Welcome to the North American Subaru Impreza Owners Club Friday October 28, 2016
Old 03-29-2009, 11:46 AM   #1
Member#: 151188
1997 GC8 EJ20G
2010 W204
Default compression ratio
I`m thinking of mating USDM EJ205 heads to my EJ20G block.
What compression ratio would i want to run? head gasket thickness?
will have forged internals and custom pistons too. specs to build to? optimal bore?
Hoping to make at least 300whp on the stock td05 running 16 psi and big injectors.
WRX_RA is offline   Reply With Quote
Compression ratio? Naturally Aspirated Normally Aspirated Powertrain 31 11-30-2003 10:37 PM
('93-'01) what is the compression ratio on a... wop Impreza Forum 9 06-15-2001 05:34 AM
Boost and compression ratios 98mpreziveRS Normally Aspirated Powertrain 4 03-29-2001 06:58 PM
Compression Ratio for 98-01 RS Delhi Normally Aspirated Powertrain 4 03-14-2001 03:00 PM
Compression ratio question fellfrosch7 Normally Aspirated Powertrain 12 03-14-2001 12:43 AM
