Go Back   NASIOC > NASIOC Technical > Engine Management & Tuning > Other Engine Management
Old 03-28-2009, 10:20 PM   #1
dexterous
Member#: 23553
ZOMG my car is
actually working!!!
Default Fluttering AFRs while calibrating Hydra WB O2 - Is this normal?
I followed the instructions in the Hydra manual (pages 43-47) to the letter and I just want to make sure that my results were normal. Here's what I did click for click without a single detail missing:
1. Started off with the WB unplugged and then turned on the power but did not start the car.
2. Opened the hydra software on my laptop and selected open from ecu to grab a current copy of my map.
3. Went to "map group" > "settings 1" > "sensor type and calibration"
4. Modified the "UEGO zero calibration" setting until the AFR value at the bottom of the window stayed close to 14.7 (it was jumping around by +/1 0.05 AFR)
5. Since the car was already up in the air, I plugged the WB in (never shut the power off and left that window opened on the laptop) and let it dangle from the harness in the open air. It almost instantly became hot to the touch and I could see the red glowing element inside.
6. I waited about three minutes for the WB to come up to temp and then went back to my laptop.
7. I modified the "UEGO gradient calibration" value until the AFR value at the bottom of the window stayed close to 21.5 but it continued to roll through values between 21.42 and 21.53. Since the AFR mostly rested on 21.5 and occasionally held for a few seconds I figured that it was as close as I could get it.
8. I closed the window and saved the map to a file on my desktop.
Is this normal? Did I do it correctly?
Here are a few screen shots. This is where I ended up:
On the main screen the AFR reading with the WB in opend air almost always shows 21.5 and almost never moves. When it does change it only moves to 21.4 and then back to 21.5.
At this point, the car starts and runs but the AFRs 15 seconds after startup (car has not run in over 72 hours) were around 10.5 but they rolled up and down a bit. I only gave it about 30 seconds to run before I shut it down and called it quits for the night (long day). I do know that the map that I am running is very close to my setup but the car is mapped for Perrin modified stock injectors and I am running deatschwerks modified stock injectors.
dexterous is offline   Reply With Quote
Old 03-29-2009, 07:54 AM   #2
n2oiroc
Member#: 141952
03 emo 8/2011 wrx
sounds about right. it will fluctuate. just get it as close as possible and recheck it.
n2oiroc is offline   Reply With Quote
Old 03-29-2009, 09:22 PM   #3
wrspeed
Member#: 40110
04 STI
131 MPH 4th gear Madness
there is your problem..... is suppose to be 20.7 to 20.8
wrspeed is offline   Reply With Quote
Old 03-30-2009, 12:40 AM   #4
n2oiroc
Member#: 141952
03 emo 8/2011 wrx
no it isnt. hydra changed the value last year.
Old 03-30-2009, 01:50 AM   #5
wrspeed
Member#: 40110
04 STI
and now im aware.
Old 03-30-2009, 01:57 AM   #6
wrspeed
Member#: 40110
04 STI
dexterous is offline Report Post Reply With Quote
you going to have to play with the starting, fuel trim & fuel map to get the car to start around 12.0 afr and then creep to 14.7 (if you dont have CAMs) is normal to start a little rich specially with a subaru motor.
Old 03-30-2009, 06:43 AM   #7
n2oiroc
Member#: 141952
03 emo 8/2011 wrx
and now im aware.
i doubt it matters either way, but here it is!
Hydra 2.6 Updates and revisions
Differences in Software and firmware:
Software differences:
Hydra 2.64R3
• First 2.6 Release for the North American Market
• Bugs found, load and RPM spread axis was not working, and clicking hotkey ”I” did not cycle between metric and imperial in settings scale.
Hydra 2.64R4
• First 2.6 release with traditional and simplified Chinese Menus
• Released for Asia Use only
Hydra 2.64R5
• Added Input Diagnostic(Dealer use only)
Hydra 2.64R5B
• Fixed load and rpm spread
• Fixed metric/imperial switching with hotkey”I”
• Metric vacuum is now in “bar” in user settings
• Added filtering for free air calibration and TPS/PPS calibration
Firmware differences:
95,23,30,141
126,23,30,141
• Free air calibrate wideband O2 sensor to 22.8
• Found range of calibration close to end of scale
173,189,180,143
• Revised free air calibration of Wideband O2 to 21.5
My clutch is dead at 42K is this normal? Ripper_AWD Normally Aspirated Powertrain 9 06-07-2012 07:46 PM
is this normal for the normal headlight sequence for an 07 outback? jawwadh Electrical & Lighting 6 08-08-2008 11:34 PM
faint fluttering at idle. is this normal? Chris85xlt Newbies & FAQs 6 10-01-2007 03:07 PM
O2 Sensor Issues-is this normal? CONBON101 Service & Maintenance 2 10-05-2004 02:28 PM
Reserve is hard to engage 3 out of 5 times... Is this normal? MrP0nch0 Technical Forum Archive 23 08-29-2000 05:28 PM
Message Board Statistics All times are GMT -4. The time now is 02:59 AM.
