Old 03-29-2009, 12:52 PM   #1
bigolrig
Member#: 185347
2002 EVO3 bugeye wag
EG33 Swapped 2 dr RS
Default burning too much oil??
I got my motor build at a local machine shop, whos reputation is incredible, they build tons and tons of tractor pulling engines across the country. but thats besides the point.
How much oil should i be burning with a new built motor? with in the last 2000 miles ive burnt 2-2.5 quarts. which seems way way excessive to me.
the only mods i have are:
je pistons & eagle ( i know i know bad choices but too late to fix and because i blew my stock motor )
catless megan downpipe
Hks hi power exhaust
Cobb short ram
Cobb Accessport stage 2
and Gimmick Afta-Maf
are my clearances too big?
should i have them pull it, rebuild it with new rings honed and such on the part that is their fault?
any advice?
bigolrig is offline   Reply With Quote
Old 03-29-2009, 01:01 PM   #2
moorebl
Member#: 59238
i have a built sleeved motor and i dont gobble any oil. even afetr 20 runs on a dyno and straight to the track and hot laped it 5 times no oil burning. you have a serious problem my friend. your clearences are all jacked. there is a big difference in building tractor race motors and horizontal opposed subaru flat 4's.
do you have a catch can?
moorebl is offline   Reply With Quote
Old 03-29-2009, 01:59 PM   #3
bigolrig
Member#: 185347
no, they have also built numerous subie motors for teams at mid-ohio.
I dont have a catch can, but I was thinking about it recently, but i think that is sort of just trying to mask my problem. Could just be more blow by?
Old 03-29-2009, 03:31 PM   #4
flycaster
Member#: 60142
2011 WRX
Grey
How do we know your clearances are to blame since we have no idea what they are? Furthermore, without a leakdown test, how could any of us possibly know if you have an engine problem or just a leak somewhere? Get a leakdown test and then report back. (btw, there isn't anything inherently "wrong" with your choice of pistons and rods - they've both been used before with good success)
flycaster is offline   Reply With Quote
Old 03-30-2009, 03:52 PM   #5
bigolrig
Member#: 185347
we called and they said it could be the turbo, which i was thinking too because it has 157k on it hah, and im going to get the specs and a compression/leak down tests as well
engine burns too much oil! Azn-Jap STI Vancouver Impreza Club Forum -- VIC 10 03-30-2005 03:00 PM
Ekk think I added too much oil for my oil change.. sti. NewShockerGuy Service & Maintenance 13 03-17-2005 05:15 PM
Too much oil causing sluggishness? Marc Sawaya Normally Aspirated Powertrain 10 07-08-2001 02:36 AM
need answer fast! too much oil, bad? pbnj9786 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 11 05-06-2001 09:55 AM
