Old 03-28-2009, 08:42 PM   #1
boost_556
Member#: 176536
2004 wrx
blue
Default engine rattling at abt 3-4k rpm
appreciate any answers or ideas on this . My engine has a rattling sound just around 3-4k rpms, is it my connecting rod bearings?My car doesn't miss, hesitate or anything and drives perfectly fine and has been like this for a while but i would like to fix the problem before it develop into something more serious .
boost_556 is offline   Reply With Quote
Old 03-28-2009, 08:57 PM   #2
25rstautoxr
Member#: 43958
99 RS Asphalt-01RS
Dirt-01 Forester swapped
Could be. I just had my motor go out with the same thing you have listed above.
Is it a built motor?
25rstautoxr is offline   Reply With Quote
Old 03-28-2009, 09:02 PM   #3
boost_556
Member#: 176536
2004 wrx
blue
nah its totally stock internals, but is it wise to just change the rod bearings and maybe put some forge pistons in the same time.looking for the least costly alternative.
Old 03-29-2009, 11:42 AM   #4
Fongers
Member#: 118239
2002 Built Wagon
Wife- 2004 Outback SE
I hada built block go with the same symptoms. Probably a rod bearing but make sure its not just flapping somewhere in the boost system first... It you're looking to stay under 400, pistons and bearings should be fine.
Fongers is offline   Reply With Quote
Old 03-29-2009, 02:22 PM   #5
boost_556
Member#: 176536
2004 wrx
blue
thanks currently at 335WHP but 400 would be good enough for the streets, so i guess i would just change the pistons, main and rod bearings for now.thanks
Old 03-29-2009, 04:08 PM   #6
Fongers
Member#: 118239
2002 Built Wagon
Cool, good luck man and make sure to get a tight machine shop job with all the bores/rings and get them to balance the parts before they go in...
boost/fuel cut at 3-4k rpm scoodhoop Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 12-24-2009 02:35 PM
Ej20k power loss above 3-4k rpm. stirs25 Pre-2002 Factory Turbo Powertrain 55 03-06-2009 12:48 PM
a whistle at 1st or second gear at 3-4k rpm!! BAMBOO Normally Aspirated Powertrain 7 05-30-2007 11:22 PM
power lag between 3-4k rpm? GrandpreRS Engine Management & Tuning 0 01-09-2006 12:35 PM
Tell me more about hesitation between 3-4k RPM? ThinkTank Normally Aspirated Powertrain 7 08-07-2001 05:33 PM
