM
Member#: 3219
WR Blue Pearl
ha haa thanks guys
Old 04-14-2002, 06:46 PM   #6
22BKEEPER
Member#: 15687
08 Tribeca
Bbronz
AndyM, Go 2 ranges colder, but i dont think you should use a standard antiseize product because they use glassbeads which can cause poor conductivity of heat and electricity when the liquid burns/evaporates away and leaves only the beads. Use a copper/bronze brake grease this will leave copper/bronze material which is a very good conducter. of heat and electricity. 22BKEEPER
22BKEEPER is offline   Reply With Quote
Old 04-14-2002, 10:24 PM   #7
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
who uses anti-sieze anyhow?? not me *shurg*
Old 04-15-2002, 01:12 AM   #8
20mm
Member#: 11607
If your only running a 55 shot or so, 1 heat range colder will be fine. Any bigger shot go 2 heat ranges colder. And who uses brake grease on their spark plug threads? that sounds like a bad idea to me, stick with the anti seize, thats what its designed for. The dielectric grease is designed to keep moisture out of the spark plug wire boot, moisture is bad!
-Chad.
Old 04-15-2002, 05:07 PM   #9
AndyM
Member#: 3219
WR Blue Pearl
I almost forgot what kind of gap do you have the plugs at, I heard anywhere from 28. to 36?
Old 04-16-2002, 01:37 AM   #10
20mm
Member#: 11607
For nitrous applications set it between .030 and .035 . Mine are at .030 right now.
-Chad
What spark plugs to get? surfsubaru Newbies & FAQs 26 04-20-2010 06:37 PM
Need advice on what parts to get. ndubz Newbies & FAQs 18 11-21-2008 12:58 PM
need advice what mods to get.. newbie issue Athrin Newbies & FAQs 23 09-13-2007 08:05 PM
What tire to get? Suggestions and opinions please! Maniac Tire & Wheel 6 06-04-2003 10:19 AM
Advice for guys/...what to do and what not to do with getting girls MattSEG Off-Topic 46 12-05-2002 01:15 AM
