#1 |
Member#: 103320
Vehicle:2005 wingless aspen white |
![]() some facts: 1) after initial tuning (trims zeroed, injectors scaled, MAF scaled) the car feels slow and down on power in closed loop cruising around town. It's almost like a 2L car where you're always going into boost getting the car to accelerate. Vacuum is good at idle, -18 in/hg and will go to -21 under hard vacuum deceleration. 2) the car has a fully built motor with 272 cams TGV deletes ported heads, EWG, FMIC, etc etc 3) getting random misfire codes (stock damper, ACT streetlight flywheel and sprung 6 puck). CEL will come on once every 2-3 days 4) plugs are LFR7AIX (one step colder) gap verified at 0.028" I'm wondering if one of the injectors (the really brown one in the pic) is getting more fuel which has caused the other jugs to run leaner in my attempt at scaling everything. since the front o2 is in control it would have no means of correcting for a cylinder imbalance. opinions are welcome, thanks!
#2 |
Member#: 134949
VIC
Vehicle:'07 SWP STi Twinscroll ViPec Anti-lag |
Plugs look exactly like mine (minus the brown one) but with not as much carbon build up. Misfire codes might be because of the lightweight flywheel?
#3 | |
Member#: 103320
normally misfire code appears during the period when coolant is coming up to temp, so I thought it might be from the noise of the forged motor |
#4 |
Member#: 103320
update: car had a bad MAF sensor. Haven't read plugs yet but it runs smooth and strong now.
MAF was working when motor let go (or so I thought). |
| Thread Tools | |
| Display Modes | |
| my new AP reads when plugged in my computer but... | beedee | AccessPort | 7 | 05-11-2009 07:14 PM |
| Help me read my plugs | jackansi | Built Motor Discussion | 10 | 09-04-2008 06:19 AM |
| Reading Spark Plugs | suberdave | Pre-2002 Factory Turbo Powertrain | 5 | 07-27-2007 12:07 AM |
| spark plug experts - review my plugs - cobb 2.5 30,000 miles | anthonyrb98 | Service & Maintenance | 31 | 11-13-2006 11:15 PM |
| is it ok to read fresh plugs? | blackie | Service & Maintenance | 2 | 04-19-2005 09:51 PM |
