Old 03-28-2009, 04:14 PM   #1
herbine2001
Member#: 126554
2005 BUILT STI
Default need help with piston choice
Ok guys I have a ej257short block with stock crank and rods,acl race main and conrad bearings planning to run a gt3076r, about23lb boost max with pe 850cc sidefeed. the block is already honed 100mm.I am trying to choose pistons for my build,I really like the ceramic coated manley pistons compared to cp pitons.wich is better for my build???? cps $520ishhile manleys $440ish I am also running a ewg 38mm and frontmount intercooler
herbine2001 is offline   Reply With Quote
Old 03-28-2009, 04:17 PM   #2
godforbid67
Member#: 137168
06 Built SGM WRX
35r, PPG, 280's, PSS9.
i think you would be fine either way for that power output, could even try and sneak some stock pistons in there and probably be ok. well wait is it a 2.5 or 2.0???
dont rods ussually go before pistons on our motors?
godforbid67 is offline   Reply With Quote
Old 03-28-2009, 04:20 PM   #3
herbine2001
Member#: 126554
2005 BUILT STI
its a 2.5l sti
Old 03-28-2009, 04:28 PM   #4
herbine2001
Member#: 126554
2005 BUILT STI
aslo I did tgv deletes and mild port and polish.with this the car is actually in Jamaica right now after doing all this I have a cobb access port is there anyone with a map that will tune my injectors and support the modifications that were done?
Old 03-28-2009, 06:22 PM   #5
herbine2001
Member#: 126554
2005 BUILT STI
bump....
Old 03-28-2009, 09:49 PM   #6
godforbid67
Member#: 137168
06 Built SGM WRX
honestly you could throw whatever pistons in there you want and should be ok.
Old 03-28-2009, 10:47 PM   #7
AWDWRXLOVER
Member#: 50267
02 built hybrid
sr55/meth/sick speed
what he said^. people run cp s, weiscos, mahles, je s, supertech etc w/o issue. the builder is more important than the brand imo.
AWDWRXLOVER is online now   Reply With Quote
Old 03-28-2009, 11:02 PM   #8
bertune
Member#: 107290
Is it a jdm or usdm? Why not use ecu flash? Is it 2.0 heads?
bertune is offline   Reply With Quote
Old 03-28-2009, 11:50 PM   #9
methaddict
Member#: 159738
2004 WRB STi
Full Race TS, BW 8374 EFR
If you bought this block already bored to 100mm pistons what pistons were used to determine how much needed to get the p/w clearance. Usually you send your pistons with the block to have the machinist bore the cylinders to the desired spec. So find out what pistons the previous owner sent in during time of machining.
methaddict is offline   Reply With Quote
Old 03-28-2009, 11:54 PM   #10
06njsti
Member#: 150986
06 #001 LSB STi
manley makes some good stuff, i will be doing manley rods and there springs, valves and retainers with cosworth pistons when i do my block in the next few months (more like fall)
06njsti is offline   Reply With Quote
Help With Piston Choice funnybike1 Built Motor Discussion 60 03-09-2009 01:37 AM
Need Help with Tire Choice Gil Off-Topic 18 03-19-2005 05:15 PM
Need help with tire choice/size for 8" wheel jin psu Tire & Wheel 3 02-25-2004 09:22 PM
Need help with these choices?? waitandbleed92 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 01-29-2004 10:50 PM
Moving to Fairbanks need help with car choice bosstone Alaskan Impreza Club Forum -- AKIC 3 07-15-2003 11:07 PM
