#1 |
Member#: 193165
Vehicle:2008 Subaru STI SS |
Goodspeed's New GT35R twin-scroll kit for my 2008 STI will begin on Monday (3/30) and I wanted to share some preliminary info. The turbo is a GT35R twin scroll- .78 A/R, 64mm 84 trim with twin wastegates. This is a custom setup that Goodspeed developed. Here the projected mod list for this kit:
Goodspeed GT35R w/twin wastegate setup Goodspeed FMIC 850CC injectors 255lph Walbro feul pump Goodspeed Speed density air intake Downpipe/Upipe One level down colder sparkplugs - not sure what brand or gap yet. Pics will arrive after the build has made some good progression. Current mods are: Cobb AP with Stage 1 AZ91 Map. Cobb SSK Cobb Turbo heat shield Cobb front and rear sway bar kit Cobb Sport springs Invidia Q300 exhaust Whiteline rear suspension bushings Kartboy Front Endlinks Whiteline steering rack bushings Motul fluids for engine, diff, and transmission Contact GoodSpeed Performance Lab @ 480.747.6150 for pricing. I got this part of this excerpt from Captain Inferno's thread on NASIOC: ""Quoted from there web site" Our goal: To provide our customers a no-compromise, completely streetable turbo kit. One with extremely fast spool and a smooth power band, while still providing massive HP and torque potential. A step closer to having your cake and eating it to! For this reason we have chosen our own GT35 twin scroll configuration using a fully divided header and custom up pipe. The separate waist gates can be plumed back into the exhaust for a stealth street setup or dump for race applications." Our goal is to make about 400WHP on 91pump since I am still on the stock block and clutch. Dont want to push it over that since I cant afford a new motor right now. I do have plans in about 1 year or so to possibly upgrade to either a new shortblock or build the motor up to run boost. I know this kit is not even close to hitting its peak on the stock block but this is my plan to upgrade slowly and enjoy each phase. My car has about 6100 miles now and I just completed a leakdown and compression test at Goodspeed. Results are: Compression 130, 130, 130, 130 Leakdown 4%, 4%, 4%, 4% Motor is pretty tight so I am pretty confident that it should hold that power for a little while....... Here are a few pics of the ride and the suspension work. http://flickr.com/gp/34691491@N05/7kT0c7 http://flickr.com/gp/34691491@N05/6Gs6EX http://flickr.com/gp/34691491@N05/U41594 http://flickr.com/gp/34691491@N05/Ho2S80 http://flickr.com/gp/34691491@N05/D65M33 http://flickr.com/gp/34691491@N05/51VzeW http://flickr.com/gp/34691491@N05/e8c3Wa
#2 | |
Member#: 200004
Vehicle:2009 SS STI Spark Silver |
#3 |
Member#: 84482
Vehicle:2005 STI.UR gt4088r E85 pro comp sti |
i will have more proof in about a week or so, with more dyno results, but i am really starting to believe that the twin scroll turbos start to stand out with the larger a/r. I was tuned with the .85 a/r on the 40r and power was a little lower than expected...since then i have put in a 1.06a/r and the spool is actually better than the .85, i think the .85 was just too restrictive with my custom UR header...i think it should be something to reconsider (the.78 a/r, go with a larger a/r) that’s my .02 best of luck!
#4 |
Member#: 104878
TXIC
Vehicle:02 wrxbastardchild aw, 1,000,000 whp 2 aw tq |
Thanks onlyturbo for reposting the first post in the second post. I dont think I read it the first time.
That muffler is ugly as sin with the pipe going straight in from the bottom. I think it will have clearance issues for some people. |
#5 |
Member#: 110994
Vehicle:2004 WRX STi something good on the way |
130 compression is pretty low. the lowest end of the spec in the service manual is 142psi.
#6 | |
Member#: 4498
NWIC
Vehicle:WRX H6-3.0 Turbo www.surgelinetuning.com |
The are three potential other causes for consistant lower readings like that: (1) A Built motor with loose tolerances (my CP piston block with 4 thou measured at about 130) (2) Low temperatures (3) Low cranking RPM from having battery in the trunk, or using jumper cords to jump from the battery to the car due to removing the battery to get to the spark plugs. Jeff |
#7 |
Vendor
Member#: 196004
BAIC
Vehicle:06 STI OBP |
Or a gauge that is off
#8 | |
Member#: 193165
#9 |
Member#: 193165
#10 | |
Member#: 110994
#11 |
Member#: 106220
SWIC
I was just talking to Jon about this yesterday. Can't wait to see how it turns out and what numbers it puts down.
#12 |
Member#: 164516
SWIC
Vehicle:2004 STI PSM |
Congrats man on your setup. Joe and Jon are top notch at what they do, Joe built my 04 STi back in 04 and I'm very very happy with what I have. Post up some pics when the job is done.
Thanks Rick |
#13 |
Member#: 48943
Vehicle:2004 95%*STi Blu/Gld www.dcawd.com |
Subb'ed, I'm interesting in the spool and power this makes!
#14 | |||
Member#: 193165
.Latest update, car is torn down and the build up has begun . This will take several weeks since the FMIC and Intake is brand new to the 08 and will need to designed and fitted. Will post pics when they become available. |
#15 |
Member#: 184206
SWIC
Vehicle:2013 X1 sDrive 28i gray |
I dyno'd my car at Goodspeed today. .
the Sti is going to be a BEAST. Jon is hard at work haha barely even said hi lol |
#16 |
Member#: 193165
http://flickr.com/gp/34691491@N05/74yNHn
http://flickr.com/gp/34691491@N05/F5521p Here are 2 sneak pics of the project. Jon has been hard at work the last 4 days. Yes, that is a 4inch intake with a massive air filter. |
#17 |
Member#: 76826
NWIC
Vehicle:2013 delorean P.I.T.A. to clean silver |
Good luck with the build -
I built nearly the same kit, albiet with a built block and Jun head/valvetrain w/ kelford cams... You're going to see how quickly your fuel cuts you short of your HP goals past 400whp with the 255lph - I had to upgrade to a Automotive 250GPH fuel pump w/ pressure regulator and 1000cc injectors to crest over the 500 whp mark... after that though, fuel issues weren't much of a problem... I'm sure you're already trackin that, but ay, its worth a mention. Granted the dyno I was on was incredibly low reading, so who knows what the actual numbers were... I'll be looking forward to seeing what the results are on the stock block... the built block SCREAMS with that setup... I'm using a single wastegate however, divorced from the up-pipe(s) at an equal length. I couldnt find the room to fit two wastegates in there, but I suppose it can be done in such a slim location(aps did it, and you're doing it as well - congrats!). difference between the normal 35/40r (.78a/r atp turbo) and the conventional 35r is pretty substantial when it comes to spooling at lower RPM's. You're going to have a fun time with your setup. pm me for pics/ideas if you run into any problems. kor |
#18 | |
Member#: 193165
#19 |
n00b Moderator
Moderator Member#: 10613
South East
Vehicle:2002 USDM WRX WRB |
please use forged after market pistons..
or you'll be replacing them.. |
#20 | |
Member#: 74324
SWIC
Vehicle:04 GT40R/623WHP GSXR1216, TJ runnin 40's |
#21 |
Member#: 74324
SWIC
I stopped by Goodspeed and saw your car.... WOW that looks SICK! Congrats. I cant wait to see that thing tear'en it up. Looks awsome man, hats of to the guys at Goodspeed.
#22 | |
Member#: 193165
Hats off too to Jon and Joe at Goodspeed. |
#23 |
Member#: 178047
SWIC
Vehicle:02 WRX STI Spec C Black |
You should see this thing now! THat True 4 inch intake and 4 inch downpipe is just sick. Jon is doing some great fab work!
Clark |
#24 |
Member#: 36033
SCIC
Vehicle:CEO PhatBottiTuning 2006 STi GTX3582 + Meth |
is this car gonna run a maf still? didnt see it in the intake anywhere....
#25 |
Member#: 193165
| Thread Tools | |
| Display Modes | |
| FS : 2008+ STI SPT cat back exhaust | Hokie-wrx wagon | MAIC Private Classifieds | 6 | 06-08-2010 10:33 AM |
| All in a weekend's work - A 2008 STI Dom III Build - Includes "HOW TO's" | squashman | Member's Car Gallery | 54 | 02-11-2009 03:36 PM |
| Full-Race GT35r Twinscroll anyone? | ruben7520 | Factory 2.5L Turbo Powertrain | 2 | 02-08-2009 02:42 PM |
| 04 STi GT35R Full Build Pics | RenegadeWRX | Member's Car Gallery | 69 | 05-06-2007 11:06 AM |
| 06 cgm sti gt35r crawford sl3 build | fountainoffshore | Vancouver Impreza Club Forum -- VIC | 60 | 10-23-2006 09:46 PM |
