Old 04-14-2002, 02:33 PM   #1
Elite Twit
Member#: 3014
1997 Outback Sport
All show lil go for now
Default Underdrive Pulley Install Help quick
I have all my belts off and car is ready for me to take off my pulley. Instructions say to use proper tool to hold my flywheel from moving. I tried searching, but search isn't working. I have an automatic, so I can't just put it in gear and have a friend hold teh brakes, we tried that any just to be sure. I called all kinds of places and no one knows what to do, or what i am talking about. Any ideas? What tool of how exactly I hold the flywheel from moving?
Elite Twit is offline   Reply With Quote
Old 04-14-2002, 03:57 PM   #2
DDMan
Member#: 11221
2002 2.5 RS
Black as Midnight!!!
Take out the starter and put a prybar in between the teeth of the flywheel gears.
That should hold it while you get the main bolt loosened.
You will have to do the same to get the bolt back on
DDMan is offline   Reply With Quote
Old 04-14-2002, 04:30 PM   #3
GLwagon
Member#: 16696
2002 WRX Sedan Stg2
2013 OBW roll'n at 30+mpg
Lightbulb
See if craftsman or rigid tools has a "grip wrench" type tool largenough for the crank pully
it is like a renforced rubber belt with a handle that you can wrap around the pully
good luck
GLwagon is offline   Reply With Quote
Old 04-14-2002, 04:58 PM   #4
AndyM
Member#: 3219
2004 Impreza WRX STi
WR Blue Pearl
I used a "chain wrench" basically its grips the pulley nice, have a buddy help you out though, that bolt was on there real tight hope it help and good luck
AndyM is offline   Reply With Quote
Old 04-14-2002, 06:43 PM   #5
Hawk296
Member#: 14555
1995 Impreza L
Baja
I didnt have subarus crankshaft pulley tool so I also ued a chain wrench. I put some shop rags around the pulley though so i didnt tear apart my crankshaft pulley. Its on there really tight (160 ft.lbs??? something like that) so you may need help.
Hawk296 is offline   Reply With Quote
Old 04-15-2002, 05:54 AM   #6
JSiwek
Member#: 14909
Get a long breaker bar w/ proper size socket, put it on the nut holding the pulley with the end of the bar resting (as close as possible) on the ground (through your engine compartment). It has to be resting on the ground on the correct side... the side that, if the crank shaft were to turn, the bar would be turned into the ground, not up into the air. Now, tap the starter! Your starter will do all the work breaking the nut loose. You may want to disconnect your engine coils so it doesn't accidently start up.
To put the new one on, you'll need a strap wrench. That stock nut is on there sooooooooo tight though, that you probably wont be able to get it off with a breaker bar and strap wrench (you can't get enough torque on that strap wrench to do it)... but you can put the new one on w/ it.
Jeremy
JSiwek is offline   Reply With Quote
Old 04-15-2002, 08:23 PM   #7
Mk750
Member#: 11210
2007 Forester XT
Here is what I have done in the past. It is almost like JSiwek's idea. I put a breaker bar on the bolt and then place the bar next to the air conditioner compressor pulley. My friend gives the starter a blip, and the bolt is loosened. To effectively tighten, you will probably have to have some sort of chain wrench to wrap around the pulley.
MK
Mk750 is offline   Reply With Quote
AEM Intake and Underdrive Pulley Installed kcollins Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 08-07-2002 03:06 PM
Underdrive Pulley Install Help Quick Elite Twit Normally Aspirated Powertrain 2 04-15-2002 03:44 PM
underdrive pulley belts.... help! Benjamin Tang Normally Aspirated Powertrain 6 09-29-2001 06:47 PM
underdrive pulley belts... help! Benjamin Tang Vancouver Impreza Club Forum -- VIC 7 09-28-2001 10:19 PM
Underdrive pulley install... SFsube Bay Area Impreza Club Forum -- BAIC 2 05-18-2000 05:03 PM
