Old 03-28-2009, 04:41 PM   #1
CAMG3
Member#: 184738
2008 Outback Sport
Default NA 6 Speed possible?
Would an STI 6 speed transmission bolt up to a 2.5i and would there be any benefits from doing this?
CAMG3 is offline   Reply With Quote
Old 03-28-2009, 04:47 PM   #2
Buster05
Member#: 107323
2005 Impreza WRX 16g
Crystal Gray Metallic
I believe its been done but it wont make the car any faster.
Buster05 is offline   Reply With Quote
Old 03-28-2009, 05:08 PM   #3
Un0RiGiNaL
Member#: 189748
Instead itll cause more problems
Un0RiGiNaL is offline   Reply With Quote
Old 03-28-2009, 05:19 PM   #4
chazly413
Member#: 151079
2005 2.5RS RBP
too many friction losses
I wouldn't say problems. It's quite a bit heavier than your 5mt, and has better ratios, but the weight will probably cancel that out. If you want to improve your awd, get some limited slips.
chazly413 is offline   Reply With Quote
Old 03-28-2009, 07:52 PM   #5
yarrgh
Member#: 80465
2001 2.5RS
Black Diamond Pearl
if you posted in the correct forum, you may get more responses.
Old 03-28-2009, 08:14 PM   #6
Counterfit
Member#: 124254
2006 06 SGM Slowbaru
"The Scoobinator"
It'll bolt up just fine, but you'll need other parts as well.
Counterfit is offline   Reply With Quote
Old 03-28-2009, 09:15 PM   #7
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
QuickSilver Metallic
I have an '06 6-speed in my car. I bought it a while back to install with the EZ30R that I also have, but the engine swap hasn't happened yet. The 2nd gear in my 5MT went at about 190,000mi or so, and I had the 6-speed already sitting in my garage, so I figured I might as well just have it installed rather than trying to rebuild the 5MT.
The added weight surely isn't a benefit, but I do like the highway cruise, and the gearing of the 6-speed will match up much better with the EZ30R than the 5MT would have. I had an Outback/Type RA 5th gear in the 5MT for better performance on track, but that meant I was spinning 4000rpm @ 80mph on the highway. With the 6-speed I still have that better gearing for the track in 5th, and for the highway I can drop it into 6th and lope along.
Oh, and I'd be curious what "problems" the 6-speed is supposed to create. Can you educate me, Unoriginal?
Pat Olsen
Old 03-29-2009, 12:32 PM   #8
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
I DO question this "new" bell housing of the new Imprezas....unless it's the same on the engine side but what's changed is on the tranny side.
Better gearing for track use. Better gear spacing for more acceleration. Two different trannies, two different purposes.
Yes I rock a JDM DCCD 6spd in my '99 L Wagon. So furious! 80mph@3600rpms in 6th gear. Forget 80mph, that's speeding. 60mph comes in around 2900rpms.
FuJi K is offline   Reply With Quote
Old 03-29-2009, 12:48 PM   #9
LetItSnow
Member#: 38222
'10 &'12 Foresters
another Miata convert
Originally Posted by chazly413 View Post
[it] has better ratios...
Not for autocross! 2nd is lower in the 6-speed, which will find you at fuel cut sooner if your local tracks get to that speed.
LetItSnow is offline   Reply With Quote
Old 03-29-2009, 10:50 PM   #10
jordan s
Member#: 122233
1997 Legacy GT
Aspen White 5MT
i was wondering this same thing. i would love an NA 6speed. an H6 motor and 6 speed trans in my car would be my dream set up.
jordan s is offline   Reply With Quote
FS : NV: 2005 Wrx Flat Lambo White! 6 Speed! exdakine Private Vehicle 'For Sale' Classifieds 90 09-29-2011 02:26 PM
WTB: 04 STi 6 speed tranny morgue Private 'Wanted' Classifieds 0 06-04-2010 10:06 AM
STI 6 speed, FULL swap. possible trade? devildevil Private 'Wanted' Classifieds 5 08-07-2008 11:06 AM
Possibly F/S: 05 STI Complete 6 Speed vinceGC8 Drivetrain 11 03-12-2007 05:18 AM
Possible Part Out- STI 6-Speed,Green,Perrin Rails,Gruppe-s header,TXS TBE + More BLUETURBOWRX Private 'For Sale' Classifieds 58 02-13-2005 12:02 AM
