Old 03-29-2009, 12:06 AM   #1
Twiztidunreal
Member#: 63249
2004 2.5 STI Wagon
05 FXT Black
Default And the build finally begins...
well after months of being at the machine shop(cracked ringland, bend valve, and bad valve guides), and thousands of dollars in labor, i got my heads and block back today..
so for ~$4,000(not including bearings, cams, springs, retainers, or pistons, which i had already purchased) i got..
*pressure test heads
*surface heads
*grind (16) valves H/P angle
*radius cut 3-angle
*high performance valve job
*install new valve guides
*adjust valves
*clean & check block
*bore block for 100mm CP pistons
*check rods
*hone block
*check line bore
*assemble short block
*polish crankshaft
*balance rotating assembly
and of course i added in:
100mm CP pistons/rings
DPR stage 3 cams
BC valve springs and retainers
all new valve lifters(buckets)
Twiztidunreal is offline   Reply With Quote
Old 03-29-2009, 12:22 AM   #2
wrxG
Member#: 155087
04 WRX
thats a lot of money .. how much power are you going for?
wrxG is offline   Reply With Quote
Old 03-29-2009, 12:28 AM   #3
Twiztidunreal
Member#: 63249
2004 2.5 STI Wagon
05 FXT Black
idk, how ever much i can get from the FP red, lol
Old 03-29-2009, 11:38 AM   #4
Fongers
Member#: 118239
2002 Built Wagon
Wife- 2004 Outback SE
Nice work and good luck. Consider rotated when you put it all back together but you'll get close to 400 with the current already.
Fongers is offline   Reply With Quote
Old 03-29-2009, 12:36 PM   #5
yarrgh
Member#: 80465
2001 2.5RS
Black Diamond Pearl
there's a lot of casting flashing in those oil return passages in the head.
Old 03-29-2009, 02:03 PM   #6
godforbid67
Member#: 137168
06 Built SGM WRX
35r, PPG, 280's, PSS9.
i would think much closer to 500 then 400 with that turbo. if he runs that thing on meth and some good boost it could hit 500 at the wheels.
godforbid67 is offline   Reply With Quote
Old 03-29-2009, 10:37 PM   #7
Twiztidunreal
Member#: 63249
2004 2.5 STI Wagon
05 FXT Black
yeah, im hoping for ~450ish daily on 93 oct 21-23 psi, close to 500+ on race juice or meth..
the full build is in a 04 wagon
2.5 STI block with 100mm CP pistons
WRX heads (w/services listed above)
DPR stage 3 cams, BC springs, retainers
4EAT tranny with cooler and temp gauge
IPT valvebody
IPT high-stall Torque Converter
FP Red ^7cm
Gruppe-S UEL headers(swaintech coated)
Grimmspeed Coated EWG up-pipe
Tial 38mm external wastegate
HKS downpipe
Stromung dual-tip catback
Mr. Josh Lightened crank pulley
TGV port and polish
Throttle body and Intake mani port matched
70mm short ram intake with Simoto Carbon Fiber MAF tube
APS 3in Turbo inlet hose
Modded stock injectors flowing 825cc
Walbro 255lph fuel pump
parallel fuel system
JDM Sport 31*11*3 FMIC
NGK Copper plugs one step colder
ACL race bearings
10mm sti oil pump
160* t-stat
alum. radiator
and every gauge i could think of to make sure i know if the motor doesnt like somerthing, lol
Old 03-29-2009, 10:45 PM   #8
JSarv
Member#: 163445
l33t *******
[email protected]
Get a 8cm2 turbine housing for that red!!! You'll like having the power on the top end.
I regret not getting the 8cm2 on my 2.0 - cant imagine on your beast!
GL - good looking setup!!
-Jerod
JSarv is offline   Reply With Quote
Old 03-29-2009, 10:48 PM   #9
Twiztidunreal
Member#: 63249
2004 2.5 STI Wagon
05 FXT Black
-Jerod
well with the 4eat i cant rev over 6900-7100rpm anyways so i went 7cm for the little bit quicker spool, and ewg to control the creep..
my old 18g was a 7cm and with the ewg never crept and held full boost(-1 or 2psi) all the way to redline..
Old 03-29-2009, 11:31 PM   #10
JSarv
Member#: 163445
l33t *******
[email protected]
Missed the 4eat!
Sounds like a winner then!!
I hold boost to redline - but feel like the 7cm2 is holding me back a bit in the higher rpms - you won't have that problem and will spool that red like nothin!
GL
-Jerod
Old 03-30-2009, 10:24 AM   #11
TopEndPull
Member#: 126112
93.5 Toyota Supra
Red
nice build, hope you hit your goals
TopEndPull is offline   Reply With Quote
Old 04-07-2009, 06:47 PM   #12
Twiztidunreal
Member#: 63249
2004 2.5 STI Wagon
05 FXT Black
heads on..
almost back together... about 75% done before the drop in..
just have to get the front built.. all the pulleys and timing belt..
bolt up headers and turbo and lines
get ready to drop in..
Old 04-07-2009, 08:05 PM   #13
supasweetr34skyline
Member#: 113060
2000 Built GC8
Aiming for 10's
what paint did you use on ur intake manifold and valve covers? it looks good
supasweetr34skyline is offline   Reply With Quote
Old 04-07-2009, 10:01 PM   #14
john 1badSTI
Member#: 77470
04 sti [email protected]
on e85@ 30psi--spinning
why did you go thru all that and not install a set of arp head studs?I hate to say this but I would be worried about the head gaskts holding to 500whp on the stock style head bolts.
john 1badSTI is offline   Reply With Quote
Old 04-08-2009, 01:04 PM   #15
Twiztidunreal
Member#: 63249
2004 2.5 STI Wagon
05 FXT Black
well, i have not heard of anyone lifting heads off yet with stock head bolts.. if i do, then i will put studs in, but idk, dont see the point in it till i need them..
not like im pushing 36psi or anything.. lol
Old 04-08-2009, 05:29 PM   #16
benw
Member#: 103320
1998 swapped
Forester L
you should be OK with stock bolts.
benw is offline   Reply With Quote
And the pendulum is beginning to swing back... cwb124 Political Playground 128 11-09-2009 11:43 PM
... and the 08 modding begins dawoniyi General Community 18 10-04-2007 08:33 PM
And the Carravan threads begin...Alabama to the dragon. enTarget South East Region Forum 44 06-01-2004 10:54 PM
And the EGT finally works! chrislehr New England Impreza Club Forum -- NESIC 6 09-26-2003 01:16 PM
And the work day begins! Soon2bSubbieowner Mid Atlantic Impreza Club -- MAIC 12 06-19-2003 02:25 PM
